Double check your configuration, especially the command line. What emulator are you using? If you're using Fusion, my command line is:
Fusion.exe -32x -fullscreen "[ROMPATH]\[ROMFILE]"
Hope that helps. If you're using a different emulator, we'll have to investigate further.
When you say it works outside, do you use the command line?
You should be able to drop the -32x switch, Fusion auto detects the system.
Run it, and if it didn't work post the contents of your runitgame.bat file.
Okay... Did you make the adjustment I mentioned?
Where's the runitgame.bat I asked for?
Help me help you here bro.
hi .i verify
the command line is this one
i tried in cmd fusion.exe -32x d:\......\xx.rom and starts correctly
in setup bios
m68kbios 32X_G_BIOS
master bios 32X_M_BIOS
slave bios 32X_S_BIOS
but in this emulator i dont see my movie /snap... but i downloaded with emumovies software
So does that mean you fixed it but now your video snaps don't show?
Verify your video paths are correct.
