Hello,
I use a tones of mame mp4 that work fine in other players (VLC, wmp, hyperspin), and they are not
well managed in Gameex (the last version).
Some seems ok, some are black with only sound, some provide squares ...
Sometime GEx is stuck or crash...
find attached an exemple.
Do you have an idea ?
thanks in advance
below message when crash (when I scroll in game list to switch the video snap)
23:43:14.3 07/09/2015: Opening Configuration File
23:43:14.3 07/09/2015: GameEx: Version 14.35: Starting Log
23:43:14.4 07/09/2015: Windows 7 Édition Intégrale Service Pack 1 64 bits
23:43:14.4 07/09/2015: Aero running
23:43:14.4 07/09/2015: Initializing Vista/Windows 7 volume control
23:43:14.4 07/09/2015: Getting CPU and RAM info
23:43:14.4 07/09/2015: Intel® Core i7-4770 CPU @ 3.40GHz, 16260MB
23:43:14.4 07/09/2015: 3,39Ghz - 8 Cores or CPU's
23:43:14.4 07/09/2015: Running Randomize()
23:43:14.4 07/09/2015: Loading PlugIns
23:43:14.4 07/09/2015: Checking for applications to Launch On Startup
23:43:14.5 07/09/2015: Setting default net connection limit to 15
23:43:14.5 07/09/2015: Running Misc startup tasks
23:43:14.5 07/09/2015: Setting Menu types
23:43:14.5 07/09/2015: Getting Configuration Values
23:43:14.5 07/09/2015: Using Theme: Default - ArcadeVGA Lo-Res
23:43:14.5 07/09/2015: Checking for alternate Image Directory for Theme: Default - ArcadeVGA Lo-Res
23:43:14.5 07/09/2015: Using Images from theme: Default - Media Center V1\MEDIA\
23:43:14.5 07/09/2015: Launching HideOS.exe
23:43:14.5 07/09/2015: Initialising Video/MNG DLL's
23:43:14.5 07/09/2015: GameEx will check for media insertion (may affect performance)
23:43:14.5 07/09/2015: Hiding Taskbar
23:43:14.5 07/09/2015: Is Media Center running?
23:43:14.5 07/09/2015: Checking/Creating LCD Registry values
23:43:14.6 07/09/2015: Check Media Center Exit/Start Mode
23:43:14.6 07/09/2015: Media Center Mode 2
23:43:14.6 07/09/2015: Video previews on. Warning: Only recommended on modern systems
23:43:14.6 07/09/2015: Snap Delay set to: 4
23:43:14.6 07/09/2015: Get other settings
23:43:14.6 07/09/2015: Desktop set to Hide ICONS and set Background to Black
23:43:14.6 07/09/2015: Set: Find emulator artwork on best match basis
23:43:14.6 07/09/2015: Start work for Form
23:43:14.6 07/09/2015: Getting Original Screen Size
23:43:14.6 07/09/2015: Opening Database Connection
23:43:14.7 07/09/2015: Initializing Component
23:43:14.7 07/09/2015: MAME Path is: F:\games\emulation\mame64
23:43:14.7 07/09/2015: MAME EXE file is: mame64.exe
23:43:14.7 07/09/2015: ROM Path is: F:\games\resources\mame\roms
23:43:14.7 07/09/2015: Catver.ini is located at: F:\games\emulation\GameEx\DATA\catver.ini
23:43:14.8 07/09/2015: controls.ini is located at: F:\games\emulation\GameEx\DATA\controls.ini
23:43:14.8 07/09/2015: History.dat is located at: F:\games\emulation\GameEx\DATA\history.dat
23:43:14.8 07/09/2015: nplayers.ini is located at: F:\games\emulation\GameEx\DATA\nplayers.ini
23:43:14.8 07/09/2015: command.dat is located at: F:\games\emulation\GameEx\DATA\command.dat
23:43:14.8 07/09/2015: MAMEinfo.dat is located at: F:\games\emulation\GameEx\DATA\mameinfo.dat
23:43:14.8 07/09/2015: Loading Controls.ini map file
23:43:14.9 07/09/2015: Snap Path: Not Found
23:43:14.9 07/09/2015: Database Snap Path: Not Found
23:43:14.9 07/09/2015: Background Snap Path: Not Found
23:43:14.9 07/09/2015: AVI Snap Path is: F:\games\resources\mame\video
23:43:14.9 07/09/2015: Flyer Path: Not Found
23:43:14.9 07/09/2015: Cabinet Path: Not Found
23:43:14.9 07/09/2015: Cabinet 3D Path: Not Found
23:43:14.9 07/09/2015: Title Path: Not Found
23:43:14.9 07/09/2015: PCB Path: Not Found
23:43:14.9 07/09/2015: Artwork Preview Path: Not Found
23:43:15.0 07/09/2015: Panel Path: Not Found
23:43:15.0 07/09/2015: Manual Path: Not Found
23:43:15.0 07/09/2015: Icon Path: Not Found
23:43:15.0 07/09/2015: Marquee Path: Not Found
23:43:15.0 07/09/2015: Applying Language/Text
23:43:15.0 07/09/2015: Text/Language: French
23:43:15.0 07/09/2015: Loading Language/Text
23:43:15.0 07/09/2015: Using 3D Alpha Blended Animations.
23:43:15.0 07/09/2015: Retrieving resolution setting
23:43:15.1 07/09/2015: Using General Font: HandelGothic BT
23:43:15.1 07/09/2015: Using Title Font: HandelGothic BT
23:43:15.1 07/09/2015: GameEx will try to reduce CPU usage
23:43:15.2 07/09/2015: Initialising Direct3D
23:43:15.2 07/09/2015: Setting Resolution to 1280x1024 32 bit color
23:43:15.2 07/09/2015: Creating Surfaces
23:43:15.4 07/09/2015: Creating Primary Surface - Full Screen Mode
23:43:15.4 07/09/2015: Creating Back Buffer
23:43:15.5 07/09/2015: Loading graphic Surfaces
23:43:15.5 07/09/2015: Display is running at: 1280x1024 32bit color, 60hz
23:43:15.5 07/09/2015: Adapter: Intel® HD Graphics 4600
23:43:15.5 07/09/2015: Max texture size: 8192x8192
23:43:15.5 07/09/2015: Available texture memory: 1681MB
23:43:15.6 07/09/2015: Initialising Bass Audio Library
23:43:15.6 07/09/2015: Creating Surfaces Misc and Dialogs
23:43:15.6 07/09/2015: Creating Surfaces Volume
23:43:15.7 07/09/2015: Creating Surfaces Arrows
23:43:15.7 07/09/2015: Creating Surfaces GameEXlogo Text
23:43:15.7 07/09/2015: Creating Surfaces Toolbar
23:43:15.7 07/09/2015: Creating Surfaces Toolbar Controls
23:43:15.7 07/09/2015: Creating Surfaces Backgrounds
23:43:15.7 07/09/2015: Creating Surfaces GameEx Logo
23:43:15.8 07/09/2015: Creating Surface Unselected
23:43:15.8 07/09/2015: Creating Surfaces Snaps
23:43:15.8 07/09/2015: Creating Surfaces Menu and List Bars
23:43:15.9 07/09/2015: Creating Fonts
23:43:15.9 07/09/2015: Creating Game Font
23:43:16.1 07/09/2015: Creating Game Font Faded
23:43:16.3 07/09/2015: Creating Title Font
23:43:16.3 07/09/2015: Restoring Title Font From Cache
23:43:16.3 07/09/2015: Creating Font Black
23:43:16.4 07/09/2015: Creating Font Black Small
23:43:16.4 07/09/2015: Fonts Created Succesfully
23:43:16.6 07/09/2015: 5MB Video Memory Used
23:43:38.6 07/09/2015: Attempting to load game list
23:43:38.7 07/09/2015: Initial Emulator Load
23:43:38.8 07/09/2015: Loading Custom Emulators
23:43:38.8 07/09/2015: MAME CMD options: -nowindow -joy -skip_gameinfo
23:43:38.8 07/09/2015: Initialising DirectInput for Gamepad support
23:43:38.8 07/09/2015: Unable to create a joystick device
23:43:38.9 07/09/2015: Loading Start Page
23:43:38.9 07/09/2015: Initializing MCE Remote
23:43:38.9 07/09/2015: Playing intro sound file
23:43:38.9 07/09/2015: Initialization OK! Starting GameEx!
23:43:38.9 07/09/2015: Testing Main Loop Once: Processing Frame
23:43:39.1 07/09/2015: Testing Main Loop Once: Main Loop ran successfully
23:46:14.5 07/09/2015: 21 Consecutive Exceptions Occured
23:46:14.5 07/09/2015: Tentative de lecture ou d'écriture de mémoire protégée. Cela indique souvent qu'une autre mémoire est endommagée.
23:46:14.6 07/09/2015: à Microsoft.DirectX.Direct3D.Sprite.Begin(SpriteFlags flags)
23:46:14.6 07/09/2015: à Direct2D.Direct2d.Surface.Draw(RectangleF DesRect, Rectangle SrcRect, Byte Alpha, Byte Red, Byte Green, Byte Blue, Single Rotation)
23:46:14.6 07/09/2015: à Direct2D.Direct2d.Surface.Draw(RectangleF DesRect, Rectangle SrcRect, Byte Alpha)
23:46:14.6 07/09/2015: à Direct2D.Direct2d.Surface.Draw(RectangleF DesRect, RectangleF SrcRect, Byte Alpha)
23:46:14.6 07/09/2015: à GameEx.GameEx.MainForm.r(Boolean A_0)
23:46:14.6 07/09/2015: à GameEx.GameEx.MainForm.d1()
23:46:14.6 07/09/2015: Trying reinitialising the display after sleeping for 4 seconds
23:46:14.6 07/09/2015: Exception count will be dropped to 15
23:46:18.6 07/09/2015: Warning: Display is running in full screen compatibility mode.
23:46:18.7 07/09/2015: Exception initializing display
23:46:18.7 07/09/2015: Tentative de lecture ou d'écriture de mémoire protégée. Cela indique souvent qu'une autre mémoire est endommagée.
23:46:18.7 07/09/2015: à ?CreateDirect3DDevice@@$$FYGJP$AAVDevice@Direct3D@DirectX@Microsoft@@KW4_D3DDEVTYPE@PrivateImplementationDetails@34@PAUHWND__@634@KP$01AP$AAVPresentParameters@234@PAPAUIDirect3DDevice9@634@@Z(Device pDevice, UInt32 dwAdapterOrdinal, Int32 deviceType, HWND__* windowHandle, UInt32 dwFlags, PresentParameters[] presentationParameters, IDirect3DDevice9** ppRet)
23:46:18.7 07/09/2015: à Microsoft.DirectX.Direct3D.Device..ctor(Int32 adapter, DeviceType deviceType, Control renderWindow, CreateFlags behaviorFlags, PresentParameters[] presentationParameters)
23:46:18.7 07/09/2015: à Direct2D.Direct2d.Device.a(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6, Int32 A_7)
23:46:18.7 07/09/2015: à Direct2D.Direct2d.Device..ctor(Form FormHandle, Int32 Width, Int32 Height, Boolean Windowed, Boolean VSync, Boolean Display16Bit, Boolean SecondaryDisplay)
23:46:18.7 07/09/2015: à GameEx.GameEx.MainForm.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7, Boolean A_8)
23:46:18.7 07/09/2015: à GameEx.GameEx.MainForm.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7)
23:46:18.7 07/09/2015: à GameEx.GameEx.MainForm.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6)
23:46:18.7 07/09/2015: à GameEx.GameEx.MainForm.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4)
23:46:18.8 07/09/2015: à GameEx.GameEx.MainForm.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7, Boolean A_8)
23:46:18.8 07/09/2015: à GameEx.GameEx.MainForm.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6, Boolean A_7)
23:46:18.8 07/09/2015: à GameEx.GameEx.MainForm.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4, Int32 A_5, Int32 A_6)
23:46:18.8 07/09/2015: à GameEx.GameEx.MainForm.c(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3)
23:46:18.8 07/09/2015: à GameEx.GameEx.MainForm.d1()
23:46:18.8 07/09/2015: --**--
23:46:18.8 07/09/2015: 21 Consecutive Exceptions Occured: Exiting
23:46:18.8 07/09/2015: Closing database connection
23:46:18.8 07/09/2015: First Exception:
23:46:18.8 07/09/2015: Tentative de lecture ou d'écriture de mémoire protégée. Cela indique souvent qu'une autre mémoire est endommagée.
23:46:18.8 07/09/2015: à Microsoft.DirectX.Direct3D.Sprite.Begin(SpriteFlags flags)
23:46:18.8 07/09/2015: à GameEx.GameEx.MainForm.a(Int32 A_0, Int32 A_1, String A_2, Boolean A_3, Boolean A_4, Int32 A_5, Int32 A_6)
23:46:18.8 07/09/2015: à GameEx.GameEx.MainForm.p(Boolean A_0)
23:46:18.9 07/09/2015: à GameEx.GameEx.MainForm.g(Boolean A_0, Boolean A_1)
23:46:18.9 07/09/2015: à GameEx.GameEx.MainForm.d1()
23:46:18.9 07/09/2015: It was detected you experienced a DirectX error.
23:46:18.9 07/09/2015: Please note the following for possible solutions to your problem:
23:46:18.9 07/09/2015: 1. Ensure you have the latest version of DirectX installed.
23:46:18.9 07/09/2015: 2. Ensure you have the latest Manufacturer provided video card drivers.
23:46:18.9 07/09/2015: NOTE: Windows/Microsoft Update does not contain the latest.
23:46:18.9 07/09/2015: NOTE: Manufacturer normally means ATI, NVidia, or Intel. Not the brand.
23:46:18.9 07/09/2015: www.ati.com www.nvidia.com
23:46:18.9 07/09/2015: 3. If you do not have a modern video card try the following. 1. Turn off advanced Graphics. 2. Try a lower resolution. 3. Try turning on and using 16-bit colour
23:46:18.9 07/09/2015: 4. Ensure any required video codecs are installed.
23:46:19.0 07/09/2015: 5. Try a different theme, or try running the theme at the resolution it was designed for
23:46:19.0 07/09/2015: 6. Try the latest version of GameEx. GameEx is updated all the time.
23:46:19.0 07/09/2015: 7. If you performed an auto update to this version. Try performing a manual download and install.
23:46:19.0 07/09/2015: Last Exception:
23:46:19.0 07/09/2015: Tentative de lecture ou d'écriture de mémoire protégée. Cela indique souvent qu'une autre mémoire est endommagée.
23:46:19.0 07/09/2015: à Microsoft.DirectX.Direct3D.Sprite.Begin(SpriteFlags flags)
23:46:19.0 07/09/2015: à Direct2D.Direct2d.Surface.Draw(RectangleF DesRect, Rectangle SrcRect, Byte Alpha, Byte Red, Byte Green, Byte Blue, Single Rotation)
23:46:19.0 07/09/2015: à Direct2D.Direct2d.Surface.Draw(RectangleF DesRect, Rectangle SrcRect, Byte Alpha)
23:46:19.0 07/09/2015: à Direct2D.Direct2d.Surface.Draw(RectangleF DesRect, RectangleF SrcRect, Byte Alpha)
23:46:19.0 07/09/2015: à GameEx.GameEx.MainForm.r(Boolean A_0)
23:46:19.0 07/09/2015: à GameEx.GameEx.MainForm.d1()
GameEx.ini
Edited by tthurman
compressed text
Hi Greenaway
This isn't an uncommon issue with Windows & installations, and the recommended solution is typically to install the Shark007 codec pack which can be found on the PinballX homepage. In most cases this resolves the issue.
