Theo Posted May 24, 2006 Share Posted May 24, 2006 Works fine on its own..but through GameEX I get this error coming up:Graphics ErrorDirect 3D failed to initialize your HAL device make sure you have a properly configured 3D Graphics Card compatible with Direct 3D 6.0Then followed by this one:The default or selected video plugin is missing or invalid. Check that you have at least one compatible plugin file in your plugin folderany help apprieciated! Link to comment Share on other sites More sharing options...
Tom Speirs Posted May 24, 2006 Share Posted May 24, 2006 Works fine on its own..but through GameEX I get this error coming up:Graphics ErrorDirect 3D failed to initialize your HAL device make sure you have a properly configured 3D Graphics Card compatible with Direct 3D 6.0Then followed by this one:The default or selected video plugin is missing or invalid. Check that you have at least one compatible plugin file in your plugin folderany help apprieciated!Export the emulator config and post it.But I think the issue might be that you the "Working Path" set incorrectly. Link to comment Share on other sites More sharing options...
Smiff Posted May 24, 2006 Share Posted May 24, 2006 that's the standard error anytime you have a video driver problem and the plugin can't init... if you can put some delay in between gameex and the emu that might help.. i'm not sure.btw, any reason you're using the dx6 plugin? v1.6 default d3d8 plugin is generally better. Link to comment Share on other sites More sharing options...
Theo Posted May 27, 2006 Author Share Posted May 27, 2006 I have now installed the newer Project 64 but same probs..Working Path: C:\Emulators\Emulators Data\N64 - Project64 1.6Rom Path: C:\Emulators\Games\N64Debug Mode: NoCommand Line: Project64.exe [ROMPath]\[RomFile]if i need to post any other info let me know... dont know how to export the config so have had to type stuff out (yawn!) Link to comment Share on other sites More sharing options...
Smiff Posted May 27, 2006 Share Posted May 27, 2006 if you open gameex.ini you can copy paste config.that looks ok though.make sure you have enabled auto fullscreen in pj64 optionsif you're sure pj64 starts ok w/o gameex, i can only think gameex is interfering with dx somehow. what's your video hardware? try changing 16<>32 bit desktopyou could try showdesktop=true aswell, not sure if that makes difference.i can't remember is there a way to tell gameex to delay x milliseconds before launching emu? Link to comment Share on other sites More sharing options...
Vynce Posted May 27, 2006 Share Posted May 27, 2006 Looks like you need quotes around your rompath:Command Line: Project64.exe "[ROMPath]\[RomFile]"This probably won't fix your problem, but it should be done anyway. Link to comment Share on other sites More sharing options...
Smiff Posted May 27, 2006 Share Posted May 27, 2006 Vynceno, wrong, don't do that. pj64 puts its own quotes on, and double quotes = error msg.(unless you have pj64 v1.7x, then you should be ok either way)this isnt his problem, the app is starting ok. Link to comment Share on other sites More sharing options...
Vynce Posted May 27, 2006 Share Posted May 27, 2006 Doh, you're right. Project64 is different. Link to comment Share on other sites More sharing options...
Smiff Posted May 28, 2006 Share Posted May 28, 2006 yeah i don't know what's wrong though. i think something perculiar to his system (video drivers) that doesnt like hiding gameex and starting pj64 (too quickly perhaps). maybe he is short of video memory or something.. without full system specs we're guessing. Link to comment Share on other sites More sharing options...
Theo Posted June 1, 2006 Author Share Posted June 1, 2006 if you open gameex.ini you can copy paste config.that looks ok though.make sure you have enabled auto fullscreen in pj64 optionsif you're sure pj64 starts ok w/o gameex, i can only think gameex is interfering with dx somehow. what's your video hardware? try changing 16<>32 bit desktopyou could try showdesktop=true aswell, not sure if that makes difference.i can't remember is there a way to tell gameex to delay x milliseconds before launching emu?well im not sure what part of this did it...but it did it! thanks i choose fullscreen in pj64, changed desktop to 16 and put yes for showdesktop.wooooo!dont understand.....but woooooo! Link to comment Share on other sites More sharing options...
