It seems like every few releases I have a problem when I upgrade to a new edition of GameEX.
I seem to lose a few emulators in my gameex.ini file. For example, before I upgraded to version 6.14 I had 27 emulators set up. After I upgraded, my list contained only 22. This does not happen with every new release, but it has happened numberous times over the last few months. Luckily, I have been saving a backup of the file before each update, so it hasn't been a real problem. Does anyone else have this happen to them?
I don't know how you could have even had 27. I thought the max available was only 25.
I have 26 emulators listed in the ini file, but when you add in Laserdisk Games total is 27.
I had this problem even when I had less than 20 emulators.
yeh i agree i can only see 25 emulators, unless if you add more in the ini file more apear on the config app.
can you do that?
I think this should be fixed in the next release.
Thanks.
Tom
