GameEx Support File Data
10:04:57.7 7/31/2015: Opening Configuration File
10:04:57.8 7/31/2015: GameEx Background Mode: Version 14.32: Starting Log
10:04:57.9 7/31/2015: Windows 8.1 64-bit
10:04:57.9 7/31/2015: Aero running
10:04:57.9 7/31/2015: Initializing Vista/Windows 7 volume control
10:04:57.9 7/31/2015: Getting CPU and RAM info
10:04:57.9 7/31/2015: AMD A4-3400 APU with Radeon HD Graphics, 4074MB
10:04:57.9 7/31/2015: 2.7Ghz - 2 Cores or CPU's
10:04:57.9 7/31/2015: Running Randomize()
10:04:57.9 7/31/2015: Loading PlugIns
10:04:57.9 7/31/2015: Checking for applications to Launch On Startup
10:04:57.9 7/31/2015: Setting default net connection limit to 15
10:04:57.9 7/31/2015: Running Misc startup tasks
10:04:57.9 7/31/2015: Setting Menu types
10:04:57.9 7/31/2015: Getting Configuration Values
10:04:57.9 7/31/2015: Using Theme: Default - Media Center
10:04:57.9 7/31/2015: Checking for alternate Image Directory for Theme: Default - Media Center
10:04:57.9 7/31/2015: Using Images from theme: Default - Media Center V1\MEDIA\
10:04:58.0 7/31/2015: Initialising Video/MNG DLL's
10:04:58.0 7/31/2015: Is Media Center running?
10:04:58.0 7/31/2015: Checking/Creating LCD Registry values
10:04:58.0 7/31/2015: Check Media Center Exit/Start Mode
10:04:58.0 7/31/2015: Media Center Mode 2
10:04:58.0 7/31/2015: Video previews on. Warning: Only recommended on modern systems
10:04:58.0 7/31/2015: Custom Game Device Input enabled: Getting custom codes
10:04:58.0 7/31/2015: Snap Delay set to: 6
10:04:58.0 7/31/2015: Get other settings
10:04:58.0 7/31/2015: Set: Find emulator artwork on best match basis
10:04:58.0 7/31/2015: SlikStik support enabled
10:04:58.0 7/31/2015: Using DirectInput for keyboard input
10:04:58.0 7/31/2015: Start work for Form
10:04:58.0 7/31/2015: Getting Original Screen Size
10:04:58.1 7/31/2015: Opening Database Connection
10:04:58.2 7/31/2015: Initializing Component
10:04:58.3 7/31/2015: MAME Path is: C:\Emulators\MAME
10:04:58.3 7/31/2015: Model 2 Path Path is: C:\Emulators\Model2
10:04:58.3 7/31/2015: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
10:04:58.3 7/31/2015: Model 2 EXE file is: emulator_multicpu.exe
10:04:58.3 7/31/2015: Model 2 emulator with command line support detected
10:04:58.3 7/31/2015: Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games
10:04:58.3 7/31/2015: ZiNc Path is: C:\Emulators\Zinc
10:04:58.3 7/31/2015: ZiNc EXE file is: zinc.exe
10:04:58.3 7/31/2015: Use ZiNc on. zinc.exe will launch PSX games
10:04:58.3 7/31/2015: MAME EXE file is: mame.exe
10:04:58.3 7/31/2015: ROM Path is: C:\Roms\MAME
10:04:58.3 7/31/2015: Catver.ini is located at: C:\GameEx\DATA\catver.ini
10:04:58.3 7/31/2015: controls.ini is located at: C:\GameEx\DATA\controls.ini
10:04:58.4 7/31/2015: History.dat is located at: C:\GameEx\DATA\history.dat
10:04:58.4 7/31/2015: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
10:04:58.4 7/31/2015: command.dat is located at: C:\GameEx\DATA\command.dat
10:04:58.4 7/31/2015: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
10:04:58.4 7/31/2015: Loading Controls.ini map file
10:04:58.4 7/31/2015: Snap Path is: C:\Emulators\MAME
10:04:58.4 7/31/2015: Database Snap Path: Not Found
10:04:58.4 7/31/2015: Background Snap Path: Not Found
10:04:58.4 7/31/2015: AVI Snap Path is: C:\GameEx\DEMO\MAME\video
10:04:58.4 7/31/2015: Flyer Path is: C:\GameEx\DEMO\MAME\flyers
10:04:58.4 7/31/2015: Cabinet Path is: C:\GameEx\DEMO\MAME\cabinets
10:04:58.4 7/31/2015: Cabinet 3D Path is: C:\GameEx\DEMO\MAME\cabinets3d
10:04:58.4 7/31/2015: Title Path is: C:\GameEx\DEMO\MAME\titles
10:04:58.4 7/31/2015: PCB Path: Not Found
10:04:58.4 7/31/2015: Artwork Preview Path: Not Found
10:04:58.4 7/31/2015: Panel Path is: C:\GameEx\DEMO\MAME\cpanel
10:04:58.4 7/31/2015: Manual Path is: C:\GameEx\DEMO\MAME\manual
10:04:58.4 7/31/2015: Icon Path is: C:\GameEx\DEMO\MAME\icons
10:04:58.4 7/31/2015: Marquee Path is: C:\GameEx\DEMO\MAME\marquees
10:04:58.5 7/31/2015: Applying Language/Text
10:04:58.5 7/31/2015: Text/Language: English
10:04:58.5 7/31/2015: Loading Language/Text
10:04:58.5 7/31/2015: Using Version 3 Themes Animations
10:04:58.5 7/31/2015: Retrieving resolution setting
10:04:58.5 7/31/2015: Using General Font: Trebuchet MS
10:04:58.5 7/31/2015: Using Title Font: Trebuchet MS
10:04:58.5 7/31/2015: GameEx will try to reduce CPU usage
10:04:58.5 7/31/2015: Initialising Direct3D
10:04:58.5 7/31/2015: Closing database connection
10:04:58.5 7/31/2015: Disposing Plugins
10:04:58.5 7/31/2015: GameEx is exiting with errors
10:04:58.6 7/31/2015: ERRORS DETECTED: EXITING
10:04:58.6 7/31/2015: Bye
Hi All,
When I attempt to play some of my mame roms the screen goes blank and then kicks back to the rom list after a few seconds. I took a peak at the log file but wasnt able to come up with much. I am using the intergrated MAME emu. Is this a romset issue? Any ideas? Thanks for any or all help in advance.
Hi again ^_^
Usually in these cases it's because your rom versions don't match your MAME version and so will likely have missing files for those roms to run. You can easily see if this is the case by loading a (troublesome) game with MAME from a command prompt - the command window will tell you if you have files missing.
Another common cause of this behavior is incorrect paths, but we've already established this is not the case for you in your other thread ;) You haven't changed your paths have you?! :P
