Hello everybody,
does somebody know what are the requirements of PinballX? ...and maybe also the requirements of PinballXLite?
I´m asking because I have an issue which has been tracked down to the hardware, but I don´t know exactly which component.
I´ve issued this topic already in another thread and "mace" gave his best to help, but now I´ve heard in another Forum (flippermarkt.de) that another guy has identical problems and therefore I would like to summarize the topic:
- some days ago I´ve installed DOF (I´m using a PinControl1 with a connected RGB-Strip).
- most tables are working fine and even DOF is working
- but there are few tables which show me an error "C:\...\.directb2s" cannot be found..." on launching the table
(in this case the table starts, DOF starts, DMD starts, just the Backglass remains black)
By the way: the table isn´t named in this error message! It only says "\.directb2s" cannot be found! Maybe the name of the table won´t correctly be forwarded?!
This is only if I start the table out of PinballX (after I installed DOF - previously they all worked fine!). If I start the tables directly out of Visual Pinball they also work fine without any error. I will attach a screenshot of my error-message, my DOF-Settings and my PinballX-Settings.
- the used backglasses are *.directb2s files. Names are exactly the same
(If I start the tables directly out of Visual Pinball everything works perfect with current settings).
- before I´ve installed DOF everything was working fine.
- if I start my tables directly out of VP9.9.0 or VP(PM5) everything works fine:
-> Backglass will be loaded, DOF starts, no problems
- if I start my tables out of PinballX (that´s what I used to do): I get an error message (as stated before)
-> DOF starts, Backglass Monitor gets dark, Playfield will be shown with mentioned error
- This happens only with following tables:
a ) Indiana Jones VP920 MOD 2.0 FS (ij_l7)
b ) Indiana Jones MOD 2.5 FS PHYSMOD5_NM (ij_l7)
c ) STTNG_VP990_HD_GI_MOD_1.3_Physmod_FOM (sttng_x7)
d ) Jurassic Park (Data East 1993) UW_LW_dark-Javier_PM5_1.1 (jupk_513)
- those mentioned tables are not all the same VP-Version. The error happens with VP9.9.0 as well as PM5
- I´ve already tried to rename one of my tables to a little easier naming "NightMod.vpt" and "NightMod.directb2s", but this changed nothing.
- I´ve also tried to use a backglass, which is working fine on another table.
But this changes also nothing and will end up in an error message exactly the same way as before with the other BG.
- Taking out the error selection via the Directb2s menu
This helps to prevent the interupting error message.
Table starts and is playable but indeed without the Backglass (so it´s only half way through...).
- Then I tried to use different ROM-files (which changed nothing)
...but by accident I found out that if I load the table in VP (I´ve NOT started it - just loaded),
then I start PinballX and launch one of those tables: everything works perfect.
- It seems to be a Timing issue at any stage, but I don´t know in which Programm/Software/script.
- I found out that if I decrease Graphics Settings in VP, I get STTNG and Jurassic Park running in PinballX.
Seems to be that VP + B2S + PinballX needs too much memory...
Still I don't know exactly what the problem is: RAM, GraphicsRAM, CPU...
My System:
CPU: AMD Phenom II X4 955 Processor (4x 3200 MHz)
RAM: 4 GB (DDR2-1066 Kit)
GPU: MSI - NVIDIA GeForce GTX 960 - 2 GB
OS: Windows 7 - 64bit
Another user´s system with identical issue:
CPU: AMD Athlon II X4 640 4 x 3 GHz
RAM: 4 GB RAM 666 MHz
GPU: AMD Radeon 6670 512MB
Maybe some of you know the requirements or have another idea.
Many thanks in advance!
Kind regards,
Jannek
post-29181-0-83419600-1438067515_thumb.j
DOF.zip
PinballX.zip
Edited by Jannek
Hey there,
an additional Information: it seems that the Problem isn´t the RAM. For testing puposes I´ve added temporarily 2 more GBs of RAM and that changed nothing (I think it got even more worse - I think because 4GBs are 1066MHz and 2GBs are 800MHz).
Kind regards,
Jannek
Hello everybody,
now I´ve encountered this issue also on "Monster Bash" Table...
And at "VPForums.org" there´s another user facing this issue.
So, maybe anyone has new suggestions/ideas/Information?
Many thanks in advance and Kind regards,
Jannek
