well im trying to make this theme work but when i load it up in GameEx it has lots of blue spots but i dont have any blue on the theme .png files
here is a Screenshot of the blue stuff
Does anyone here know what i should do to fix that ?
i found out that files that have some areas that are transparent turn out blue in gameex anyways i just got ride of those areas.
my problem now is parts of my buttons that are black are not showing up in gameex
What program are you using to build the theme? If your using Photoshop, then use the Adjust Brightness slider to make the images so they are brighter than black. Only make the areas you want "keyed out" or transparent pure black.
If your using the Theme Editor, there is "Adjust Colour" in the Object menu. It has a slider you can use to make the image slightly brighter as well.
Is it possible to have different buttons for the left "MENU" and the "LIST"
also is it possible to move the text in the left "MENU"
does anyone KNOW?
Hey Tom if its easy could u some how make it so that u can change the buttons on the left so that its not the same as the list buttons. If its hard i understand
