can anyone help with gens32 surreal 1.67 , i get a black screen
when i try to run this emulator then it goes back to gameEX.
i have been using fusion but its not my emulator of choice
and gens surreal rocks.
another reason for using gens is that fusion seems to
give me (no signal errors) somthing to do with my monitor
but it is definatly a bug in the emulator.
if anyone has surreal working please let me know ..
thanks
  • 4 months later...
thanks
1.69 r2 is out. I'm still having problems with getting roms to launch as well. Anyone had luck?
Okay I haven't really done much testing...but I found I got a black screen when sending the Emu a rom via a shortcut.
How ever I did find that when I renamed the config file from .cfg to .bak to where it needed to generate a new config things worked fine.
Of course first run it will be in a window...and at that point ALT+F4 to exit the app or click the window close title button.
Then manually edit the new *.cfg with at the following values:
[Graphics]
Full Screen=1
Render Fullscreen=1
Save then relaunch the game...should now launch full screen...next slowly start adding in values you where using in your *.bak file into the new *.cfg file till you find what breaks things...then post here what the hell the issue is. ;)
I may look into more dealing with this Emu later...and frankly others that offer NetPlay as that could be very handy in GameEx.
[Graphics]
Full Screen=1
Render Fullscreen=1
Which config file? I'd love to get this one up and running, since it supports everything Sega.
