New user here, have used HyperPin before and decided to check out PinballX. I installed it and went through the setup guide install thing. After that I launch the program and it brings up the screen but when I press a button it just closes the whole application. Attached are the log and ini files. Log mentions "index was outside of the bounds of the array", did a search but only came up with some threads mentioning this with regards to gameex.
PinballX.ini
