Been meaning to write this out for a while now but havent had time
Incase anyone hasnt noticed there are many (possibly all) slingfront app commands which are "hard coded" to particular keyboard keys and cannot be changed. Even if you go into the keyboard config.ini and wipe out all key mappings these hard coded keys will still carry out the app functions.
For example..... try pressing the left alt key and see what happens
Now clear out your keyboard config.ini and run through the keyboard and see what happens
This is a total and utter ball ache for setting up your keyboard commands, particularly if you use a logitech harmony and DONT WANT/USE SLINGFRONT APP COMMANDS but you want to use one of the assigned keys
Please can you fix it so there are no hard coded keys???????
  • 6 months later...
I have remapped as best i can using the slingfron interface and the logitech harmony software. This is very difficult to do though as there are lots of hard coded keys you have to avoid. Its difficult to find vacant keys that fit in with the logitech harmony software and are not one of those hard coded in slingfront
please fix
