Adultery Posted May 17, 2006 Share Posted May 17, 2006 Each time I update GameEx, I have a problem with the config file! Can someone break it down to me so I don't have to change my .ini file each time I update? *lookin in Tom's direction! *Emulators 7&8 get bumped to the bottom of the list and a whole bunch of things are all over the place... It's driving me slightly nuts!Any advice would be helpful! Thanks. Link to comment Share on other sites More sharing options...
Tom Speirs Posted May 17, 2006 Share Posted May 17, 2006 Each time I update GameEx, I have a problem with the config file! Can someone break it down to me so I don't have to change my .ini file each time I update? *lookin in Tom's direction! *Emulators 7&8 get bumped to the bottom of the list and a whole bunch of things are all over the place... It's driving me slightly nuts!Any advice would be helpful! Thanks. I'm generally not supporting manual ini edits anymore. All configuration ideally should be done through the config app.If the configuration app does not do something, or GameEx does not work properly after an update than let me know, but I cant really address the structure changes in gameex.ini, unless something actually gets broken. If you want to manually edit the ini, yourll have to live it with it for now. Sorry. Link to comment Share on other sites More sharing options...
hansolo77 Posted May 18, 2006 Share Posted May 18, 2006 Something you can look into Adultery is removing the write access to the file. If you right click on the file, go to properties and change the attributes to READ-ONLY.. this should prevent anything from re-writing it, or overwriting it, until you uncheck the READ-ONLY option. Hope that helps. Link to comment Share on other sites More sharing options...
Adultery Posted May 18, 2006 Author Share Posted May 18, 2006 Something you can look into Adultery is removing the write access to the file. If you right click on the file, go to properties and change the attributes to READ-ONLY.. this should prevent anything from re-writing it, or overwriting it, until you uncheck the READ-ONLY option. Hope that helps.Good lookin out. Thanks! Link to comment Share on other sites More sharing options...
hansolo77 Posted May 18, 2006 Share Posted May 18, 2006 No problem. I just hope it works for ya. Link to comment Share on other sites More sharing options...
