Is there some trick to getting the old B2S tables to work? Mine work fine in Hyperpin but the backglass stays black in PinballX and then when I exit the table VP crashes. All of my other tables (standard and DirectB2S) are working great. If I could switch to DB2S for these others I would but it doesn't appear they are available.
Sorry if this has been asked before (I'm sure it has) but after reading the setup manual and scouring the forums I couldn't find any clear instructions to point me to what I am doing wrong. I haven't looked at UVP tables (also working in Hyperpin) yet but if there is anything I need to know about that as well it would be prevent me posting in the future.
Thanks in advance for any help, links to posts or otherwise.
I did and it seems the problem there is more about how the table exits (which I'm sure I will need soon) but right now I can't seem to get the B2S backglass to show. I only get a black screen in PinballX even though the table works correctly in Hyperpin.
