Hi,
Can someone tell me the correct way to use the "roms in folders" option in the emulator configs? GameEx does not seem to detect the folders, just games in the rom path.
thanks!
As far as I know, this feature is not yet fully implemented (i.e. working).
Emph
try this :
http://www.gameex.info/forums/index.php?showtopic=1629
its an alternative way and requires alittle work but its a workaround for it :)
Hi, thanks for your reply.
The way I set up Turbografix/PC Engine CD was to use just one path and rename all the track wave files for each game, which was very tedious.
I currently use the bat file system for Sega Saturn SSF, and it works perfectly, but I was trying to avoid the extra work of making up a bat file for each game.
If the "roms in folders" option worked, it would be a really big time saver when setting up these types of games.
as far as i know thats the only way atm that and afcouse use sortcuts but that require work to
sorry i cant be of more help ..
Night
