GameEx has always worked but for some reason, I started getting crashes whenever I start my jukebox. Don't know why, I haven't changed anything and I update whenever Tom makes any changes. Here is what the log says:
21:22:29.3 5/14/2006: 21 Consecutive Exceptions Occured: Exiting
21:22:29.3 5/14/2006: Error in the application.
21:22:29.6 5/14/2006: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
21:22:29.6 5/14/2006: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags)
21:22:29.6 5/14/2006: at GameEx.GameEx.mainform.DrawMenuText(Int32 x, Int32 y, String textstring)
21:22:29.6 5/14/2006: at GameEx.GameEx.mainform.DrawMenuText()
21:22:29.6 5/14/2006: at GameEx.GameEx.mainform.DrawMenuImages()
21:22:29.6 5/14/2006: at GameEx.GameEx.mainform.DisplayFrame()
Anyone, please help me if you can.
hi, can you post the full log. Does this happen ever time or just sometimes?
I will post the whole log when I get home from work today. It happens every time I select Jukebox and it doesn't happen at any other time on any of the other menus. I can't figure out why either because I didn't change anything at all other than upgrade regularly... and since no one else is having this problem, it must be something on my system.
Here is the entire log:
21:00:56.1 5/15/2006: GameEx: Version 6.10: Starting Log
21:00:56.1 5/15/2006: Operating System Platform: Win32NT
21:00:56.1 5/15/2006: Operating System Name: Windows XP
21:00:56.1 5/15/2006: Operating System Version: 5.1.2600
21:00:56.1 5/15/2006: Checking for versions of .net Framework installed
21:00:56.1 5/15/2006: .net Framework 1.1 Installed
21:00:56.1 5/15/2006: Checking Registration
21:00:56.2 5/15/2006: Running Randomize()
21:00:56.2 5/15/2006: Checking for applications to Launch On Startup
21:00:56.2 5/15/2006: Initialising Video/MNG DLL's
21:00:56.2 5/15/2006: Running Misc startup tasks
21:00:56.2 5/15/2006: Setting Menu types
21:00:56.2 5/15/2006: Opening Configuration File
21:00:56.2 5/15/2006: Getting Configuration Values
21:00:56.2 5/15/2006: Using Theme: Talking Bull With Videos
21:00:56.2 5/15/2006: Checking for alternate Image Directory for Theme: Talking Bull With Videos
21:00:56.2 5/15/2006: Launching HideOS.exe
21:00:57.0 5/15/2006: Hiding Taskbar
21:00:57.0 5/15/2006: Is Media Center running?
21:00:57.0 5/15/2006: Check Media Center Exit/Start Mode
21:00:57.0 5/15/2006: Media Center Mode 0
21:00:57.0 5/15/2006: Text/Language: English
21:00:57.0 5/15/2006: Applying Language/Text
21:00:57.1 5/15/2006: Creating Scancodes.txt (List of DirectInput scan codes)
21:00:57.1 5/15/2006: Snap Delay set to: 6
21:00:57.1 5/15/2006: Get other settings
21:00:57.1 5/15/2006: Desktop set to Hide ICONS and set Background to Black
21:00:57.1 5/15/2006: Backing up Registry Wallpaper Settings
21:00:57.1 5/15/2006: Set: Find emulator artwork on best match basis
21:00:57.2 5/15/2006: SlikStik support enabled
21:00:57.2 5/15/2006: Start work for Form
21:00:57.2 5/15/2006: Getting Original Screen Size
21:00:57.2 5/15/2006: Loading ICON
21:00:57.2 5/15/2006: Initializing Component
21:00:57.2 5/15/2006: Initialising Bass Audio Library
21:00:57.3 5/15/2006: Loading default loading screen
21:00:57.4 5/15/2006: Version 2 Theme being used. Loading.
21:00:57.4 5/15/2006: Loading Button Data
21:00:57.4 5/15/2006: Loading Font Data
21:00:57.4 5/15/2006: Loading Layout Data
21:00:57.4 5/15/2006: Loading Taskbar Data
21:00:57.4 5/15/2006: Using 3D Alpha Blended Animations. This could be slow
21:00:57.4 5/15/2006: Using General Font: Tw Cen MT
21:00:57.4 5/15/2006: Using Title Font: Trebuchet MS
21:00:57.4 5/15/2006: Starting GameExtender on: 127.0.0.1:8383
21:00:57.4 5/15/2006: Initialising DirectDraw
21:00:57.5 5/15/2006: Creating DirectDraw Device
21:00:57.5 5/15/2006: Using Device: RADEON 7500 SERIES
21:00:57.6 5/15/2006: Setting Resolution to 800x600 32 bit color
21:00:57.6 5/15/2006: Creating DirectDraw Surfaces
21:00:57.6 5/15/2006: Creating Primary Surface - Full Screen Mode
21:00:57.6 5/15/2006: Creating Back Buffer
21:00:57.6 5/15/2006: Loading graphic surfaces
21:00:57.7 5/15/2006: Creating Surfaces Misc and Dialogs
21:00:57.8 5/15/2006: Creating Surface Volume
21:00:57.8 5/15/2006: Creating Surfaces Arrows
21:00:57.8 5/15/2006: Creating Surfaces GameEXlogo Text
21:00:57.8 5/15/2006: Creating Surfaces Toolbar
21:00:57.8 5/15/2006: Creating Surfaces Backgrounds
21:00:58.7 5/15/2006: Creating Surfaces Toolbar Controls
21:00:58.7 5/15/2006: Creating Surfaces GameEx Logo
21:00:58.7 5/15/2006: Creating Surfaces Home & Exit
21:00:58.8 5/15/2006: Creating Surfaces Snaps
21:00:58.8 5/15/2006: Creating Surfaces Menu and List Bars
21:00:58.8 5/15/2006: Creating Fonts
21:00:58.8 5/15/2006: Creating Menu Font
21:01:00.0 5/15/2006: Creating Game Font
21:01:00.8 5/15/2006: Creating Game Font Standard Size
21:01:01.7 5/15/2006: Creating Font Black
21:01:01.8 5/15/2006: Creating Font Black Small
21:01:01.9 5/15/2006: Creating Game Font Faded
21:01:02.7 5/15/2006: Creating Title Font
21:01:04.2 5/15/2006: Creating Control Panel Font
21:01:05.1 5/15/2006: Fonts Created Succesfully
21:01:05.1 5/15/2006: Initialising Windows Media Player Component
21:01:05.1 5/15/2006: MAME Path is: E:\Mame32
21:01:05.1 5/15/2006: daphne Path is: D:\DAPHNE
21:01:05.1 5/15/2006: daphne EXE file is: Daphne.exe
21:01:05.1 5/15/2006: Use daphne on. Daphne.exe will launch games
21:01:05.2 5/15/2006: ZiNc Path is: E:\ZINC
21:01:05.2 5/15/2006: ZiNc EXE file is: zinc.exe
21:01:05.2 5/15/2006: Use ZiNc on. zinc.exe will launch PSX games
21:01:05.2 5/15/2006: MAME EXE file is: mame32.exe
21:01:05.2 5/15/2006: ROM Path is: D:\MAME
21:01:05.2 5/15/2006: Catver.ini is located at: D:\Data\catver.ini
21:01:05.2 5/15/2006: controls.ini is located at: D:\Data\controls.ini
21:01:05.2 5/15/2006: History.dat is located at: D:\Data\history.dat
21:01:05.2 5/15/2006: nplayers.ini is located at: D:\Data\nplayers.ini
21:01:05.2 5/15/2006: MAMEinfo.dat is located at: D:\Data\mameinfo.dat
21:01:05.2 5/15/2006: Loading Controls.ini map file
21:01:05.2 5/15/2006: Loading Custom Emulators
21:01:05.2 5/15/2006: Loading Emulator 1: Nintendo 64 Games
21:01:05.2 5/15/2006: Loading OfflineList Dat File for emulator: 1
21:01:05.2 5/15/2006: Cannot Find Offline List Dat File
21:01:05.2 5/15/2006: Loading Emulator 2: Nintendo SNES games
21:01:05.2 5/15/2006: Loading OfflineList Dat File for emulator: 2
21:01:05.3 5/15/2006: Loading Emulator 3: GameBoy & GameBoy Color
21:01:05.3 5/15/2006: Loading Emulator 4: Nintendo NES Games
21:01:05.4 5/15/2006: Loading Emulator 5: Atari 2600 Games
21:01:05.4 5/15/2006: Loading Emulator 6: Sega Genesis
21:01:05.5 5/15/2006: Loading Emulator 7: PCEngine Turbo Grafx 16
21:01:05.5 5/15/2006: Loading Emulator 8: Gameboy Advance
21:01:05.6 5/15/2006: Loading Emulator 9: Atari Lynx
21:01:05.6 5/15/2006: Loading Emulator 10: Sega Master System
21:01:05.7 5/15/2006: Loading Emulator 11: Intellivision
21:01:05.7 5/15/2006: Loading Emulator 12: Colecovision
21:01:06.1 5/15/2006: Snap Path is: E:\Mame32Plus\snap
21:01:06.1 5/15/2006: AVI Snap Path is: E:\Mame32Plus\Videos
21:01:06.1 5/15/2006: Flyer Path is: E:\Mame32Plus\flyers
21:01:06.1 5/15/2006: Cabinet Path is: E:\Mame32Plus\cabinets
21:01:06.1 5/15/2006: Title Path is: E:\titles99
21:01:06.1 5/15/2006: Panel Path is: E:\Mame32Plus\cpanel
21:01:06.1 5/15/2006: Icon Path is: D:\Icons
21:01:06.1 5/15/2006: Marquee Path is: E:\Mame32Plus\marquees
21:01:06.1 5/15/2006: MAME CMD options: -triplebuffer -nowindow -joy
21:01:06.1 5/15/2006: Attempting to load game list
21:01:06.4 5/15/2006: Loading last used Game List
21:01:06.5 5/15/2006: Loading Start Page
21:01:06.5 5/15/2006: Setting Music Volume
21:01:06.5 5/15/2006: Creating DirectSound Device
21:01:06.5 5/15/2006: Trying: Primary Sound Driver
21:01:06.5 5/15/2006: Loading Sound Files
21:01:06.6 5/15/2006: DirectSound Device Created Successfully
21:01:06.6 5/15/2006: Creating ICONS
21:01:06.6 5/15/2006: Restoring Cached ICONS from File
21:01:07.5 5/15/2006: Gamepad/Joystick disabled
21:01:07.5 5/15/2006: Initialising DirectInput for Keyboard support
21:01:07.5 5/15/2006: Playing Startup Video
21:01:08.8 5/15/2006: Initializing MCE Remote
21:01:08.8 5/15/2006: Initialization OK! Starting GameEx!
21:01:08.9 5/15/2006: Testing Main Loop Once: Processing Frame
21:01:09.3 5/15/2006: Testing Main Loop Once: Main Loop ran successfully
21:01:14.3 5/15/2006: 21 Consecutive Exceptions Occured: Exiting
21:01:14.3 5/15/2006: Error in the application.
21:01:14.6 5/15/2006: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
21:01:14.6 5/15/2006: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags)
21:01:14.6 5/15/2006: at GameEx.GameEx.mainform.DrawMenuText(Int32 x, Int32 y, String textstring)
21:01:14.6 5/15/2006: at GameEx.GameEx.mainform.DrawMenuText()
21:01:14.6 5/15/2006: at GameEx.GameEx.mainform.DrawMenuImages()
21:01:14.6 5/15/2006: at GameEx.GameEx.mainform.DisplayFrame()
Anyone have any ideas?
OK, I tried it on a different theme and it worked with no problems...I don't understand though. It used to work on that theme.
I think the issue is the position of the menus/info. When loading the jukebox its going outside the bounds of the bottom of the screen. Try moving it up some in the editor.
It probably used to work because there was a bug that was fixed where the resolution was not set when loading a v2 theme if you had gameex set not to change resolution.
Cheers.
