Can't exit if esc disabled and flat menu with start menu not first
Hi Tom, Here's kind of a strange thing. On my daughter's cab, because there are only 62 games, I disabled everything so there is only the original mame games category. Now, if I also disable the start menu as always being first, gameex will come up in the mame games list which is what I want but there's no going back to the start menu because there's no page to go back to since you didn't come from the start menu (since gameex back behavior is like a browser's). Also, since I disabled the escape key so my daughter wouldn't accidentally exit gamex, I cannot quit gameex or shutdown the cab without doing ctrl+alt+del. The only option I have enabled as far as exiting goes is the shut down the machine. Is there any way you can make that available from the game lists if start menu is disabled? I know it makes GameEx into a one page, simple, simple interface but that's what I am looking for on this cab. Pretty much reminiscent of GameLauncher. A list of games and shut down.
Thanks Again!
Erik
Any chance of this being addressed? It only happens if you don't have GameEx start with the Start page which kida looks funny with only Mame and Shutdown as the options.
Pressing both shift keys. e.g CTRL-ALT should load the start page. Of course then the MAME list wont be the last page.
Sorry, don't plan on addressing it any other way for just now (probably will happen eventually though). Too much other stuff to do.
Thanks.
Tom
just an idea get a keyboard with a shut down button on it or a logitech keyboard that you can bind keys on you could use a shutdown command line
