I have noticed that PinballX is not sowing the correct wheel logos for some of the tables. For instance I have a table called HULK and another called The Incredible Hulk which I have given different logos to how ever they both show the same logo. The same happens for Heavy Metal and Heavy Metal Meltdown, two different Harley Davison tables as well as three Playboy tables which not only the logos get mixed up but even the back glass image, table image and actually loading the wrong tables for those three. I have tried to change the names in the description, the file name, and even changed the logos and images but they always go back to the logo or image of the other one. They all have distinctly different names so I have no idea why this would happen. I would really appreciate any help with this.
Thanks.
Try turning "Enable File Matching" to "No" in the PBX settings and naming your wheel logos the same as your tables.
In fact, save yourself a ton of work later when you have a lot of table...name all your artwork (tables images/videos, BG images videos, wheel images, etc) the same as your table name. (section 4-11 to 4-12 in the user guide)
Z
Thanks, that worked! And I already have about 170 tables installed thats when all this started to happen, it was fine untill the list got larger. I also noticed that some long file names in the description and under scores tend to do some strange things where the logo, back glass and table image dont show up. I did get it all sorted out now and Im so glad because Im not too fond of HyperPin which I would have had to end up using. Thanks again zeenon.
