Is this possible on gameex? running 2 emulators and roms
Outside of Gameex you get this when you link. Not a major thing just putting it out there :)
I didn't even know this was possible... Too bad I can't link Mario Golf to GBA like that!
Yeah this is pretty fantastic; I was not aware of this either. Thanks for sharing!
As for GameEx I'd have to investigate how it works in Dolphin. I think the critical part is whether or not the two emulators can be linked using purely command line directives (or at least that would be the coolest way - alternately you might be able to use an AHK script to automate it, but the level of effort would rise considerably). Other than that I don't see why it couldn't' work. I assume that this would always be the same ROM on Dolphin, and a various assortment on VBA-M? You could leverage the Launch Before parameter to launch one or the other (you can use the [ROMFILE] in either your emulator command or your Launch Before command depending the order that the emulators need to launched).
Alternately you could write a batch launcher that would take in a parameter for the ROM path of the game you wanted to play.
Just spit balling ideas. I think it would be possible, but would likely require some creativity to pull off.
