[RESOLVED] Crash - Index was out of range
***Edit: I re-downloaded the table and changed the ROM to 109b from 109c that I was using before and I can no longer recreate the issue. So for now it seems to be resolved though I'm not sure what I actually did to fix it. ***
This example is Medieval Madness (Physmod, Nightmod), The first time I hit the Castle I get the error.
Table plays fine if not launched through PinballX.
I read somewhere on this forum I should not run the DB2S in "EXE Mode" so I switched that off, no difference.
Error is:
Line 70:
Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: Index
Line 70 reads:
Controller.B2SSetData dofevent, 1:Controller.B2SSetData dofevent, 0
Log and ini are attached
Thanks!
PinballX.ini
