I posted this over in a slingfront thread on the kodi forums but I think that thread gets as much traffic as this one probably will. Let's hope someone sees this and can guide me. Here goes:
I have a Windows box and kodi 14 installed on it as well as slingfront. I'm sure it's me being blind but i can't find the add-on anywhere in kodi. I can't find it under programs or video. Anyone know the exact directory to find it?
I know Tom said it auto loads into xbmc but I just can't find it.
Slingfront from the desktop and sling.com work great. Just need this last piece to finish my setup. Thanks for any help anyone can give me.
Peja
Well I think it has something to do with it being a newer version of XBMC which is Kodi. I had an older install of XBMC on a different computer and the add-on was within the programs section like it should be.
So I assume this is something to do with the directory it is placing that install file in. I will keep playing with it and see if I can get it to play nice. Thanks.
Another update:
I got it figured out. I just needed to find the addon in the XBMC directory slingfront created and install it into the Kodi directory. Everything works now, with exception of when I exit the program hangs Kodi up and just says "working".
So there is a bug in there somewhere, just not sure where.
Thanks.
  • 1 year later...
