Buzzin69 Posted January 23, 2015 Share Posted January 23, 2015 Hey all, Does anyone know if there is a way to have MAME auto change displays? To be exact, I have a Pinball style arcade (Vertical Display and a Horizontal Display). I am now running MAME on the (Playfield) Vertical Display and would like to know if there is a way to have MAME run Vert games on Display 1 and Hor. games on display 2. To make it even more interesting.... I DO NOT want to run all roms on BOTH screens, I would like the unused screen to stay black.Any ideas????Thanks in advance.P.S. If you look at the cabinet in my Signature you will understand more clearly what I am striving to do. Link to comment Share on other sites More sharing options...
B2K24 Posted January 23, 2015 Share Posted January 23, 2015 In case you didn't know, PinballX has MAME support so you could run all the MAME vertical games on your playfield display using PinballXhttp://www.gameex.info/forums/topic/15343-upload-all-650-vertical-games-parents-only-mamexml/Then just somehow setup GameEX for the horizontal games on your other display.You could make a copy of your MAME folder (not ROMs or CHDs) and have PinballX pointed to 1 location and GameEX use the copy that you've made.Then you can utilize these options to make it do what you wantPer-window options-------------------screen <display>-screen0 <display>-screen1 <display>-screen2 <display>-screen3 <display> Specifies which physical monitor on your system you wish to have each window use by default. In order to use multiple windows, you must have increased the value of the -numscreens option. The name of each display in your system can be determined by running MAME with the -verbose option. The display names are typically in the format of: \\.\DISPLAYn, where 'n' is a number from 1 to the number of connected monitors. The default value for these options is 'auto', which means that the first window is placed on the first display, the second window on the second display, etc. The -screen0, -screen1, -screen2, -screen3 parameters apply to the specific window. The -screen parameter applies to all windows. The window-specific options override values from the all window option.-aspect <width:height> / -screen_aspect <num:den>-aspect0 <width:height>-aspect1 <width:height>-aspect2 <width:height>-aspect3 <width:height> Specifies the physical aspect ratio of the physical monitor for each window. In order to use multiple windows, you must have increased the value of the -numscreens option. The physical aspect ratio can be determined by measuring the width and height of the visible screen image and specifying them separated by a colon. The default value for these options is 'auto', which means that MAME assumes the aspect ratio is proportional to the number of pixels in the desktop video mode for each monitor. The -aspect0, -aspect1, -aspect2, -aspect3 parameters apply to the specific window. The -aspect parameter applies to all windows. The window-specific options override values from the all window option.-resolution <widthxheight[@refresh]> / -r <widthxheight[@refresh]>-resolution0 <widthxheight[@refresh]> / -r0 <widthxheight[@refresh]>-resolution1 <widthxheight[@refresh]> / -r1 <widthxheight[@refresh]>-resolution2 <widthxheight[@refresh]> / -r2 <widthxheight[@refresh]>-resolution3 <widthxheight[@refresh]> / -r3 <widthxheight[@refresh]> Specifies an exact resolution to run in. In full screen mode, MAME will try to use the specific resolution you request. The width and height are required; the refresh rate is optional. If omitted or set to 0, MAME will determine the mode auomatically. For example, -resolution 640x480 will force 640x480 resolution, but MAME is free to choose the refresh rate. Similarly, -resolution 0x0@60 will force a 60Hz refresh rate, but allows MAME to choose the resolution. The string "auto" is also supported, and is equivalent to 0x0@0. In window mode, this resolution is used as a maximum size for the window. This option requires the -switchres option as well in order to actually enable resolution switching with -video ddraw or -video d3d. The default value for these options is 'auto'. The -resolution0, -resolution1, -resolution2, -resolution3 parameters apply to the specific window. The -resolution parameter applies to all windows. The window-specific options override values from the all window option.-view <viewname>-view0 <viewname>-view1 <viewname>-view2 <viewname>-view3 <viewname> Specifies the initial view setting for each window. The <viewname> does not need to be a perfect match; rather, it will select the first view whose name matches all the characters specified by <viewname>. For example, -view native will match the "Native (15:14)" view even though it is not a perfect match. The value 'auto' is also supported, and requests that MAME perform a default selection. The default value for these options is 'auto'. The -view0, -view1, -view2, -view3 parameters apply to the specific window. The -view parameter applies to all windows. The window-specific options override values from the all window option. 2 Link to comment Share on other sites More sharing options...
Buzzin69 Posted January 23, 2015 Author Share Posted January 23, 2015 Great idea B2K24, and something to ponder...... I will look into it over the weekend Just realized... Mame in PinballX would be a bit of a drag to others using the Cade (they are mostly kids of friends and whatnot). I will have to tinker some more, or figure a way to hack the MAME.ini I think. Link to comment Share on other sites More sharing options...
u-man Posted January 23, 2015 Share Posted January 23, 2015 You dont need to "hack" the mame.ini . You can use a horizontal.ini and a vertical.ini and make so changes to them, that it fits to your configuration i.e. telling which screen is used based on orientation of the games.... easy as that .For your info (sadly i dont know where the horizontal.ini / vertical.ini order belongs, but I am sure that they will override the mame.ini):All settings defined in the mame.ini file, are global settings. These settings are the first, that are read by MAME. However other .ini files can overwrite those settings.MAME reads the following .ini files in order:- mame.ini- debug.ini (if the debugger is enabled)- vector.ini (for vector games only)- <driver>.ini (based on the source filename of the driver)- <parent>.ini (for clones only, may be called recursively)- <gamename>.ini 4 Link to comment Share on other sites More sharing options...
Buzzin69 Posted January 23, 2015 Author Share Posted January 23, 2015 Thatsound like EXACTLY what i need to do! Thanks u-man 😄. I guess i know what I'm doing this weekend lol Link to comment Share on other sites More sharing options...
B2K24 Posted January 23, 2015 Share Posted January 23, 2015 You dont need to "hack" the mame.ini . You can use a horizontal.ini and a vertical.ini and make so changes to them, that it fits to your configuration i.e. telling which screen is used based on orientation of the games.... easy as that .For your info (sadly i dont know where the horizontal.ini / vertical.ini order belongs, but I am sure that they will override the mame.ini):All settings defined in the mame.ini file, are global settings. These settings are the first, that are read by MAME. However other .ini files can overwrite those settings.MAME reads the following .ini files in order:- mame.ini- debug.ini (if the debugger is enabled)- vector.ini (for vector games only)- <driver>.ini (based on the source filename of the driver)- <parent>.ini (for clones only, may be called recursively)- <gamename>.iniThis is 100% true and very good information.If you put your mame.ini in the ini directory and rename it to vertical.ini, you can even intentionally change the rompath to something totally incorrect. Then when you launch a vertical game you will get the error files are missing even though the correct path is in your mame.iniSo think of it as a 100% override 1 Link to comment Share on other sites More sharing options...
Buzzin69 Posted January 23, 2015 Author Share Posted January 23, 2015 God I LOVE this site!!!!! You guys are amazing. I set up the .ini (Copied the mame.ini and edited out all that didn't matter. Saved as Vertical.ini). Then went into Mameui64 and set my prefs for Horizontal and BAM! works like a charm.Thanks for the help guys! I am a happy gamer 2 Link to comment Share on other sites More sharing options...
