mpad Posted January 11, 2015 Posted January 11, 2015 hello, after having spent several our getting my exit emulator to work with nukelauncher (with no success so far) I cam tho the conclusion that the xppadder plugin is not working at all times.it seems to work for pinball arcade, but not for fx2 and VP.help.
Adultery Posted January 11, 2015 Posted January 11, 2015 I would need a log at least...This plugin probably needs a pretty hefty update tbh. Most if not all of my attention is focused on GameEx.More importantly I don't provide support for Nuke Launcher since it's a 3rd party add-in so if its something specific to that I won't be able to fix it.
mpad Posted January 11, 2015 Author Posted January 11, 2015 hi, which log you need?are threre any settings that have to be made in xpadder for your plugin? disable autostart or sth?at least I have pinballx nukelauncher etc. now working with the xpadder standard autoprofil function.what exactly is the advantage of your plugin over this feature (if I only need one profile per software)?log.txtxpadder.log.txtsettings.xml
Adultery Posted January 11, 2015 Posted January 11, 2015 I couldn't tell you, I don't know anything about nukelauncher and don't know a lot about pinball emulators.The plugin is widely used for GameEx because there are game specific profiles, the launch is cleaner, and there are more advanced features available.The obvious advantage in your case is that you can launch a profile cleanly per system and close it after when you aren't using it without using any kind of launch with commands.I haven't updated the PinballX plugin in some time mainly because of the lack of feedback and lack of test users.
mpad Posted January 11, 2015 Author Posted January 11, 2015 ok, thanks for the info and thanks for providing the plugin at first place!!!It did work a couple of times but suddenly not, or only for one of the programs, no idea what caused it.I don't think it has anything to do with the emulator software or nukelauncher, as xpadder should work independently.maybe it doesn't get the right info which system pinballX is calling, so it doesn't change the profile?I am fine with the built in profile changer of xpadder atm, but if you ever feel the need to update it I will gladly test again.thanksp.s. just noticed the headline "party"? lol, should have been partlyparty on...
Adultery Posted January 11, 2015 Posted January 11, 2015 I may take you up on that actually, I've been wanting to update the core and add table specific options for a bit.If you wanted to test some new integrations in a beta branch, i would really appreciate that.
mpad Posted January 12, 2015 Author Posted January 12, 2015 Yes sure, but I won't have much time during the week as holidays are over now. [emoji24]
