Hello tom , im a big fan of your fe , thanks for the good work. Iwas just wondering it this is a bug...
I want to use gameex for my fe on my cabinet, i build this cab based on a vertical monitor, but whenever i start gameex in vertical mode, i got to update my gamelist everytime..... its there a way this can be fix? also can we change gameex to rotate the screen from left to right? cus on my monitor the image looks sideways...
thanks for the help and the good work... keep goin...
Hi, Can you confirm you dont get the game list update issue when your cab is running in horizontal mode?
Yes, I do plan to add support for rotating the other way, but not right away. There is a way to reverse this physically on your cab by changing the wiring, but I don't have any details on it.
Thanks,
Tom
Thanks,
Tom
thanks for the fast reply... yes i dont have the same issue whe i run gameex in horisontal mode, i close gameex start'it again and the gamelist is there, but in vertical mode i have to update the list everytime i open gameex.....im using 5.99.... thanks again
I couldnt duplicate this in the current version. Works a charm for me.
Thanks,
Tom
