Right now, my command line is set to vldp -fullscreen -x 640 -y 480 -nohwaccel to start daphne. is there a way i can add a volume level to set it at because everytime i press the volume increase button on my keyboard it escapes out of the emulator. no other emulator i have does this. i saw something on a daphne wiki site: http://www.daphne-emu.com/mediawiki/index.php/CmdLine
It says -volume_vldp <volume> Sets the volume of the laserdisc audio when using VLDP (max value is 64, 0 means muted). VLDP only. is there a way to set this in the gameex command line along with the other configuration i have above? plz help
Well if that's the case then for those games you can add that command to the "Options" field under your Daphne games that support that command.
Yes or add it to the main Daphne Options command like so:
vldp -fullscreen -x 640 -y 480 -nohwaccel -volume_vldp 64 (or whichever number is reasonable on your machine)
But that would set it across all your games though so per-game would probably be preferable.
The real issue here though is why it is exiting on the volume up keypress? Which key is it and have you altered it from default? It sounds as though it is set the same as, or at least conflicting with GX's process close. A log.ini after you have pressed your volume up while in Daphne might be helpful here ;)
  • 8 months later...
sorry it took so long.......damn.....my apologies here is the log. i did as you said and i hit the volume + key which is the f12 key on the keyboard. i made sure no hotkeys are set to f12. this is during gameplay and i hit the volume key.
--Command line is: Daphne.exe roadblaster vldp -fullscreen -x 640 -y 480 -nohwaccel -framefile C:\Roms\Laserdisc\Road Blaster\roadblaster.txt
--CPU : AuthenticAMD 2900 MHz || Mem : 3072 megs
--OS : Windows NT Derivative || Video : NVIDIA GeForce 9300 GE
Setting screen width to 640
Setting screen height to 480
Set 640x480 at 32 bpp with flags: 80000000
Initializing sound system ...
Joystick #0 was successfully opened
Remapping input ...
Loading compressed ROM image 01.bin...8192 bytes read.
Loading compressed ROM image 00.bin...8192 bytes read.
Loading compressed ROM image 08.bin...8192 bytes read.
Loading compressed ROM image 07.bin...8192 bytes read.
Loading compressed ROM image 06.bin...8192 bytes read.
Loading compressed ROM image 05.bin...8192 bytes read.
Loading compressed ROM image 04.bin...8192 bytes read.
Loading compressed ROM image 03.bin...8192 bytes read.
Framefile parse succeeded. Video/Audio directory is: E:/Roms/Daphne/Road_Blaster/Road Blaster/
YUV overlay is done in software (ie unaccelerated).
Booting ROM ...
MC6850: Master Reset!
MC6850: clock set to x32
MC6850: 8 Bits+1 Stop Bits
MC6850: /RTS=low, Transmitting Interrupt Disabled
MC6850: Recieve Interrupt Enabled
Search to 301 received
NOTE: converting FPS from 29.970000 to 23.976000. This may be less accurate.
Play
Search to 10631 received
Freeing memory used to store audio stream...
Play
Error, bug in move enable
Search to 10687 received
Shutting down sound system...
Shutting down video display...
