boiydiego Posted December 18, 2014 Author Share Posted December 18, 2014 ;-) no tom didnt do that because it always work with no , so oke i will test today fingers crossed and will report back Link to comment Share on other sites More sharing options...
boiydiego Posted December 18, 2014 Author Share Posted December 18, 2014 oke tested NOT fixed , when pbx is on wheel back than futuredmd starts again as soon as futuredmd starts pbx minimizes , other things i can try @tom spiers ??ps:when pbx startsup with futuredmd there is no problem at all with minimizing .. only when exiting from a table vp back to pbx and when futuredmd starts back again.. thx for help tom Link to comment Share on other sites More sharing options...
Tom Speirs Posted December 18, 2014 Share Posted December 18, 2014 Im not sure what the autohotkey command is but you should tell it to run futuredmd.exe but THEN wait for it to exit. Either that or put a sleep command in before exiting the script. Again I am not familiar with AHK but it will have these features.This is not a bug in PinballX. If it worked before it was unintended because of some extra lag returning to the wheel that shouldn't have been there. Link to comment Share on other sites More sharing options...
boiydiego Posted December 19, 2014 Author Share Posted December 19, 2014 cant you test it maybe on your setup at home Link to comment Share on other sites More sharing options...
boiydiego Posted December 19, 2014 Author Share Posted December 19, 2014 what iam going to try is use the pluginmanager from pbx and only use the exe and not the autoscript , can i set also the wait for exit in the pluginmanager ?would that aproch be good/better tom?also it worked Always before but now nothing but SH.Ti saw in pluginmanager i only can set a parameter , can you give me a parameter that does the same as wait for exit ?? Link to comment Share on other sites More sharing options...
nullPointer Posted December 19, 2014 Share Posted December 19, 2014 Hi boiydiegoDid you write that AHK script or was it someone else? If you're the author, it should be completely arbitrary to add a Sleep command or even a WinWait directive (which might be preferable TBH) to your script. If you didn't write the script and the code talk feels intimidating, I would advise you to contact the author of the script. It's your AHK script that's causing problems for PinballX, not the other way around. 1 Link to comment Share on other sites More sharing options...
boiydiego Posted December 19, 2014 Author Share Posted December 19, 2014 remove because double post Link to comment Share on other sites More sharing options...
boiydiego Posted December 19, 2014 Author Share Posted December 19, 2014 i can say this its NOT the script and why i say that because when i deactived the setup i made in setup of pbx and then use pluginmanager , and set a run after command with onlyfuturedmd.exe so than it will NOT use the script also than pbx minimizes try that before (reported in post 22) , but nice you are still trying to help .. keep the pointers coming..THX IN ADVANCE Link to comment Share on other sites More sharing options...
Tom Speirs Posted December 19, 2014 Share Posted December 19, 2014 Here, just for you. Try this.PinballX.zip 1 Link to comment Share on other sites More sharing options...
boiydiego Posted December 21, 2014 Author Share Posted December 21, 2014 thx what is the change in the exe tom ? Link to comment Share on other sites More sharing options...
boiydiego Posted December 21, 2014 Author Share Posted December 21, 2014 @tom spiers THANK YOU for coming thru with a fix , this solves my problem completly , may i now what ws changed in the exe ?big thx and kind regards diego 1 Link to comment Share on other sites More sharing options...
