Hi Tom,
thanks for the 1.92 update.
Are there any settings to configure if Shark codecs or internal Windows codecs should be used ?
Hi Sigma
I don't believe there are any settings to choose what Codecs to use. The codecs are part and parcel of your system itself. So if you install the Shark codecs, PinballX will be using the Shark codecs. In fact everything on your system will be using the Shark codecs (or at least everything that requires media playback). If you uninstall the Shark pack your entire system will revert back to using default codecs. Shark is pretty great about leaving the system exactly how it found it upon uninstalling (and not every codec pack will do this, so it's definitely a nice feature).
The Shark codec pack itself has quite a bit of internal adjustments that you can make, but TBH I've never had issue with the default configuration.
