So with the imarc i/o working I have now tried both blinky and the ledplugin- results?
Well blinky I have programmed and run tests- Great but not working from pinball X. In set up I call it etc but nothing.
With the plugin less than nothing its almost like it cannot see the device. No lights even when testing.
I did unload one why truing the other. Its driving me mad.
On a side note one of the RGB lights shows odd colours under pad64.
Any thoughs
been struggling for days now trying to get my RGB's to work under gameex and pinballx, i'm using the pacled64, am i missing something really simple. the software for pacled64 sees it, so does LEDBlinky put not the ledplugin within gameex. Something weird happened today I left the machine and it went into demo mode, showing a random music video it used the audio animation within ledblinky thought everything sorted when I came out of the demo nothing lit up and could not replicate again.
Just followed the instructions step by step on LEDBLINKY site and it worked first time
just noticed this from the instructions, this is probably the answer to my question even though you said you already tried.
The LEDBlinky plug-in should not be used in conjunction with any other MaLa,
AtomicFE, or GameEx plug-in that controls the listed LED controllers. If you have
installed another LED plug-in, it should be disabled or removed from the plugins folder.
The LEDBlinky plug-in should not be used in conjunction with any native front-end
feature that controls the listed LED controllers. Please disable any MaLa, AtomicFE, or
GameEx LED features.
