hi I am slowly setting up and building an arcade pinball. It's one mountain after another.
Next mountain lighting. I am using future pinball with bam with a ultimarc pac I/o. I have played with led blinky and I wondered what people's thoughts are on solutions.
We have rgb buttons but plan for under lighting and maybe play field lighting.
mmmh ican say you didnt need ledblinky for pinballX there are many in work wait a little bis there comes a big thing.
At moment it gives the LED PLugin go into the plugin manager Activate it and Play ouround with the channels :)
the the problem with the Ultimarc devices and other devices in Futurepinball is futurepinball only Support LEdwiz i have send Shaun an email i hope he can help us !
Here a Sample How it shows in the Future.
the plugin is in the moment a little tricky you mustcreate row for row its the same as led blinky when you use ON 1,2,5,7,8 then the channel goes on at the right side you can put in the waittime in ms for this animation!
