Hi
I got some problems getting started with plugins.
Havent got a clue yet whats going wrong?
As a first step I have installed the function logger plugin, enabled it in the plugin manger and started pinballx. However after I exit Pinballx I cant find any log file or anything similar regarding the function calls.
The log file of PBX also doesnt contain any information regarding plugins apart from a line saying plugins loaded.
I'm running Pinballx in XP 32bit.
Any hints?
Thanks and best regards
Are you looking in the "plugins/function logger" folder? Did you check the PinballX.log to see if the plugin fails to initialize?
There may be a bug if I didn't update the plugin to use the new variables. I can look into this after work.
Ok, finnaly The Function Logger plugin is working :)
I had somehow manage to f...up the config file of PBX. After I deleted the ini and redid the configs everything worked as expected.
Even better, my first experiments building my own plugin have been successful as well. I guess I'll convert the plugin template to C# next, since I feel more comfortable with it.
There should be a c# template in the plugins folder already. :)
