Is it possible to have a default audio file play for a set system? I know you can have a default ambience but what I'd like to have is a background ambience file play globally AND also have a per-system audio file that plays for videos that have no audio designated.
you could put the default audio for each table in the system under audio, where all your table pics and stuff are stored, but you would have to name each file what the table is named.It would take forever if u had a bunch of tables. although there may be a better way I don't know about.
I already know this but it's not what I am after. Currently if you have a file in the ambience folder it will play mixed with the sound encoded in your playfield videos. If you have a video without sound and put an audio file named the same as the table it will play that audio track but will NOT mix the ambience with it. It will in fact cancel out the ambience sound.
