Hi,
Fantastic little front end, my hat is off to you completely bravo
Currently there is a bug whereby the program does not close completely either through "exit" on the interface or alt+f4. The process still runs in the background and i need to close it manually. It is for this reason that focus isnt being restored to XBMC (when i kill the process it jumps back to XBMC)
Can you fix please?
Thanks :D
Hi,
Can you fix please?
Thanks :D
Haven't seen this - what is the name of the process that continues to run, is it the actual SlingFront app or the web plugin?
Slingfront app... whether i run it from XBMC or straight from dektop SlingFront.exe process continues to run on app exit (either via alt+f4 or "exit app")
And if i enter/exit again there will be two SlingFront.exe processes still runnning and so on
post-27603-0-26363400-1411145070_thumb.p
It doesn't reproduce for me, and I've not seen anyone post about this issue before.
If I could reproduce it I'd take a look, but it's not actually my project (I just contributed some tweaks a while back) so you'll likely have to wait and see if anyone else sees this thread.
