[RESOLVED] upgrade to win8.1 and some problems
Ok i had pinballx working great on win7 no issues great program
but i decide to upgrade to win8.1 for some reason
now when i load a vp table from pinballx it goes in window size and i have to exit it with esc to get out of vp to go back to pinballx.
when i run a table from vp outside of pinballx its fullscreen
i did uninstall pinballx and reinstall but same thing
so if anyone can look at my log and config and tell me what im doing wrong i'd appreciated
thanks
Chris
one of the reason i went to win 8.1 as i saw in one of your post that you had no issues running it with everything
when i launch for pinballx vp goes to a window about half of screen and to exit i have to hit esc to exit vp editor then it goes back to pinballx
here's my log file
18:43:35.0 9/13/2014: PinballX - Version 1.87
18:43:35.1 9/13/2014: Windows 8.1 Pro 64-bit (3.9GB)
18:43:35.1 9/13/2014: Loading Settings
18:43:35.2 9/13/2014: Initialize Component
18:43:35.3 9/13/2014: Initialize Display
18:43:35.3 9/13/2014: Loading PlugIns
18:43:35.6 9/13/2014: Created DirectX BackGlass Window
18:43:35.7 9/13/2014: Created DirectX DMD Window
18:43:35.9 9/13/2014: Hiding Cursor
18:43:35.9 9/13/2014: Hiding Taskbar
18:43:35.9 9/13/2014: CPU: Intel® Core i5-4570 CPU @ 3.20GHz
18:43:35.9 9/13/2014: GPU 1: NVIDIA GeForce GTX 750 Ti
18:43:35.9 9/13/2014: GPU 2: NVIDIA GeForce GT 630
18:43:35.9 9/13/2014: Displays: 3
18:43:35.9 9/13/2014: Load Game List
18:43:36.0 9/13/2014: Loading Database: Visual Pinball
18:43:36.0 9/13/2014: Loading Custom Database: Night
18:43:36.0 9/13/2014: Loading Custom Database: Physmod5
18:43:36.0 9/13/2014: Loading Custom Database: Top Tables
18:43:36.0 9/13/2014: Finding and matching artwork and videos
18:43:37.0 9/13/2014: Loading Game Statistics and Scores
18:43:37.1 9/13/2014: Loading Surfaces
18:43:37.4 9/13/2014: Finished Loading Surfaces
18:43:37.4 9/13/2014: Initialize Audio
18:43:37.4 9/13/2014: Set Keyboard Controls
18:43:37.4 9/13/2014: Initialize Joystick
18:43:39.1 9/13/2014: 1 Joystick Attached
18:43:39.1 9/13/2014: Started
18:45:34.2 9/13/2014: Launch System
18:45:34.2 9/13/2014: Waiting for threads
18:45:34.2 9/13/2014: Disposing display
18:45:35.4 9/13/2014: C:\Program Files (x86)\Visual Pinball\VPinball990.exe /play -"C:\Program Files (x86)\Visual Pinball\Tables\Judge Dredd (Williams) (1993) (bmiki75) (HR) (1.0.8).vpt"
18:45:35.4 9/13/2014: C:\PinballX\vpauto.exe
18:45:53.0 9/13/2014: Hidden Visual Pinball Editor Window
18:46:43.0 9/13/2014: Exit System Control Pressed
18:46:54.8 9/13/2014: Error. Exiting
18:46:54.8 9/13/2014: Cannot access a disposed object.
18:46:54.8 9/13/2014: Object name: 'Main'.
18:46:54.9 9/13/2014: at System.Windows.Forms.Control.CreateHandle()
18:46:54.9 9/13/2014: at System.Windows.Forms.Form.CreateHandle()
18:46:54.9 9/13/2014: at System.Windows.Forms.Control.get_Handle()
18:46:54.9 9/13/2014: at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
18:46:54.9 9/13/2014: at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
18:46:54.9 9/13/2014: at System.Windows.Forms.Control.set_Visible(Boolean value)
18:46:54.9 9/13/2014: at PinballX.Main.l()
18:46:54.9 9/13/2014: at PinballX.Main.ai()
18:46:54.9 9/13/2014: at PinballX.Main..ctor()
18:46:54.9 9/13/2014: Disposing Plugins
18:46:54.9 9/13/2014: Showing Taskbar
18:46:55.1 9/13/2014: Unhiding Mouse Cursor
18:46:55.1 9/13/2014: Bye
and config file
[Display]
Monitor=0
rotate=270
Windowed=False
WindowWidth=1920
WindowHeight=1080
WindowX=0
WindowY=65
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ffffa500
[backGlass]
monitor=2
x=0
y=0
width=1920
height=1080
[DMD]
monitor=1
x=0
y=70
width=1280
height=465
[FileSystem]
EnableFileMatching=True
[interface]
DesktopModeEnabled=False
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=True
EnableDefaultFilters=False
[Audio]
StreamVolume=90
SampleVolume=90
PlaySoundInVideos=True
[startup]
playsound=False
playvideo=False
StartWithWindows=Yes
[KeyCodes]
quit=69
left=160
right=161
select=49
rotate=82
pageleft=33
pageright=34
exitemulator=69
ingame=80
screenshot=83
screenshotbackglass=66
instructions=73
volumedown=77
volumeup=78
[JoyCodes]
quit=10
left=0
right=1
select=2
rotate=3
pageleft=4
pageright=5
exitemulator=6
ingame=13
instructions=14
[Text]
Line1=Pinball
Line2=Press Play
[FuturePinball]
Enabled=False
WorkingPath=C:\Games\Future Pinball
TablePath=C:\Games\Future Pinball\Tables
Executable=Future Pinball.exe
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
[VisualPinball]
WorkingPath=C:\Program Files (x86)\Visual Pinball
TablePath=C:\Program Files (x86)\Visual Pinball\Tables
Executable=VPinball990.exe
[ExitScreen]
EnableExit=True
EnableShutdown=True
[startupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=45
MuteAudio=False
[system_1]
Name=Pinball FX2
Enabled=False
WorkingPath=C:\Steam
TablePath=C:\Steam\Tables
Executable=PinballFX.exe
Parameters=
SystemType=0
[system_2]
Name=MAME
Enabled=False
TablePath=C:\
Executable=mamep64.exe
Parameters=[TABLEFILE]
SystemType=0
[AutoExit]
Minutes=15
[Login]
[internal]
lastselected=Attack and Revenge From Mars (Other 2010)Attack & Revenge from Mars (Other) (2010) (JPSalas) (2.3.1)VisualPinball
filter_year=
filter_company=
filter_custom=Top Tables
filtername=Top Tables Tables
[system_3]
Name=Visual Pinball Physmod 5
SystemType=1
Executable=VP_physmod5.exe
[setupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=1
CustomArray=
SearchArray=
SavePosition=False
SectionIndex=4
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=2
ShowPanel=True
FontSize=1
WindowState=0
WindowSize=650,479
WindowLocation=315,120
Still haven't figured this out
Uninstalled pinballx again and reinstalled
I thinks it's a win8 issue going to go back to win7
Every time I load a table from pinballx screen goes black and task bar pops up and then a windowed vp
I have to hit esc to go to vp to quit table then wait 30 sec to get back to pinballx
