I've searched the archives and haven't found a definitive solution to the problem of exiting a table and ending back at the Windows desktop but upon a control alt delete, it shows GameEx is still active.
Like many people have written already, once set up, Vpinmame runs great with the help of vpauto.exe (menus bypassed), but we get shut out of GameEx when exiting.
I've tested this out a bit and noticed a couple things.
About half of my table collection go back to GameEx and the other half go back to the desktop.
Upon further research, I tried creating Snaps of my collection and the offending tables when closing brought up a window saying that "Visual Pinball has encountered a problem" and the standard send error report message followed. I needed to click don't send report or the box would show up as part of my snap. GameEx still continued to switch between tables flawlessly to create the snaps even with the message active.
Since this is a Windows, message, maybe vpauto.exe can't bypass the message? And maybe this message is trying to pop up when vpinmame is terminating, causing a conflict.
Could this be the culprit for this problem?
Like many people have written already, once set up, Vpinmame runs great with the help of vpauto.exe (menus bypassed).
About half of my table collection goes back to GameEx and the other half go back to the desktop.
What version of GameEx are you using, and have you tried turning on map keys?
Are you using the latest version of Visual Pinball? I believe this bug was fixed.
I'm running vers 7
I have mapkeys on. Here's my config.
[Emulator_3]
StartPageName=Pinball Games
TitleText=Pinball
StartPageLogo=pinball
RomFilter=*.vpt
RomsInFolders=False
ROMPath=C:\pinballpack\Visual Pinball\Tables
SnapPath=C:\pinballpack\Visual Pinball\SNAPS
WorkingPath=C:\pinballpack\Visual Pinball\Tables
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
AlsoLaunch=[apppath]\vpauto.exe
ShowDesktop=True
Debug=False
MapFile=
OLDatZip=
Command=..\vpinball -play -"[ROMFILE]"
TitlePath=C:\pinballpack\Visual Pinball\SNAPS
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=Visual Pinball
ExcludedFiles=
CustomBackground=bak.avi
Import=
Export=
DumbyValue=
PlayMusic=
PCGame=
DATABASE=
  • 1 month later...
I just upgraded GameEx to the most current version and am still having similar problems. When I exit a Pinball Table, it goes back to GameEx, but the pinball table is running in the backgroung. I have to exit GameEx and then manually shut down the pinball table. My config is the identical to what's been posted and I've tried all the suggestions that I have found on the forum. Another thing that I noticed is that after updating to the new GameEx version. The Pinball Tables in my favorites are not the same table that plays (i.e. when I select Dolly Parton-yes I play that :P - from the favorites menu, it is a completely different pinball table. I figured I would just remove them and start over, but I thought I would make you aware of it. Thanks.
