gStAv Posted September 11, 2014 Posted September 11, 2014 Hi!This problem is only when I using Physmod5 version of visual pinball in PinballX.When I exit a table with the ESCAPE key, the table have the correct position for the DMDthe next time I fire it up.BUT, when I use the EXIT TABLE from the menu, the dmd_pos_ x and y values in the registrygets altered and the DMD jumps to the upper left corner of my main screen(!)What is the difference between these two exit commands as I would be happy to have the ESC actionto the exit table option aswell...I took a snapshot so you can see the strange values after a "menu exit"Cheers!/Gustav
