Hi.
I want use two displays.
display1 using a browser,
display2 play a GameEx.
When, after start of GameEx,
I click a browser, GameEx hide.
When the GameEx loses focus, screen disappears.
Can this be improved ?
Thanks.
GameEx.ini
You may have to put up with it running in windowed mode. Pres Alt + Enter to toggle between fulscreen and windowed mode in GameEX and maximize the window. Stop gap measure, but it's all I can think of (I'm by no means an expert though).
  • Like 3
I would suggest the same and in fact you can tell GameEx to run fullscreen windowed:
Setup Wizard> Display Settings> Full Screen Windowed = Windowed
REP-Felix
DazzleHP
It solved the problem thanks to your advice.
I set the these configuration.
[Full Screen Windowed] Windowed
very thanks ! :) :) :)
REP-Felix
DazzleHP
You're most welcome :)
Which is VM which is the best to an emulator?
hyper-v ? vm ware ? virtual box ?
I prepared two monitors.
Primary monitor for web browsing,
Secondary monitor for GAME EX use.
However, to execute the emulator with Secondary monitor,
I noticed that It had many problems.
Any emulator can't running on Secondary monitor.
I decided to carry out GAME EX through VM.
Please tell me your recommendation.
I use vbox, but just because it was free and worked better than VPC for me. I don't use it much anymore, just to contain vista when I need to use movie maker (It was better than 7's version). I should really just get good movie making program, preferably free (poor collage student ;) ).
VMWare is my choice. I use it in the field and at home.
RIP-Felix ^_^
Adultery ^_^
Thank for your answer.
I'll use vbox , vmware.
I hope to play DAYTONA USA / GALAXY FORCE etc comfortably.
Thanx.
:D :D :D
