I lost my connection during the night so i booted GameEx to ease the boredom and it kept crashing. It doesn't get to the main screen even - just blanks my screen for a split second then pops the generic Windows message "GameEx has stopped working [Close]". I was baffled by this as i've used GameEx offline many times in the past, but then i remembered the GE Online portion so i disabled it. Same thing. I then realised Adultery's Tagger also needs a connection so disabled it, yet again no dice.
So i wait till my IP get their act together, my connection resumes, i boot GameEx and bang! Working again!
I had to make sure it wasn't coincidence so i deliberately pulled my wi-fi dongle, tried GameEx and it starts crashing again :wacko:
I took a copy of the log both with Online enabled and disabled but they look the same to me:
log_online_enabled.txt
log_online_disabled.txt
It should be noted also that GameExOnlineLog.txt never updates when i have no connection - it only updates when i do.
Hey Dazzle!
My plugins will not initialize if they require a connection to the net and one can't be found, as noted here:
09:43:42.0 15/07/2014: Loaded Plugin:"Game Tagger" Version 1.0.7 By Adultery
09:43:42.1 15/07/2014: PlugIn Did not initialize. Disabling PlugIn
Basically I try to ping DracLabs and if I can't, I just tell GameEx not to initialize the plugin. I hope that helps somewhat. :)
Hey Dazzle!
Not really, as i stated i already tried disabling it and it made no difference ^_^ I can force another log with the Tagger disabled but the results are the same - GE crash :)
EDIT - i see what you're saying now, basically it should make no difference if your plugin is enabled or not? Of course i knew this coz i already tried it ;)
Yeah, for sure. :)
You can try and disable the Hi-Score Snapper plugin too, I'm not sure if I added the code to dispose of that plugin when no connection is found when I added the new online scrape. LMK if it fixes the problem or not. :)
Yup! That's got it :D tried without HS Snapper enabled (i totally forgot that too needs a connection!) and GE ran fine, enabled it again and crash. Disabled it once more for good measure and GE ran fine again :)
Okay, well then I better get on that bug fix. :)
The online check was later in development, so I just forgot to run that check. Should only take a few minutes to fix. Thanks for your help. :)
Chop chop :P
Kidding :ph34r:
And NP, never is ;)
No problem, I was worried for a sec because I saw the code in there for the online check, then when I saw your log I was all like woah... :)
