I know this is more of a project64 question, but I figured there were probably people here that may have had the same problem... When I load Castlevania64 in Project64 via gameex, the game says "Controller1 not connected. Please turn the power off and attach Controller into Socket 1."
Any suggestions?
Any suggestions?
open Project 64 and see if there are any issues with the game, and do other n64 games work ok??
I figured it out... I'm an idiot. When you set up the controllers, there is a drop-down that you can select a memory pack or rumble pack... I had it on rumble instead of memory. Changing that fixed it. Although it makes me wonder, is there no way to have the rumble function along with the memory, at the same time? I guess I'll have to check out the project64 forums...
Thanks for the reply!
~skidrash
