JNES version 0.6 works good for me.
Here is the config I use:
[Emulator_4]
StartPageName=Nintendo NES
TitleText=Nintendo
StartPageLogo=nes
RomFilter=*.zip;*.nes;*.fds
RomsInFolders=False
ROMPath=d:\vnes\Roms
SnapPath=d:\vnes\snap
WorkingPath=d:\JNES
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
AlsoLaunch=
ShowDesktop=True
Debug=False
MapFile=
OLDatZip=
Command=jnes.exe [ROMPath]\[RomFile]
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
DATABASE=NES
ok well jnes is not as good in my book, it didnt allow me to use both right and down while running and shooting in contra, but nestopia is pretty good. when i play nestopia in windows it works well. when i try and load it through gameex, it give me this error
command line parser error, did you forget quotation marks?
anyone know how i can fix this?
Perhaps you need to put quotation marks around your COMMAND line for calling nestopia..
Something like
Command=nestopia.exe "[ROMPath]\[RomFile]"
You may need a switch in there also, some command line parameters need them. The nestopia docs should explain what they are. Let me know how you go, I still havn't decided on what emu to use.
