Riffman81 Posted May 13, 2014 Share Posted May 13, 2014 So I recently learned PCSX2 can have 'per game' settings using a frontend like PCSX2Bonus. Makes things much easier as some PS2 games require different settings in order to get them to run properly. I was thinking of adding one of these frontends to my PCSX2 setup in order to get things to run more fluently within GameEx, eliminating the need to configure emulator settings for games that require a bit of tweaking. I wanted to check and see if anyone is using one of these frontends for PCSX2 within GameEx, and if so, which one? There seem to be several to choose from. Some games, like Final Fight: StreetWise require software mode for proper rendering, while others require Hardware, etc... and various other settings. Having a frontend that can configure settings on a per game basis seems to be the way to go to eliminate some of the hassle when playing. Have any of you guys got one of these to work with GameEx? Link to comment Share on other sites More sharing options...
stigzler Posted May 13, 2014 Share Posted May 13, 2014 Here ya go....http://www.gameex.info/forums/topic/13947-pcsx2-setup-with-individual-games-settings/Tried PCSXBonus as well - preferred PCSXLunchServed me fine so far... 1 Link to comment Share on other sites More sharing options...
Riffman81 Posted May 13, 2014 Author Share Posted May 13, 2014 Thanks Stig! I must have missed this the first time around Link to comment Share on other sites More sharing options...
DazzleHP Posted May 20, 2014 Share Posted May 20, 2014 How did you get on with this Riffman? I've been playing around and got a sweet solution! It'll take some typing so if you're set i'll let you get on with it Link to comment Share on other sites More sharing options...
stigzler Posted May 20, 2014 Share Posted May 20, 2014 I'd be interested in your approach, Dazzler.Whilst PCSXLunch works great - there is only one problem. When you upgrade your version of PCSX2 and plugins - I think you have to re-do all your settings all over again! I'm just wondering if with your method there's a workaround for the above problem.Recognize it'd be a lot of typing, but care to share? Link to comment Share on other sites More sharing options...
DazzleHP Posted May 20, 2014 Share Posted May 20, 2014 Whilst PCSXLunch works great - there is only one problem. When you upgrade your version of PCSX2 and plugins - I think you have to re-do all your settings all over again! I fear it would be the same for PCSX2Bonus (or any such tools) I haven't tried Lunch yet but there is one thing Bonus does that makes GameEx integration soooooo easy - it can create standalone .exe's for each game! So in terms of GameEx setup it is as simple as having these exes in one folder, then it's just "[ROMPATH/ROMFILE]" how cool is that! You can specify which mem card and gamepad config too, so if like me you like teh shmups and the controls are all wrong and unconfigurable, you can configure the pad to your tastes for that one game only. I think i'll be messing with PS2 for a few days yet PS: The mega type was coz i woulda made a mini guide so as to not go through a couple mistakes i made Link to comment Share on other sites More sharing options...
stigzler Posted May 20, 2014 Share Posted May 20, 2014 Ah cheers Dazzle. I checked bonus too - and I think yer right - think would likely have the same problem with that too...Hmmm.. another project to add to the list... Link to comment Share on other sites More sharing options...
