Hi,
I'm still having some trouble trying to get scummvm games to load through gameex using the bat file method. My bats work fine double-clicking in them but don't from gameex. Gameex minimises, but nothing happens and then it comes right back up again.
I'm executing them with this line-
cmd.exe /c [ROMPATH]/[ROMFILE]
I'm not sure if working path is set right, or if that line above is quite right, or a few other options...
Could someone maybe:
Give me an example bat file and how it should work properly with a gameex config.
Thanks!
Jon
Seems I figured it out- the folder where I keep the .bat files had a space in it, removed that, and it works.
Hi,
Thanks!
Jon
