I go to the Snes emulater in GameEx,pick a game from the list and it exits out to desktop with a command prompt box,
C:\ProgramFiles\Zsnesw142>Pause
Press any key to continue.
Well i hit any key and then it goes back into GameEx list of games without ever seeing that game or able to play it.
What am i doing wrong.Please help me,your help is greatly appreciated.
i think you have left debug mode on try turning it off in config
Yep,turned it off now it goes back to desktop(command prompt does not show)then straight back to GameEx,play this game appears again.
Any more ideas.
Thanks.
Looks to me like SNES emulator is not going full screen. You can try turning on ShowDesktop to see what is going on. Or just go into your SNES emulator and make sure it's going to full screen on startup.
Yep,i have tryed everything possible and it has finally given me the SH**TS.
I must have spent the last couple of days trying to set up Project64,Zsnes,Genises,all to no avail.Not being a computer or tech head i just dont know so i will stick with mame as i have it working perfectly and wont waste any more of my (holiday time)or people here in this forum.
Thanks for trying to help the Very Uneducated.
I just don't understand why your having so many problems with setting up Project 64. It was one of the easiest to set up from memory.
I have just booted up my cab and grabbed my config for you.
[Emulator_5]
StartPageName=Nintendo 64
TitleText=N64
StartPageLogo=n64
RomFilter=*.zip;*.rom;*.v64;*.n64
RomsInFolders=False
ROMPath=D:\Games\Project64\roms
SnapPath=D:\Games\Project64\snaps
WorkingPath=D:\Games\Project64
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
AlsoLaunch=
ShowDesktop=False
Debug=False
MapFile=n64x
OLDatZip=C:\Program Files\OfflineList0.7\datas\n64_OL.zip
Command=Project64.exe [ROMPath]\[RomFile]
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
DumbyValue=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
And attached is a picture of the option you should have enabled in Project 64.
Headkaze,thanks for that-it worked like a charm.
You dont happen to have a configuration for zsnes and genesis by any chance that you could post also.
Thanks heaps.
