Hi everyone:
I´m using GameEx and everything went ok since now. I´m trying to configurate Future pinball using your configuration file, but I have a big problem.
I use two PS2 pads on my PC, in order to control GameEx and the games. If I unplug (quit) the pads and load a table using GameEx, everything goes fine and I can play perfectly. But when I load a table with the pads plugged under GameEx, the table loads but I can´t control the game (It seems hanged or something else),
The problem is that this only occurs under GameEx. If I load Future pinball from windows, It recognizes the pads and I can play tables with my PS2 pad perfectly.
Anyone knows how to solve this problem?. Another question...Is it possible to exit from an emulator in GameEx using other different key than "Escape"? (I want to exit from a game using mi pads).
Thanks.
P.D: Sorry if my English is not as good as it must be <_<
