Hello, I've been searching for a FE like this for a long time and I really love it. But I've got a problem and I'm really stuck by now. (I've browsed this forum from beginning to end, I swear)
I'm using MAME 0.105 (command line version) and GameEX 5.88 on a Pentium III 1GHz with an ArcadeVGA. Windows XP SP2.
The problem is that I can't run roms from GameEx using the -hwstretch flag to use my arcade monitor as near to full screen as possible.
Running them from mame in command line gives me full screen.
I tried to put the -hwstretch flag in advanceMAME settings. It doesn't work, but when I edit the "run last game" file I see my -hwstretch flag followed by the resolution flag, and the-nohwstretch flag.
If I remove that -nohwstretch flag and run this it works perfectly.
How could I prevent GameEx to add this flag to the command line?
I worked around this by editing the .ini file for the game (ghouls), but I can't even think of doing this with the whole bunch of .ini files created by the aVGAres utility.
Any idea, please?
Many thanks in advance.
Mopi
Any idea, please?
Mopi
The idea of an ArcadeVGA card is deffinitly not to stretch to games, and have them run at a close or the same resolution to the original game. ie like a real arcade. If you don't want to do this which seems a little strange to me, then just turn off the ArcadeVGA mode in GameEx configuration.
Hi tom, thanks for being there.
I've got everything running in a cabinet with a Hantarex arcade monitor.
I wonder why the next-to-original resolution for the game (ghouls'n ghosts in this case) leaves so much screen unused in an original arcade monitor (two big black bands on the top and bottom).
I bought an ArcadeVGA thinking that it would use as much screen space as possible.
Is there another way to get full screen gaming?
Thanks again
Mopi
Thanks again
Mopi
Theres no other way of doing this with your hardware. You either play the games at a normal ArcadeVGA resolution stretched, not stretched, or a normal windows stretched resolution. If you want more control over the arcadevga resolutions, you can turn off GameEx ArcadeVGA features and use this MAME resolution tool here:
http://mamewah.mameworld.net/downloads.htm
This should allow you to use -hwstrecth with the ArcadeVGA resolutions.
