Latest XP, instant death for GameEx?
Guest b6gm6n
Hi..
Was looking forward to useing this GameEX thing but after downloading (and the mp3) installing...i cannot even run the config or any config...or even gameex, yes framework is installed, anti-v is off etc etc etc... whatever i downloaded as a hotfix maybe from M$ has knackered it... wont even run, theme editor works....erm but nothing else
23:33:15.2  14/04/2006:  GameEx: Version 5.88: Starting Log
23:33:15.2  14/04/2006:  Operating System Platform: Win32NT
23:33:15.2  14/04/2006:  Operating System Name: Windows XP
23:33:15.2  14/04/2006:  Operating System Version: 5.1.2600
23:33:15.2  14/04/2006:  ERROR: An error occured while checking for previous instance of GameEx
23:33:15.2  14/04/2006:  This can be caused by a bad windows or .net framework install.
23:33:15.2  14/04/2006:  GameEx will likely function incorrectly as it cannot check for running processes
23:33:15.2  14/04/2006:  GameEx will now exit with errors
23:33:15.2  14/04/2006:  Application-defined or object-defined error.
23:33:15.2  14/04/2006:  ERRORS DETECTED: EXITING
Only app i have thats doing this, i suppose im stuffed... right
anyone reccommend a good front end?
as i say i installed the latest security updates for windows and hotfixes and this aint gonna work... i'll try .Net2.0...see what happens but i dont hold out much luck...
one of those hot fixes kills it anyways...good luck
-b6
Guest b6gm6n
NET2... Nope! - yeahs it's a windows thing... dunno what.. but i downloaded some recent hotfixes and well...it's death for ole GameEx, if you need any more info i can provide, cheers
-b6
Guest b6gm6n
Cant even open the log viewer... dear me, anyways check the attached, typical error running most exe's in the gameex dir... also im running net1.1, tried fixing the exes using the net config tool but no luck... well thats all i can do for now, i belioeve im never gonna get this to run.... also check for my hotfixes (quite alot, didnt upgrade for ages) , cheers
-b6
-b6
Its nothing to do with recent hot fixes, this problem was reported a long time ago. GameEx even detects this problem, as the error in the log says.
Somehow the way windows or .net is installed or setup, or because of other programs on the system, or disabled services, or missing OS files this issue happens. I stil have no idea why. The only known solution is to rebuild the OS. ie reinstall windows XP, and try again.
If you search the forum you can read up a lot more in it, but theres no known fix.
I'm really sorry, but I don't know of a fix for this, somehow your windows install is messed up, and that's the only information I can give you.
Tom.
Guest b6gm6n
ok i'll un-install... anyways, where did that 93meg sound file go i wonder? it's not in the gameEX dir...y'know the one...upon setup... cannto find it...damn...but anyways thanks for the heads up i'll remember that, cheers
