Hello. I can't seem to find the answer to this anywhere, and I can't fathom that I'm the only one with this issue. I am running Win7 32-bit on an ASUS P5QPL-VM Motherboard. I have a 3 monitor setup for my cabinet:
Sceptre 40" LED TV for playfield - Connected to HDMI on GTX660
Vizio 29" LED TV for backglass - Connected to DVI out on GTX660 converted to HDMI
AOC 19" LED Monitor for DMD - Connected to VGA port on Mobo (Intel GMA 4500)
As shown in "Screen Resolution" in Windows 7 Display Settings
Monitor 1 - 19" AOC - 1024 x 768
Monitor 2 - 40" PF - 1920 x 1080 (Forced as Primary monitor but still considered #2)
Monitor 3 - 29" BG - 1360 x 768
Due to the settings on the mobo, I can't get the GTX660 and the Intel to work together unless I have the system boot with the Intel on the 19" AOC. The BIOS screen and "Loading Windows" screen shows up on the 19" AOC. Once Windows comes up, the primary display moves to the 40" PF.
In PinballX, I have the PF monitor set to Monitor 1 which displays the playfield screenshots just fine. I have tried all combinations of Monitors 2 to 5 for the BG and DMD to show the media images for both with no luck. There were some setting combinations that I saw the BG image on the DMD screen or vice versa (so I know it is seeing the media images), but when I went to swap the monitor numbers in PinballX Settings, both monitors were blank again. Game manager shows that the images are not missing in the media folder. I am using B2S for the games that support it, but while browsing the game list in the frontend, I want the DMD and BG to display when scrolling through the tables. I have the latest 1.77 release (had 1.74 before and hoped 1.77 would help me out). I only have 5 games in the list right now as I'm trying to test the basics before adding more tables to my newly built cab.
Thanks for any help.
I may be able to help, I have virtually the same setup. I use the GTX-660 to run all three monitors. After much researched I've learned it was designed to run three monitors. I use the HDMI on my Playfield, the DVI on the backglass and the VGA on the DMD. It's been running for months with almost no problems other than an Nvidia driver glitch that I've yet to figure out. And in forums, nobody else can figure it out either but it's not a big deal.
I don't know how Win7 32 will work, I'm using Win7 64. I'm running an I-7 so everyone forced me to use the 64bit version because it can utilize the 64bit architecture or something along those lines. I'm not a big computer guy, I just know everyone was adamant about it.
