Heya,
So, I recently sifted through a bunch of SNES/Genesis/NES/Master System roms and narrowed them down to games that were worth keeping. I'd like to now organize these based on if they have multiplayer support, and then further organize them down to whether they're co-op or versus.
I did this with my MAME games a year ago, and I see GameEx supports MAME folders, but does GameEx support folders for the non-mame emulated games?
Edit: Okay, I see GameEx can sort games by Category (by 1-2 players, action, adventure, etc.). Is there a way to make my own category?
Yes you can certainly store your ROMs in subfolders. For your given emulator you would simply want to set the ROM Path as the parent directory which housed all your various ROM sub-directories. Then on the Advanced Emulator Setup screen in the Setup Wizard you would want to change the Scan Sub Folders setting to Yes.
Bear in mind though that GameEx will disregard any sort of "categorization by sub folder". It's possible to do something like that, but it's going to involve a lot more configuration in the form Custom Menus and multiple emulator configuration entries for single emulators. If that's what you're going for, we can get into the steps to pull it off, otherwise the above should have you covered just fine.
This is what I'm looking for (I think). I want to sort them by MAME's idea of a folder (.ini lists or menus or whatever, which GameEx supports, for example, the Favorites Menu) not Explorer's, sorry for the ambiguity.
I'm prepared to get my configure on, so lay it on me :)
Edit: Another thing: On the emulator menus you can sort the games by category. Is there a way to make my own category? This would be preferable.
Erm ... not so much. You cannot currently add your own categories in GameEx and have them display in the categories menu itself.
What I was envisioning is adding "category" selections to the normal emulator menu structure and even then it gets a bit hackish since it requires multiple emulator configuration entries for the same emulator(s). If that's what your after you have a couple of initial options:
  • [Consider this Option A] Under the "parent" ROM directory for your chosen emulator create sub-directories for your chosen categories. Sort your ROMs into those sub-directories. The downside to this technique is that you cannot "cross reference" ROMs across multiple categories. If a given ROM needs to appear in multiple categories you will need to copy that ROM into each of the appropriate sub-directories.
  • [Consider this Option B] Perhaps a better option would be to create map files for each of your chosen categories. That way all your ROMS can still live in a single directory, and you don't run into the whole "cross reference" problem described above. There are several great tools to assist you in the creation of map files, but I find myself most often recommending either Map File Maker or Map File Magician.
  • Now you'll need to create a separate emulator entry for each of your chosen categories. All of them can point at the same Working Path, but you'll want to change the ROM Path to point at the appropriate sub-directory (if you categorized your ROMs by sub-directory). OR you'll want to change each Map File (on the Advanced Emulator Setup screen) setting to point at the corresponding map file (if you categorized your ROMs via map files). Which ever method you chose you can alter the Start Page Name and Title Text settings to be reflective of your categories.
  • So that part gets you so far as a flat menu structure, which depending on your needs might be good enough. Something like this (abbreviated):
    • Sega Genesis [Fighting]
    • Sega Genesis [Platformer]
    • Super Nintendo [Fighting]
    • Super Nintendo [Platformer]
    But ... you might want to get a little fancy and have a tiered menu structure. Say something like this:
    • Sega Genesis
      |- Fighting
      |- Platformer
    • Super Nintendo
      |- Fighting
      |- Platformer
    That's where custom menus are going to become your ally ... and a powerful ally they are. I'm not going to restate here what DazzleHP has already stated much more eloquently and informatively than I can, so if you're willing to go on the journey with Custom Menus then I would direct you to his excellent tutorial.
    Best of luck man!
Thank you for all of the resources! I'll try my hand at those Map files soon.
  • 4 weeks later...
Alright, I've successfully made a map file. I know how to make separate emulator entries from scratch, but is there any way I can just duplicate my existing emulator and just re-name it (Ex: Nintendo NES to Nintendo NES [2-Player])? That would speed up the process immensely.
If you are talking about your emu settings, you can export it to the C:\GameEx\CONFIG\EMULATORS\IMPORT-EXPORT folder with a new name, then import it in the setup wizard.
Thanks, Tempest. Map Magician is awesome by the way.
I now have the map files in the right places, and separate Emulator Entries for All Games/Multiplayer Games. Everything looks exactly as it should within GameEx as well. But, there's one big problem. I can't run any of the multiplayer games from the Multiplayer Emulator Entries.
When I try to open "Balloon Fight" for "NES Allgames" it runs. But when I try to run "Balloon Fight" for "NES Multiplayer" FCEUX tells me "Error opening "C:\Emulators\FCEUX\NES Roms\Balloon Fight (U) [!]"". The only difference between "NES Allgames" and "NES Multiplayer" is the map file.
Since the log doesn't report anything out of the ordinary, I've attached my NES Multiplayer Map File and the NES Multiplayer instance of the Emulator.
2-Player Nintendo NES.zip
Nintendo NES Multiplayer Games.ini
Where are the cache files located?
In case its related to my problem, I ran the new map file without deleting the cache files and got this error message.
14:47:03.1 4/6/2014: Creating instance of global keyboard hook
14:47:03.2 4/6/2014: Running: cmd.exe /c C: fceux.exe "C:\Emulators\FCEUX\NES Roms\Archon (U) [!]"
14:47:03.3 4/6/2014: Shutting down display
14:47:09.4 4/6/2014: Writing Stats
14:47:09.7 4/6/2014: 21 Consecutive Exceptions Occured
14:47:09.8 4/6/2014: Object reference not set to an instance of an object.
14:47:09.8 4/6/2014: at Direct2D.Direct2d.Device.BeginScene(Boolean Clear, Color ClearColour)
14:47:09.8 4/6/2014: at GameEx.GameEx.MainForm.k(Boolean A_0)
14:47:09.8 4/6/2014: at GameEx.GameEx.MainForm.dw()
14:47:09.9 4/6/2014: Trying reinitialising the display after sleeping for 4 seconds
14:47:09.9 4/6/2014: Exception count will be dropped to 15
14:47:38.9 4/6/2014: Running: cmd.exe /c C: fceux.exe "C:\Emulators\FCEUX\NES Roms\Balloon Fight (U) [!]"
14:47:39.0 4/6/2014: Shutting down display
14:47:42.8 4/6/2014: Writing Stats
14:47:43.2 4/6/2014: --**--
14:47:43.2 4/6/2014: 21 Consecutive Exceptions Occured: Exiting
14:47:43.2 4/6/2014: Closing database connection
14:47:43.2 4/6/2014: First Exception:
14:47:43.2 4/6/2014: Index was outside the bounds of the array.
14:47:43.2 4/6/2014: at GameEx.GameEx.MainForm.a(String A_0, Int32 A_1, String A_2, String A_3, String A_4, String A_5, Int32 A_6, Boolean A_7, Boolean A_8, Boolean A_9, Boolean& A_10, Boolean A_11, Boolean A_12)
14:47:43.2 4/6/2014: at GameEx.GameEx.MainForm.b(Int32 A_0, String A_1, Boolean A_2)
14:47:43.2 4/6/2014: at GameEx.GameEx.MainForm.a(DateTime A_0, String A_1, String A_2, Int32 A_3, Boolean A_4, Boolean A_5)
14:47:43.2 4/6/2014: at GameEx.GameEx.MainForm.a(Boolean A_0)
14:47:43.2 4/6/2014: at GameEx.GameEx.MainForm.bl()
14:47:43.3 4/6/2014: at GameEx.GameEx.MainForm.h(Boolean A_0)
14:47:43.3 4/6/2014: at GameEx.GameEx.MainForm.dw()
14:47:43.3 4/6/2014: Last Exception:
14:47:43.3 4/6/2014: Object reference not set to an instance of an object.
14:47:43.3 4/6/2014: at Direct2D.Direct2d.Device.BeginScene(Boolean Clear, Color ClearColour)
14:47:43.3 4/6/2014: at GameEx.GameEx.MainForm.k(Boolean A_0)
Well, I tried
1. deleting all instances of emu_31 in the DATA folder.
2. deleting all instances of emu_31 .cache & .cacheini
3. deleting all instances of emu_31 .cache
Same thing happened every time. GameEx would start flickering when I selected "NES Multiplayer" from the main menu, and then I'd get the same error message.
It's so weird that changing the .map file makes such a difference.
Here's my log from #3.
13:21:58.5 4/7/2014: Opening Configuration File
13:21:58.6 4/7/2014: GameEx: Version 13.25: Starting Log
13:21:58.6 4/7/2014: Operating System Platform: Win32NT
13:21:58.6 4/7/2014: Operating System Name: Windows 7
13:21:58.6 4/7/2014: Operating System Version: 6.1.7601
13:21:58.6 4/7/2014: Aero running
13:21:58.6 4/7/2014: Initializing Vista/Windows 7 volume control
13:21:58.6 4/7/2014: Getting CPU and RAM info
13:21:58.6 4/7/2014: Intel® Core i7-2720QM CPU @ 2.20GHz, 8140MB
13:21:58.7 4/7/2014: 2.19Ghz - 8 Cores or CPU's
13:21:58.7 4/7/2014: Running Randomize()
13:21:58.7 4/7/2014: Loading PlugIns
13:21:58.7 4/7/2014: Checking for applications to Launch On Startup
13:21:58.7 4/7/2014: Setting default net connection limit to 15
13:21:58.7 4/7/2014: Running Misc startup tasks
13:21:58.8 4/7/2014: Setting Menu types
13:21:58.8 4/7/2014: Getting Configuration Values
13:21:58.8 4/7/2014: Using Theme: Red-Blue V4
13:21:58.8 4/7/2014: Checking for alternate Image Directory for Theme: Red-Blue V4
13:21:58.8 4/7/2014: Launching HideOS.exe
13:21:58.8 4/7/2014: Initialising Video/MNG DLL's
13:21:58.8 4/7/2014: Hiding Taskbar
13:21:58.8 4/7/2014: Is Media Center running?
13:21:58.8 4/7/2014: Checking/Creating LCD Registry values
13:21:58.8 4/7/2014: Check Media Center Exit/Start Mode
13:21:58.9 4/7/2014: Media Center Mode 2
13:21:58.9 4/7/2014: Video previews on. Warning: Only recommended on modern systems
13:21:58.9 4/7/2014: Snap Delay set to: 4
13:21:58.9 4/7/2014: Get other settings
13:21:58.9 4/7/2014: Set: Find emulator artwork on best match basis
13:21:58.9 4/7/2014: Start work for Form
13:21:58.9 4/7/2014: Getting Original Screen Size
13:21:58.9 4/7/2014: Opening Database Connection
13:21:59.2 4/7/2014: Initializing Component
13:21:59.3 4/7/2014: MAME Path is: C:\Emulators\MAME
13:21:59.3 4/7/2014: MAME EXE file is: mame64.exe
13:21:59.3 4/7/2014: ROM Path is: C:\Emulators\MAME\roms
13:21:59.3 4/7/2014: Catver.ini is located at: C:\GameEx\DATA\catver.ini
13:21:59.3 4/7/2014: History.dat is located at: C:\GameEx\DATA\history.dat
13:21:59.3 4/7/2014: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
13:21:59.3 4/7/2014: command.dat is located at: C:\GameEx\DATA\command.dat
13:21:59.3 4/7/2014: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
13:21:59.3 4/7/2014: Loading Controls.ini map file
13:21:59.3 4/7/2014: Snap Path is: C:\GameEx\DEMO\MAME\snaps
13:21:59.3 4/7/2014: Database Snap Path: Not Found
13:21:59.3 4/7/2014: Background Snap Path: Not Found
13:21:59.3 4/7/2014: AVI Snap Path is: C:\GameEx\DEMO\MAME\video
13:21:59.3 4/7/2014: Flyer Path is: C:\GameEx\DEMO\MAME\flyers
13:21:59.4 4/7/2014: Cabinet Path is: C:\GameEx\DEMO\MAME\cabinets
13:21:59.4 4/7/2014: Cabinet 3D Path: Not Found
13:21:59.4 4/7/2014: Title Path is: C:\GameEx\DEMO\MAME\titles
13:21:59.4 4/7/2014: PCB Path: Not Found
13:21:59.4 4/7/2014: Artwork Preview Path: Not Found
13:21:59.4 4/7/2014: Panel Path: Not Found
13:21:59.4 4/7/2014: Manual Path is: C:\GameEx\DEMO\MAME\manual
13:21:59.4 4/7/2014: Icon Path: Not Found
13:21:59.4 4/7/2014: Marquee Path is: C:\GameEx\DEMO\MAME\marquees
13:21:59.4 4/7/2014: Applying Language/Text
13:21:59.4 4/7/2014: Text/Language: English
13:21:59.4 4/7/2014: Loading Language/Text
13:21:59.5 4/7/2014: Loading Custom Emulators
13:21:59.5 4/7/2014: Loading Emulator 2: Atari 2600 (Stella)
13:21:59.5 4/7/2014: Loading Emulator 3: Atari 5200 (kat5200)
13:21:59.5 4/7/2014: Loading Emulator 4: Atari 7800 (MESS)
13:21:59.5 4/7/2014: Loading Emulator 5: Coleco Vision (MESS)
13:21:59.5 4/7/2014: Loading Emulator 6: Intellivision (MESS)
13:21:59.6 4/7/2014: Loading Emulator 7: Odyssey 2 (MESS)
13:21:59.6 4/7/2014: Loading Emulator 8: Fairchild Channel F (MESS)
13:21:59.6 4/7/2014: Loading Emulator 9: Super Cassette Vision (MESS)
13:21:59.6 4/7/2014: Loading Emulator 10: SG-1000 (bee)
13:21:59.6 4/7/2014: Loading Emulator 11: Sega Master System (MESS)
13:21:59.6 4/7/2014: Loading Emulator 12: Sega Genesis (MESS)
13:21:59.6 4/7/2014: Loading Emulator 13: Sega CD (Fusion)
13:21:59.6 4/7/2014: Loading Emulator 14: Nintendo NES (FCEUX)
13:21:59.6 4/7/2014: Loading Emulator 15: Nintendo FDS (FCEUX)
13:21:59.6 4/7/2014: Loading Emulator 16: Nintendo SNES (ZSNES)
13:21:59.6 4/7/2014: Loading Emulator 17: TurboGrafx-16 (MESS)
13:21:59.6 4/7/2014: Loading Emulator 18: TurboGrafx-CD (mednafen)
13:21:59.7 4/7/2014: Loading Emulator 19: Atari Lynx (MESS)
13:21:59.7 4/7/2014: Loading Emulator 20: Neo Geo Pocket Color (MESS)
13:21:59.7 4/7/2014: Loading Emulator 21: MSX (blueMSX)
13:21:59.7 4/7/2014: Loading Emulator 22: Vectrex (MESS)
13:21:59.7 4/7/2014: Loading Emulator 23: Watara Super Vision (MESS)
13:21:59.7 4/7/2014: Loading Emulator 31: Nintendo NES [Multiplayer Games]
13:21:59.7 4/7/2014: Loading Emulator 32: Atari 7800 [Multiplayer Games]
13:21:59.7 4/7/2014: Loading Emulator 33: Nintendo FDS [Multiplayer Games]
13:21:59.7 4/7/2014: Loading Emulator 34: Coleco Vision [Multiplayer Games]
13:21:59.7 4/7/2014: Loading Emulator 35: Intellivision [Multiplayer Games]
13:21:59.7 4/7/2014: Loading Emulator 36: Nintendo SNES [Multiplayer Games]
13:21:59.7 4/7/2014: Loading Emulator 37: TurboGrafx-16 [Multiplayer Games]
13:21:59.7 4/7/2014: Loading Emulator 38: Sega Master System [Multiplayer Games]
13:21:59.8 4/7/2014: Loading Emulator 39: Sega Genesis [Multiplayer Games]
13:21:59.8 4/7/2014: Checking if Steam enabled
13:21:59.8 4/7/2014: Steam support is turned off in configuration.
13:21:59.8 4/7/2014: Using Version 3 Themes Animations
13:21:59.8 4/7/2014: Retrieving resolution setting
13:21:59.8 4/7/2014: Using General Font: Trebuchet MS
13:21:59.8 4/7/2014: Using Title Font: Trebuchet MS
13:21:59.8 4/7/2014: GameEx will try to reduce CPU usage
13:21:59.9 4/7/2014: Initialising Direct3D
13:22:00.1 4/7/2014: Setting Resolution to 1366x768 32 bit color
13:22:00.1 4/7/2014: Creating Surfaces
13:22:00.5 4/7/2014: Creating Primary Surface - Full Screen Mode
13:22:00.5 4/7/2014: Creating Back Buffer
13:22:00.5 4/7/2014: Version 2 Theme being used. Loading.
13:22:00.5 4/7/2014: Loading Button Data
13:22:00.5 4/7/2014: Loading Font Data
13:22:00.5 4/7/2014: Loading Layout Data
13:22:00.5 4/7/2014: Loading Taskbar Data
13:22:00.5 4/7/2014: Loading graphic Surfaces
13:22:00.6 4/7/2014: Display is running at: 1366x768 32bit color, 60hz
13:22:00.6 4/7/2014: Adapter: Radeon HD 6770M
13:22:00.6 4/7/2014: Max texture size: 16384x16384
13:22:00.6 4/7/2014: Available texture memory: 714MB
13:22:00.6 4/7/2014: Initialising Bass Audio Library
13:22:00.6 4/7/2014: Creating Surfaces Misc and Dialogs
13:22:00.8 4/7/2014: Creating Surfaces Volume
13:22:00.8 4/7/2014: Creating Surfaces Arrows
13:22:00.9 4/7/2014: Creating Surfaces GameEXlogo Text
13:22:00.9 4/7/2014: Creating Surfaces Toolbar
13:22:00.9 4/7/2014: Creating Surfaces Toolbar Controls
13:22:00.9 4/7/2014: Creating Surfaces Backgrounds
13:22:00.9 4/7/2014: Creating Surfaces GameEx Logo
13:22:00.9 4/7/2014: Creating Surface Unselected
13:22:01.0 4/7/2014: Creating Surfaces Snaps
13:22:01.0 4/7/2014: Creating Surfaces Menu and List Bars
13:22:01.0 4/7/2014: Creating Fonts
13:22:01.1 4/7/2014: Creating Game Font
13:22:01.3 4/7/2014: Creating Game Font Faded
13:22:01.8 4/7/2014: Creating Title Font
13:22:01.8 4/7/2014: Restoring Title Font From Cache
13:22:02.1 4/7/2014: Creating Font Black
13:22:02.2 4/7/2014: Creating Font Black Small
13:22:02.3 4/7/2014: Fonts Created Succesfully
13:22:02.8 4/7/2014: 4MB Video Memory Used
13:22:03.8 4/7/2014: Attempting to load game list
13:22:03.9 4/7/2014: MAME CMD options: -nowindow -joy -skip_gameinfo
13:22:04.2 4/7/2014: Cannot Load Play List. Check Path and filename
13:22:04.2 4/7/2014: Sound Disabled
13:22:04.2 4/7/2014: Initialising DirectInput for Gamepad support
13:22:04.2 4/7/2014: Unable to create a joystick device
13:22:04.2 4/7/2014: Loading Start Page
13:22:04.2 4/7/2014: Initializing MCE Remote
13:22:04.3 4/7/2014: Initialization OK! Starting GameEx!
13:22:04.3 4/7/2014: Testing Main Loop Once: Processing Frame
13:22:04.9 4/7/2014: Testing Main Loop Once: Main Loop ran successfully
13:22:06.4 4/7/2014: Validating: Emulator_2: Snap Path: C:\Emulators\Stella\assets\Atari 2600\Snaps
13:22:06.4 4/7/2014: Validating: Emulator_2: Control Panel Path: C:\Emulators\Stella\assets\Atari 2600\Controls
13:22:06.4 4/7/2014: Validating: Emulator_2: Database: [Console] Atari 2600
13:22:06.4 4/7/2014: Validating: Emulator_2: Title Snap Path: C:\Emulators\Stella\assets\Atari 2600\Titles
13:22:06.4 4/7/2014: Validating: Emulator_2: Box Art Path: C:\Emulators\Stella\assets\Atari 2600\Boxes
13:22:06.4 4/7/2014: Validating: Emulator_2: Cart Art Path: C:\Emulators\Stella\assets\Atari 2600\Cartridges
13:22:06.4 4/7/2014: Validating: Emulator_2: Manual Path: C:\Emulators\Stella\assets\Atari 2600\Manuals
13:22:06.4 4/7/2014: Validating: Emulator_3: Snap Path: C:\Emulators\MESS\assets\Atari 5200\Snaps
13:22:06.4 4/7/2014: Warning: Emulator_3: Snap Path Does not exist
13:22:06.4 4/7/2014: Validating: Emulator_3: Control Panel Path: C:\Emulators\MESS\assets\Atari 5200\Controls
13:22:06.4 4/7/2014: Warning: Emulator_3: Control Panel Path Does not exist
13:22:06.4 4/7/2014: Validating: Emulator_3: Database: [Console] Atari 5200
13:22:06.4 4/7/2014: Validating: Emulator_3: Title Snap Path: C:\Emulators\kat5200\assets\Atari 5200\Titles
13:22:06.4 4/7/2014: Validating: Emulator_3: Box Art Path: C:\Emulators\kat5200\assets\Atari 5200\Boxes
13:22:06.4 4/7/2014: Validating: Emulator_3: Cart Art Path: C:\Emulators\kat5200\assets\Atari 5200\Cartridges
13:22:06.5 4/7/2014: Validating: Emulator_3: Manual Path: C:\Emulators\kat5200\assets\Atari 5200\Manuals
13:22:06.5 4/7/2014: Validating: Emulator_4: Snap Path: C:\Emulators\MESS\assets\Atari 7800\Snaps
13:22:06.5 4/7/2014: Validating: Emulator_4: Control Panel Path: C:\Emulators\MESS\assets\Atari 7800\Controls
13:22:06.5 4/7/2014: Validating: Emulator_4: Database: [Console] Atari 7800
13:22:06.5 4/7/2014: Validating: Emulator_4: Title Snap Path: C:\Emulators\MESS\assets\Atari 7800\Titles
13:22:06.5 4/7/2014: Validating: Emulator_4: Box Art Path: C:\Emulators\MESS\assets\Atari 7800\Boxes
13:22:06.5 4/7/2014: Validating: Emulator_4: Cart Art Path: C:\Emulators\MESS\assets\Atari 7800\Cartridges
13:22:06.5 4/7/2014: Validating: Emulator_4: Manual Path: C:\Emulators\MESS\assets\Atari 7800\Manuals
13:22:06.5 4/7/2014: Validating: Emulator_5: Snap Path: C:\Emulators\MESS\assets\Coleco Vision\Snaps
13:22:06.5 4/7/2014: Validating: Emulator_5: Control Panel Path: C:\Emulators\MESS\assets\Coleco Vision\Controls
13:22:06.5 4/7/2014: Validating: Emulator_5: Database: [Console] Coleco Vision
13:22:06.5 4/7/2014: Validating: Emulator_5: Title Snap Path: C:\Emulators\MESS\assets\Coleco Vision\Titles
13:22:06.5 4/7/2014: Validating: Emulator_5: Box Art Path: C:\Emulators\MESS\assets\Coleco Vision\Boxes
13:22:06.5 4/7/2014: Validating: Emulator_5: Cart Art Path: C:\Emulators\MESS\assets\Coleco Vision\Cartridges
13:22:06.5 4/7/2014: Validating: Emulator_5: Manual Path: C:\Emulators\MESS\assets\Coleco Vision\Manuals
13:22:06.5 4/7/2014: Validating: Emulator_6: Snap Path: C:\Emulators\MESS\assets\Intellivision\Snaps
13:22:06.5 4/7/2014: Validating: Emulator_6: Control Panel Path: C:\Emulators\MESS\assets\Coleco Vision\Controls
13:22:06.5 4/7/2014: Validating: Emulator_6: Database: [Console] Mattel Intellivision
13:22:06.5 4/7/2014: Validating: Emulator_6: Title Snap Path: C:\Emulators\MESS\assets\Intellivision\Titles
13:22:06.5 4/7/2014: Validating: Emulator_6: Box Art Path: C:\Emulators\MESS\assets\Intellivision\Boxes
13:22:06.5 4/7/2014: Validating: Emulator_6: Cart Art Path: C:\Emulators\MESS\assets\Intellivision\Cartridges
13:22:06.5 4/7/2014: Validating: Emulator_6: Manual Path: C:\Emulators\MESS\assets\Intellivision\Manuals
13:22:06.6 4/7/2014: Validating: Emulator_7: Snap Path: C:\Emulators\MESS\assets\Odyssey 2\Snaps
13:22:06.6 4/7/2014: Warning: Emulator_7: Snap Path Does not exist
13:22:06.6 4/7/2014: Validating: Emulator_7: Control Panel Path: C:\Emulators\MESS\assets\Coleco Vision\Controls
13:22:06.6 4/7/2014: Validating: Emulator_7: Database: [Console] Magnavox Odyssey 2
13:22:06.6 4/7/2014: Validating: Emulator_7: Title Snap Path: C:\Emulators\MESS\assets\Odyssey 2\Titles
13:22:06.6 4/7/2014: Warning: Emulator_7: Title Snap Path Does not exist
13:22:06.6 4/7/2014: Validating: Emulator_7: Box Art Path: C:\Emulators\MESS\assets\Odyssey 2\Boxes
13:22:06.6 4/7/2014: Warning: Emulator_7: Box Art Path Does not exist
13:22:06.6 4/7/2014: Validating: Emulator_7: Cart Art Path: C:\Emulators\MESS\assets\Odyssey 2\Cartridges
13:22:06.6 4/7/2014: Warning: Emulator_7: Cart Art Path Does not exist
13:22:06.6 4/7/2014: Validating: Emulator_7: Manual Path: C:\Emulators\MESS\assets\Odyssey 2\Manuals
13:22:06.6 4/7/2014: Warning: Emulator_7: Manual Path Does not exist
13:22:06.6 4/7/2014: Validating: Emulator_8: Snap Path: C:\Emulators\MESS\assets\Fairchild Channel F\Snaps
13:22:06.6 4/7/2014: Validating: Emulator_8: Control Panel Path: C:\Emulators\MESS\assets\Fairchild Channel F\Controls
13:22:06.6 4/7/2014: Validating: Emulator_8: Database: [Console] Fairchild Channel F
13:22:06.6 4/7/2014: Validating: Emulator_8: Title Snap Path: C:\Emulators\MESS\assets\Fairchild Channel F\Titles
13:22:06.6 4/7/2014: Validating: Emulator_8: Box Art Path: C:\Emulators\MESS\assets\Fairchild Channel F\Boxes
13:22:06.6 4/7/2014: Validating: Emulator_8: Cart Art Path: C:\Emulators\MESS\assets\Fairchild Channel F\Cartridges
13:22:06.6 4/7/2014: Validating: Emulator_8: Manual Path: C:\Emulators\MESS\assets\Fairchild Channel F\Manuals
13:22:06.6 4/7/2014: Validating: Emulator_9: Snap Path: C:\Emulators\MESS\assets\Super Cassette Vision\Snaps
13:22:06.6 4/7/2014: Warning: Emulator_9: Snap Path Does not exist
13:22:06.7 4/7/2014: Validating: Emulator_9: Control Panel Path: C:\Emulators\MESS\assets\Super Cassette Vision\Controls
13:22:06.7 4/7/2014: Warning: Emulator_9: Control Panel Path Does not exist
13:22:06.7 4/7/2014: Validating: Emulator_9: Database: [Console] Epoch Super Cassette Vision
13:22:06.7 4/7/2014: Validating: Emulator_9: Title Snap Path: C:\Emulators\MESS\assets\Super Cassette Vision\Snaps
13:22:06.7 4/7/2014: Warning: Emulator_9: Title Snap Path Does not exist
13:22:06.7 4/7/2014: Validating: Emulator_9: Box Art Path: C:\Emulators\MESS\assets\Super Cassette Vision\Snaps
13:22:06.7 4/7/2014: Warning: Emulator_9: Box Art Path Does not exist
13:22:06.7 4/7/2014: Validating: Emulator_9: Cart Art Path: C:\Emulators\MESS\assets\Super Cassette Vision\Snaps
13:22:06.7 4/7/2014: Warning: Emulator_9: Cart Art Path Does not exist
13:22:06.7 4/7/2014: Validating: Emulator_9: Manual Path: C:\Emulators\MESS\assets\Super Cassette Vision\Snaps
13:22:06.7 4/7/2014: Warning: Emulator_9: Manual Path Does not exist
13:22:06.7 4/7/2014: Validating: Emulator_10: Snap Path: C:\Emulators\bee\assets\SG-1000\Snaps
13:22:06.7 4/7/2014: Warning: Emulator_10: Snap Path Does not exist
13:22:06.7 4/7/2014: Validating: Emulator_10: Control Panel Path: C:\Emulators\bee\assets\Controls
13:22:06.7 4/7/2014: Warning: Emulator_10: Control Panel Path Does not exist
13:22:06.7 4/7/2014: Validating: Emulator_10: Database: [Console] Sega SG-1000
13:22:06.7 4/7/2014: Validating: Emulator_10: Title Snap Path: C:\Emulators\bee\assets\SG-1000\Titles
13:22:06.7 4/7/2014: Warning: Emulator_10: Title Snap Path Does not exist
13:22:06.7 4/7/2014: Validating: Emulator_10: Box Art Path: C:\Emulators\bee\assets\SG-1000\Boxes
13:22:06.7 4/7/2014: Warning: Emulator_10: Box Art Path Does not exist
13:22:06.7 4/7/2014: Validating: Emulator_10: Cart Art Path: C:\Emulators\bee\assets\SG-1000\Cartridges
13:22:06.7 4/7/2014: Warning: Emulator_10: Cart Art Path Does not exist
13:22:06.8 4/7/2014: Validating: Emulator_10: Manual Path: C:\Emulators\bee\assets\SG-1000\Manuals
13:22:06.8 4/7/2014: Warning: Emulator_10: Manual Path Does not exist
13:22:06.8 4/7/2014: Validating: Emulator_11: Snap Path: C:\Emulators\MESS\assets\Sega Master System\Snaps
13:22:06.8 4/7/2014: Validating: Emulator_11: Control Panel Path: C:\Emulators\MESS\assets\Sega Master System\Controls
13:22:06.8 4/7/2014: Validating: Emulator_11: Database: [Console] Sega Master System
13:22:06.8 4/7/2014: Validating: Emulator_11: Title Snap Path: C:\Emulators\MESS\assets\Sega Master System\Titles
13:22:06.8 4/7/2014: Validating: Emulator_11: Box Art Path: C:\Emulators\MESS\assets\Sega Master System\Boxes
13:22:06.8 4/7/2014: Validating: Emulator_11: Cart Art Path: C:\Emulators\MESS\assets\Sega Master System\Cartridges
13:22:06.8 4/7/2014: Validating: Emulator_11: Manual Path: C:\Emulators\MESS\assets\Sega Master System\Manuals
13:22:06.8 4/7/2014: Validating: Emulator_12: Snap Path: C:\Emulators\MESS\assets\Sega Genesis\Snaps
13:22:06.8 4/7/2014: Validating: Emulator_12: Control Panel Path: C:\Emulators\MESS\assets\Sega Genesis\Controls
13:22:06.8 4/7/2014: Validating: Emulator_12: Database: [Console] Sega Genesis
13:22:06.8 4/7/2014: Validating: Emulator_12: Title Snap Path: C:\Emulators\MESS\assets\Sega Genesis\Titles
13:22:06.8 4/7/2014: Validating: Emulator_12: Box Art Path: C:\Emulators\MESS\assets\Sega Genesis\Boxes
13:22:06.8 4/7/2014: Validating: Emulator_12: Cart Art Path: C:\Emulators\MESS\assets\Sega Genesis\Cartridges
13:22:06.8 4/7/2014: Validating: Emulator_12: Manual Path: C:\Emulators\MESS\assets\Sega Genesis\Manuals
13:22:06.8 4/7/2014: Validating: Emulator_13: Snap Path: C:\Emulators\Fusion\assets\Sega CD\Snaps
13:22:06.8 4/7/2014: Validating: Emulator_13: Control Panel Path: C:\Emulators\Fusion\assets\Sega CD\Controls
13:22:06.8 4/7/2014: Validating: Emulator_13: Database: [Console] Sega CD
13:22:06.8 4/7/2014: Validating: Emulator_13: Title Snap Path: C:\Emulators\Fusion\assets\Sega CD\Titles
13:22:06.9 4/7/2014: Validating: Emulator_13: Box Art Path: C:\Emulators\Fusion\assets\Sega CD\Boxes
13:22:06.9 4/7/2014: Validating: Emulator_13: Cart Art Path: C:\Emulators\Fusion\assets\Sega CD\Cartridges
13:22:06.9 4/7/2014: Validating: Emulator_13: Manual Path: C:\Emulators\Fusion\assets\Sega CD\Manuals
13:22:06.9 4/7/2014: Validating: Emulator_14: Snap Path: C:\Emulators\FCEUX\assets\Nintendo NES\Snaps
13:22:06.9 4/7/2014: Validating: Emulator_14: Control Panel Path: C:\Emulators\FCEUX\assets\Nintendo NES\Controls
13:22:06.9 4/7/2014: Validating: Emulator_14: Database: [Console] Nintendo NES
13:22:06.9 4/7/2014: Validating: Emulator_14: Title Snap Path: C:\Emulators\FCEUX\assets\Nintendo NES\Titles
13:22:06.9 4/7/2014: Validating: Emulator_14: Box Art Path: C:\Emulators\FCEUX\assets\Nintendo NES\Boxes
13:22:06.9 4/7/2014: Validating: Emulator_14: Cart Art Path: C:\Emulators\FCEUX\assets\Nintendo NES\Cartridges
13:22:06.9 4/7/2014: Validating: Emulator_14: Manual Path: C:\Emulators\FCEUX\assets\Nintendo NES\Manuals
13:22:06.9 4/7/2014: Validating: Emulator_15: Snap Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Snaps
13:22:06.9 4/7/2014: Validating: Emulator_15: Control Panel Path: C:\Emulators\FCEUX\assets\Nintendo NES\Controls
13:22:06.9 4/7/2014: Validating: Emulator_15: Database: [Console] Nintendo Famicom Disk System
13:22:06.9 4/7/2014: Validating: Emulator_15: Title Snap Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Titles
13:22:06.9 4/7/2014: Validating: Emulator_15: Box Art Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Boxes
13:22:06.9 4/7/2014: Validating: Emulator_15: Cart Art Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Cartridges
13:22:06.9 4/7/2014: Validating: Emulator_15: Manual Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Manuals
13:22:06.9 4/7/2014: Validating: Emulator_16: Snap Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Snaps
13:22:06.9 4/7/2014: Validating: Emulator_16: Control Panel Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Controls
13:22:06.9 4/7/2014: Validating: Emulator_16: Database: [Console] Nintendo SNES
13:22:06.9 4/7/2014: Validating: Emulator_16: Title Snap Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Titles
13:22:07.0 4/7/2014: Validating: Emulator_16: Box Art Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Boxes
13:22:07.0 4/7/2014: Validating: Emulator_16: Cart Art Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Cartridges
13:22:07.0 4/7/2014: Validating: Emulator_16: Manual Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Manuals
13:22:07.0 4/7/2014: Validating: Emulator_17: Snap Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Snaps
13:22:07.0 4/7/2014: Validating: Emulator_17: Control Panel Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Controls
13:22:07.0 4/7/2014: Validating: Emulator_17: Database: [Console] NEC TurboGrafx-16
13:22:07.0 4/7/2014: Validating: Emulator_17: Title Snap Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Titles
13:22:07.0 4/7/2014: Validating: Emulator_17: Box Art Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Boxes
13:22:07.0 4/7/2014: Validating: Emulator_17: Cart Art Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Cartridges
13:22:07.0 4/7/2014: Validating: Emulator_17: Manual Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Manuals
13:22:07.0 4/7/2014: Validating: Emulator_18: Snap Path: C:\Emulators\Mednafen\assets\NEC TurboGrafx CD\Snaps
13:22:07.0 4/7/2014: Validating: Emulator_18: Control Panel Path: C:\Emulators\Mednafen\assets\NEC TurboGrafx CD\Controls
13:22:07.0 4/7/2014: Validating: Emulator_18: Database: [Console] NEC TurboGrafx CD
13:22:07.0 4/7/2014: Validating: Emulator_18: Title Snap Path: C:\Emulators\Mednafen\assets\NEC TurboGrafx CD\Titles
13:22:07.0 4/7/2014: Validating: Emulator_18: Box Art Path: C:\Emulators\Mednafen\assets\NEC TurboGrafx CD\Boxes
13:22:07.0 4/7/2014: Validating: Emulator_18: Cart Art Path: C:\Emulators\Mednafen\assets\NEC TurboGrafx CD\Cartridges
13:22:07.0 4/7/2014: Validating: Emulator_18: Manual Path: C:\Emulators\Mednafen\assets\NEC TurboGrafx CD\Manuals
13:22:07.0 4/7/2014: Validating: Emulator_19: Snap Path: C:\Emulators\MESS\assets\Atari Lynx\Snaps
13:22:07.0 4/7/2014: Validating: Emulator_19: Control Panel Path: C:\Emulators\MESS\assets\Atari Lynx\Controls
13:22:07.0 4/7/2014: Validating: Emulator_19: Database: [Handheld] Atari Lynx
13:22:07.1 4/7/2014: Validating: Emulator_19: Title Snap Path: C:\Emulators\MESS\assets\Atari Lynx\Titles
13:22:07.1 4/7/2014: Validating: Emulator_19: Box Art Path: C:\Emulators\MESS\assets\Atari Lynx\Boxes
13:22:07.1 4/7/2014: Validating: Emulator_19: Cart Art Path: C:\Emulators\MESS\assets\Atari Lynx\Cartridges
13:22:07.1 4/7/2014: Validating: Emulator_19: Manual Path: C:\Emulators\MESS\assets\Atari Lynx\Manuals
13:22:07.1 4/7/2014: Validating: Emulator_20: Snap Path: C:\Emulators\MESS\assets\SNK Neo Geo Pocket Color\Snaps
13:22:07.1 4/7/2014: Validating: Emulator_20: Control Panel Path: C:\Emulators\MESS\assets\SNK Neo Geo Pocket Color\Controls
13:22:07.1 4/7/2014: Validating: Emulator_20: Database: [Handheld] SNK Neo Geo Pocket Color
13:22:07.1 4/7/2014: Validating: Emulator_20: Title Snap Path: C:\Emulators\MESS\assets\SNK Neo Geo Pocket Color\Titles
13:22:07.1 4/7/2014: Validating: Emulator_20: Box Art Path: C:\Emulators\MESS\assets\SNK Neo Geo Pocket Color\Boxes
13:22:07.1 4/7/2014: Validating: Emulator_20: Cart Art Path: C:\Emulators\MESS\assets\SNK Neo Geo Pocket Color\Cartridges
13:22:07.1 4/7/2014: Validating: Emulator_20: Manual Path: C:\Emulators\MESS\assets\SNK Neo Geo Pocket Color\Manuals
13:22:07.1 4/7/2014: Validating: Emulator_21: Snap Path: C:\Emulators\BlueMSX\Assets\Microsoft MSX\Snaps
13:22:07.1 4/7/2014: Validating: Emulator_21: Control Panel Path: C:\Emulators\BlueMSX\Assets\Microsoft MSX\Controls
13:22:07.1 4/7/2014: Validating: Emulator_21: Database: [PC] Microsoft MSX
13:22:07.1 4/7/2014: Validating: Emulator_21: Title Snap Path: C:\Emulators\BlueMSX\Assets\Microsoft MSX\Titles
13:22:07.1 4/7/2014: Validating: Emulator_21: Box Art Path: C:\Emulators\BlueMSX\Assets\Microsoft MSX\Boxes
13:22:07.1 4/7/2014: Validating: Emulator_21: Cart Art Path: C:\Emulators\BlueMSX\Assets\Microsoft MSX\Cartridges
13:22:07.1 4/7/2014: Validating: Emulator_21: Manual Path: C:\Emulators\BlueMSX\Assets\Microsoft MSX\Manuals
13:22:07.1 4/7/2014: Validating: Emulator_22: Snap Path: C:\Emulators\MESS\assets\GCE Vectrex\Snaps
13:22:07.1 4/7/2014: Validating: Emulator_22: Control Panel Path: C:\Emulators\MESS\assets\GCE Vectrex\Controls
13:22:07.1 4/7/2014: Validating: Emulator_22: Database: [Console] GCE Vectrex
13:22:07.2 4/7/2014: Validating: Emulator_22: Title Snap Path: C:\Emulators\MESS\assets\GCE Vectrex\Titles
13:22:07.2 4/7/2014: Validating: Emulator_22: Box Art Path: C:\Emulators\MESS\assets\GCE Vectrex\Boxes
13:22:07.2 4/7/2014: Validating: Emulator_22: Cart Art Path: C:\Emulators\MESS\assets\GCE Vectrex\Cartridges
13:22:07.2 4/7/2014: Validating: Emulator_22: Manual Path: C:\Emulators\MESS\assets\GCE Vectrex\Manuals
13:22:07.2 4/7/2014: Validating: Emulator_23: Snap Path: C:\Emulators\MESS\assets\Super Vision\Snaps
13:22:07.2 4/7/2014: Warning: Emulator_23: Snap Path Does not exist
13:22:07.2 4/7/2014: Validating: Emulator_23: Control Panel Path: C:\Emulators\MESS\assets\Super Vision\Controls
13:22:07.2 4/7/2014: Warning: Emulator_23: Control Panel Path Does not exist
13:22:07.2 4/7/2014: Validating: Emulator_23: Database: [Handheld] Watara Supervision
13:22:07.2 4/7/2014: Validating: Emulator_23: Title Snap Path: C:\Emulators\MESS\assets\Super Vision\Snaps
13:22:07.2 4/7/2014: Warning: Emulator_23: Title Snap Path Does not exist
13:22:07.2 4/7/2014: Validating: Emulator_23: Box Art Path: C:\Emulators\MESS\assets\Super Vision\Snaps
13:22:07.2 4/7/2014: Warning: Emulator_23: Box Art Path Does not exist
13:22:07.2 4/7/2014: Validating: Emulator_23: Cart Art Path: C:\Emulators\MESS\assets\Super Vision\Snaps
13:22:07.2 4/7/2014: Warning: Emulator_23: Cart Art Path Does not exist
13:22:07.2 4/7/2014: Validating: Emulator_23: Manual Path: C:\Emulators\MESS\assets\Super Vision\Snaps
13:22:07.2 4/7/2014: Warning: Emulator_23: Manual Path Does not exist
13:22:07.2 4/7/2014: Validating: Emulator_31: Snap Path: C:\Emulators\FCEUX\assets\Nintendo NES\Snaps
13:22:07.2 4/7/2014: Validating: Emulator_31: Control Panel Path: C:\Emulators\FCEUX\assets\Nintendo NES\Controls
13:22:07.2 4/7/2014: Validating: Emulator_31: Database: [Console] Nintendo NES
13:22:07.2 4/7/2014: Validating: Emulator_31: Title Snap Path: C:\Emulators\FCEUX\assets\Nintendo NES\Titles
13:22:07.3 4/7/2014: Validating: Emulator_31: Box Art Path: C:\Emulators\FCEUX\assets\Nintendo NES\Boxes
13:22:07.3 4/7/2014: Validating: Emulator_31: Cart Art Path: C:\Emulators\FCEUX\assets\Nintendo NES\Cartridges
13:22:07.3 4/7/2014: Validating: Emulator_31: Manual Path: C:\Emulators\FCEUX\assets\Nintendo NES\Manuals
13:22:07.3 4/7/2014: Validating: Emulator_32: Snap Path: C:\Emulators\MESS\assets\Atari 7800\Snaps
13:22:07.3 4/7/2014: Validating: Emulator_32: Control Panel Path: C:\Emulators\MESS\assets\Atari 7800\Controls
13:22:07.3 4/7/2014: Validating: Emulator_32: Database: [Console] Atari 7800
13:22:07.3 4/7/2014: Validating: Emulator_32: Title Snap Path: C:\Emulators\MESS\assets\Atari 7800\Titles
13:22:07.3 4/7/2014: Validating: Emulator_32: Box Art Path: C:\Emulators\MESS\assets\Atari 7800\Boxes
13:22:07.3 4/7/2014: Validating: Emulator_32: Cart Art Path: C:\Emulators\MESS\assets\Atari 7800\Cartridges
13:22:07.3 4/7/2014: Validating: Emulator_32: Manual Path: C:\Emulators\MESS\assets\Atari 7800\Manuals
13:22:07.3 4/7/2014: Validating: Emulator_33: Snap Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Snaps
13:22:07.3 4/7/2014: Validating: Emulator_33: Control Panel Path: C:\Emulators\FCEUX\assets\Nintendo NES\Controls
13:22:07.3 4/7/2014: Validating: Emulator_33: Database: [Console] Nintendo Famicom Disk System
13:22:07.3 4/7/2014: Validating: Emulator_33: Title Snap Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Titles
13:22:07.3 4/7/2014: Validating: Emulator_33: Box Art Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Boxes
13:22:07.3 4/7/2014: Validating: Emulator_33: Cart Art Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Cartridges
13:22:07.3 4/7/2014: Validating: Emulator_33: Manual Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Manuals
13:22:07.3 4/7/2014: Validating: Emulator_34: Snap Path: C:\Emulators\MESS\assets\Coleco Vision\Snaps
13:22:07.3 4/7/2014: Validating: Emulator_34: Control Panel Path: C:\Emulators\MESS\assets\Coleco Vision\Controls
13:22:07.3 4/7/2014: Validating: Emulator_34: Database: [Console] Coleco Vision
13:22:07.3 4/7/2014: Validating: Emulator_34: Title Snap Path: C:\Emulators\MESS\assets\Coleco Vision\Titles
13:22:07.3 4/7/2014: Validating: Emulator_34: Box Art Path: C:\Emulators\MESS\assets\Coleco Vision\Boxes
13:22:07.4 4/7/2014: Validating: Emulator_34: Cart Art Path: C:\Emulators\MESS\assets\Coleco Vision\Cartridges
13:22:07.4 4/7/2014: Validating: Emulator_34: Manual Path: C:\Emulators\MESS\assets\Coleco Vision\Manuals
13:22:07.4 4/7/2014: Validating: Emulator_35: Snap Path: C:\Emulators\MESS\assets\Intellivision\Snaps
13:22:07.4 4/7/2014: Validating: Emulator_35: Control Panel Path: C:\Emulators\MESS\assets\Coleco Vision\Controls
13:22:07.4 4/7/2014: Validating: Emulator_35: Database: [Console] Mattel Intellivision
13:22:07.4 4/7/2014: Validating: Emulator_35: Title Snap Path: C:\Emulators\MESS\assets\Intellivision\Titles
13:22:07.4 4/7/2014: Validating: Emulator_35: Box Art Path: C:\Emulators\MESS\assets\Intellivision\Boxes
13:22:07.4 4/7/2014: Validating: Emulator_35: Cart Art Path: C:\Emulators\MESS\assets\Intellivision\Cartridges
13:22:07.4 4/7/2014: Validating: Emulator_35: Manual Path: C:\Emulators\MESS\assets\Intellivision\Manuals
13:22:07.4 4/7/2014: Validating: Emulator_36: Snap Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Snaps
13:22:07.4 4/7/2014: Validating: Emulator_36: Control Panel Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Controls
13:22:07.4 4/7/2014: Validating: Emulator_36: Database: [Console] Nintendo SNES
13:22:07.4 4/7/2014: Validating: Emulator_36: Title Snap Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Titles
13:22:07.4 4/7/2014: Validating: Emulator_36: Box Art Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Boxes
13:22:07.4 4/7/2014: Validating: Emulator_36: Cart Art Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Cartridges
13:22:07.4 4/7/2014: Validating: Emulator_36: Manual Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Manuals
13:22:07.5 4/7/2014: Validating: Emulator_37: Snap Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Snaps
13:22:07.5 4/7/2014: Validating: Emulator_37: Control Panel Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Controls
13:22:07.5 4/7/2014: Validating: Emulator_37: Database: [Console] NEC TurboGrafx-16
13:22:07.5 4/7/2014: Validating: Emulator_37: Title Snap Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Titles
13:22:07.5 4/7/2014: Validating: Emulator_37: Box Art Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Boxes
13:22:07.5 4/7/2014: Validating: Emulator_37: Cart Art Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Cartridges
13:22:07.5 4/7/2014: Validating: Emulator_37: Manual Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Manuals
13:22:07.5 4/7/2014: Validating: Emulator_38: Snap Path: C:\Emulators\MESS\assets\Sega Master System\Snaps
13:22:07.5 4/7/2014: Validating: Emulator_38: Control Panel Path: C:\Emulators\MESS\assets\Sega Master System\Controls
13:22:07.5 4/7/2014: Validating: Emulator_38: Database: [Console] Sega Master System
13:22:07.5 4/7/2014: Validating: Emulator_38: Title Snap Path: C:\Emulators\MESS\assets\Sega Master System\Titles
13:22:07.5 4/7/2014: Validating: Emulator_38: Box Art Path: C:\Emulators\MESS\assets\Sega Master System\Boxes
13:22:07.5 4/7/2014: Validating: Emulator_38: Cart Art Path: C:\Emulators\MESS\assets\Sega Master System\Cartridges
13:22:07.5 4/7/2014: Validating: Emulator_38: Manual Path: C:\Emulators\MESS\assets\Sega Master System\Manuals
13:22:07.5 4/7/2014: Validating: Emulator_39: Snap Path: C:\Emulators\MESS\assets\Sega Genesis\Snaps
13:22:07.5 4/7/2014: Validating: Emulator_39: Control Panel Path: C:\Emulators\MESS\assets\Sega Genesis\Controls
13:22:07.5 4/7/2014: Validating: Emulator_39: Database: [Console] Sega Genesis
13:22:07.5 4/7/2014: Validating: Emulator_39: Title Snap Path: C:\Emulators\MESS\assets\Sega Genesis\Titles
13:22:07.5 4/7/2014: Validating: Emulator_39: Box Art Path: C:\Emulators\MESS\assets\Sega Genesis\Boxes
13:22:07.5 4/7/2014: Validating: Emulator_39: Cart Art Path: C:\Emulators\MESS\assets\Sega Genesis\Cartridges
13:22:07.5 4/7/2014: Validating: Emulator_39: Manual Path: C:\Emulators\MESS\assets\Sega Genesis\Manuals
13:22:07.6 4/7/2014: Restoring Emulator from Cache: 2
13:22:07.8 4/7/2014: Restoring Emulator Database From Cache: 2
13:22:08.0 4/7/2014: Restoring Emulator from Cache: 3
13:22:08.1 4/7/2014: Restoring Emulator Database From Cache: 3
13:22:08.1 4/7/2014: Restoring Emulator from Cache: 4
13:22:08.1 4/7/2014: Restoring Emulator Database From Cache: 4
13:22:08.2 4/7/2014: Restoring Emulator from Cache: 5
13:22:08.3 4/7/2014: Restoring Emulator Database From Cache: 5
13:22:08.4 4/7/2014: Restoring Emulator from Cache: 6
13:22:08.4 4/7/2014: Restoring Emulator Database From Cache: 6
13:22:08.5 4/7/2014: Restoring Emulator from Cache: 7
13:22:08.6 4/7/2014: Restoring Emulator Database From Cache: 7
13:22:08.7 4/7/2014: Restoring Emulator from Cache: 8
13:22:08.8 4/7/2014: Restoring Emulator Database From Cache: 8
13:22:08.8 4/7/2014: Restoring Emulator from Cache: 9
13:22:08.9 4/7/2014: Restoring Emulator Database From Cache: 9
13:22:09.0 4/7/2014: Restoring Emulator from Cache: 10
13:22:09.0 4/7/2014: Restoring Emulator Database From Cache: 10
13:22:09.1 4/7/2014: Restoring Emulator from Cache: 11
13:22:09.1 4/7/2014: Restoring Emulator Database From Cache: 11
13:22:09.2 4/7/2014: Restoring Emulator from Cache: 12
13:22:09.3 4/7/2014: Restoring Emulator Database From Cache: 12
13:22:09.4 4/7/2014: Restoring Emulator from Cache: 13
13:22:09.4 4/7/2014: Restoring Emulator Database From Cache: 13
13:22:09.5 4/7/2014: Restoring Emulator from Cache: 14
13:22:09.6 4/7/2014: Restoring Emulator Database From Cache: 14
13:22:09.6 4/7/2014: Restoring Emulator from Cache: 15
13:22:09.7 4/7/2014: Restoring Emulator Database From Cache: 15
13:22:09.8 4/7/2014: Restoring Emulator from Cache: 16
13:22:09.9 4/7/2014: Restoring Emulator Database From Cache: 16
13:22:09.9 4/7/2014: Restoring Emulator from Cache: 17
13:22:10.0 4/7/2014: Restoring Emulator Database From Cache: 17
13:22:10.1 4/7/2014: Restoring Emulator from Cache: 18
13:22:10.1 4/7/2014: No Database Data: 18
13:22:10.2 4/7/2014: Restoring Emulator from Cache: 19
13:22:10.2 4/7/2014: Restoring Emulator Database From Cache: 19
13:22:10.3 4/7/2014: Restoring Emulator from Cache: 20
13:22:10.3 4/7/2014: Restoring Emulator Database From Cache: 20
13:22:10.4 4/7/2014: Restoring Emulator from Cache: 21
13:22:10.5 4/7/2014: Restoring Emulator Database From Cache: 21
13:22:10.5 4/7/2014: Restoring Emulator from Cache: 22
13:22:10.6 4/7/2014: Restoring Emulator Database From Cache: 22
13:22:10.6 4/7/2014: Restoring Emulator from Cache: 23
13:22:10.7 4/7/2014: Restoring Emulator Database From Cache: 23
13:22:10.9 4/7/2014: Restoring Emulator Database From Cache: 32
13:22:10.9 4/7/2014: Restoring Emulator Database From Cache: 33
13:22:11.0 4/7/2014: Restoring Emulator Database From Cache: 34
13:22:11.1 4/7/2014: Restoring Emulator Database From Cache: 35
13:22:11.2 4/7/2014: Restoring Emulator Database From Cache: 36
13:22:11.3 4/7/2014: Restoring Emulator Database From Cache: 37
13:22:11.4 4/7/2014: Restoring Emulator Database From Cache: 38
13:22:11.5 4/7/2014: Restoring Emulator Database From Cache: 39
13:22:22.9 4/7/2014: Creating instance of global keyboard hook
13:22:23.1 4/7/2014: Running: cmd.exe /c C: fceux.exe "C:\Emulators\FCEUX\NES Roms\Archon (U) [!]"
13:22:23.3 4/7/2014: Shutting down display
13:22:27.4 4/7/2014: Writing Stats
13:22:27.7 4/7/2014: 21 Consecutive Exceptions Occured
13:22:27.7 4/7/2014: Object reference not set to an instance of an object.
13:22:27.7 4/7/2014: at Direct2D.Direct2d.Device.BeginScene(Boolean Clear, Color ClearColour)
13:22:27.8 4/7/2014: at GameEx.GameEx.MainForm.k(Boolean A_0)
13:22:27.8 4/7/2014: at GameEx.GameEx.MainForm.dw()
13:22:27.8 4/7/2014: Trying reinitialising the display after sleeping for 4 seconds
13:22:27.8 4/7/2014: Exception count will be dropped to 15
13:22:41.2 4/7/2014: Exiting GameEx!
13:22:41.2 4/7/2014: Disposing all videos
13:22:41.2 4/7/2014: Deleting temporary Karaoke videos
13:22:41.2 4/7/2014: Disposing Image List
13:22:41.3 4/7/2014: Disposing Fonts
13:22:41.3 4/7/2014: Disposing Surfaces
13:22:41.3 4/7/2014: Saving Settings
13:22:41.3 4/7/2014: Shutting down Bass
13:22:41.4 4/7/2014: Closing HideOS.exe
13:22:41.6 4/7/2014: Disposing Plugins
13:22:41.6 4/7/2014: Closing database connection
13:22:41.6 4/7/2014: Checking for applications to Launch On Exit
13:22:41.7 4/7/2014: Media Center was not open when starting GameEx, so not launching
13:22:41.7 4/7/2014: Bye
Edit: Nevermind
Now this is just weird. I was concerned about the screen flickering, so I switched my .map file back to the one I made (which I attached above earlier). I went to test it out and it works. The error message is gone and the games load fine.
Here's my log. I don't see anything out of the ordinary though.
13:29:27.2 4/7/2014: Opening Configuration File
13:29:27.3 4/7/2014: GameEx: Version 13.25: Starting Log
13:29:27.3 4/7/2014: Operating System Platform: Win32NT
13:29:27.3 4/7/2014: Operating System Name: Windows 7
13:29:27.3 4/7/2014: Operating System Version: 6.1.7601
13:29:27.3 4/7/2014: Aero running
13:29:27.3 4/7/2014: Initializing Vista/Windows 7 volume control
13:29:27.4 4/7/2014: Getting CPU and RAM info
13:29:27.4 4/7/2014: Intel® Core i7-2720QM CPU @ 2.20GHz, 8140MB
13:29:27.4 4/7/2014: 2.19Ghz - 8 Cores or CPU's
13:29:27.4 4/7/2014: Running Randomize()
13:29:27.4 4/7/2014: Loading PlugIns
13:29:27.4 4/7/2014: Checking for applications to Launch On Startup
13:29:27.5 4/7/2014: Setting default net connection limit to 15
13:29:27.5 4/7/2014: Running Misc startup tasks
13:29:27.5 4/7/2014: Setting Menu types
13:29:27.5 4/7/2014: Getting Configuration Values
13:29:27.5 4/7/2014: Using Theme: Red-Blue V4
13:29:27.5 4/7/2014: Checking for alternate Image Directory for Theme: Red-Blue V4
13:29:27.5 4/7/2014: Launching HideOS.exe
13:29:27.5 4/7/2014: Initialising Video/MNG DLL's
13:29:27.5 4/7/2014: Hiding Taskbar
13:29:27.6 4/7/2014: Is Media Center running?
13:29:27.6 4/7/2014: Checking/Creating LCD Registry values
13:29:27.6 4/7/2014: Check Media Center Exit/Start Mode
13:29:27.6 4/7/2014: Media Center Mode 2
13:29:27.6 4/7/2014: Video previews on. Warning: Only recommended on modern systems
13:29:27.6 4/7/2014: Snap Delay set to: 4
13:29:27.6 4/7/2014: Get other settings
13:29:27.7 4/7/2014: Set: Find emulator artwork on best match basis
13:29:27.7 4/7/2014: Start work for Form
13:29:27.7 4/7/2014: Getting Original Screen Size
13:29:27.7 4/7/2014: Opening Database Connection
13:29:27.9 4/7/2014: Initializing Component
13:29:28.1 4/7/2014: MAME Path is: C:\Emulators\MAME
13:29:28.1 4/7/2014: MAME EXE file is: mame64.exe
13:29:28.1 4/7/2014: ROM Path is: C:\Emulators\MAME\roms
13:29:28.1 4/7/2014: Catver.ini is located at: C:\GameEx\DATA\catver.ini
13:29:28.1 4/7/2014: History.dat is located at: C:\GameEx\DATA\history.dat
13:29:28.1 4/7/2014: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
13:29:28.1 4/7/2014: command.dat is located at: C:\GameEx\DATA\command.dat
13:29:28.1 4/7/2014: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
13:29:28.1 4/7/2014: Loading Controls.ini map file
13:29:28.1 4/7/2014: Snap Path is: C:\GameEx\DEMO\MAME\snaps
13:29:28.1 4/7/2014: Database Snap Path: Not Found
13:29:28.1 4/7/2014: Background Snap Path: Not Found
13:29:28.2 4/7/2014: AVI Snap Path is: C:\GameEx\DEMO\MAME\video
13:29:28.2 4/7/2014: Flyer Path is: C:\GameEx\DEMO\MAME\flyers
13:29:28.2 4/7/2014: Cabinet Path is: C:\GameEx\DEMO\MAME\cabinets
13:29:28.2 4/7/2014: Cabinet 3D Path: Not Found
13:29:28.2 4/7/2014: Title Path is: C:\GameEx\DEMO\MAME\titles
13:29:28.2 4/7/2014: PCB Path: Not Found
13:29:28.2 4/7/2014: Artwork Preview Path: Not Found
13:29:28.2 4/7/2014: Panel Path: Not Found
13:29:28.2 4/7/2014: Manual Path is: C:\GameEx\DEMO\MAME\manual
13:29:28.2 4/7/2014: Icon Path: Not Found
13:29:28.2 4/7/2014: Marquee Path is: C:\GameEx\DEMO\MAME\marquees
13:29:28.3 4/7/2014: Applying Language/Text
13:29:28.3 4/7/2014: Text/Language: English
13:29:28.3 4/7/2014: Loading Language/Text
13:29:28.4 4/7/2014: Loading Custom Emulators
13:29:28.4 4/7/2014: Loading Emulator 2: Atari 2600 (Stella)
13:29:28.4 4/7/2014: Loading Emulator 3: Atari 5200 (kat5200)
13:29:28.4 4/7/2014: Loading Emulator 4: Atari 7800 (MESS)
13:29:28.4 4/7/2014: Loading Emulator 5: Coleco Vision (MESS)
13:29:28.4 4/7/2014: Loading Emulator 6: Intellivision (MESS)
13:29:28.4 4/7/2014: Loading Emulator 7: Odyssey 2 (MESS)
13:29:28.4 4/7/2014: Loading Emulator 8: Fairchild Channel F (MESS)
13:29:28.4 4/7/2014: Loading Emulator 9: Super Cassette Vision (MESS)
13:29:28.5 4/7/2014: Loading Emulator 10: SG-1000 (bee)
13:29:28.5 4/7/2014: Loading Emulator 11: Sega Master System (MESS)
13:29:28.5 4/7/2014: Loading Emulator 12: Sega Genesis (MESS)
13:29:28.5 4/7/2014: Loading Emulator 13: Sega CD (Fusion)
13:29:28.5 4/7/2014: Loading Emulator 14: Nintendo NES (FCEUX)
13:29:28.5 4/7/2014: Loading Emulator 15: Nintendo FDS (FCEUX)
13:29:28.5 4/7/2014: Loading Emulator 16: Nintendo SNES (ZSNES)
13:29:28.5 4/7/2014: Loading Emulator 17: TurboGrafx-16 (MESS)
13:29:28.5 4/7/2014: Loading Emulator 18: TurboGrafx-CD (mednafen)
13:29:28.5 4/7/2014: Loading Emulator 19: Atari Lynx (MESS)
13:29:28.6 4/7/2014: Loading Emulator 20: Neo Geo Pocket Color (MESS)
13:29:28.6 4/7/2014: Loading Emulator 21: MSX (blueMSX)
13:29:28.6 4/7/2014: Loading Emulator 22: Vectrex (MESS)
13:29:28.6 4/7/2014: Loading Emulator 23: Watara Super Vision (MESS)
13:29:28.6 4/7/2014: Loading Emulator 31: Nintendo NES [Multiplayer Games]
13:29:28.6 4/7/2014: Loading Emulator 32: Atari 7800 [Multiplayer Games]
13:29:28.6 4/7/2014: Loading Emulator 33: Nintendo FDS [Multiplayer Games]
13:29:28.6 4/7/2014: Loading Emulator 34: Coleco Vision [Multiplayer Games]
13:29:28.6 4/7/2014: Loading Emulator 35: Intellivision [Multiplayer Games]
13:29:28.6 4/7/2014: Loading Emulator 36: Nintendo SNES [Multiplayer Games]
13:29:28.7 4/7/2014: Loading Emulator 37: TurboGrafx-16 [Multiplayer Games]
13:29:28.7 4/7/2014: Loading Emulator 38: Sega Master System [Multiplayer Games]
13:29:28.7 4/7/2014: Loading Emulator 39: Sega Genesis [Multiplayer Games]
13:29:28.7 4/7/2014: Checking if Steam enabled
13:29:28.7 4/7/2014: Steam support is turned off in configuration.
13:29:28.7 4/7/2014: Using Version 3 Themes Animations
13:29:28.7 4/7/2014: Retrieving resolution setting
13:29:28.7 4/7/2014: Using General Font: Trebuchet MS
13:29:28.7 4/7/2014: Using Title Font: Trebuchet MS
13:29:28.8 4/7/2014: GameEx will try to reduce CPU usage
13:29:28.8 4/7/2014: Initialising Direct3D
13:29:29.1 4/7/2014: Setting Resolution to 1366x768 32 bit color
13:29:29.1 4/7/2014: Creating Surfaces
13:29:29.5 4/7/2014: Creating Primary Surface - Full Screen Mode
13:29:29.5 4/7/2014: Creating Back Buffer
13:29:29.6 4/7/2014: Version 2 Theme being used. Loading.
13:29:29.6 4/7/2014: Loading Button Data
13:29:29.6 4/7/2014: Loading Font Data
13:29:29.6 4/7/2014: Loading Layout Data
13:29:29.6 4/7/2014: Loading Taskbar Data
13:29:29.6 4/7/2014: Loading graphic Surfaces
13:29:29.6 4/7/2014: Display is running at: 1366x768 32bit color, 60hz
13:29:29.6 4/7/2014: Adapter: Radeon HD 6770M
13:29:29.6 4/7/2014: Max texture size: 16384x16384
13:29:29.6 4/7/2014: Available texture memory: 714MB
13:29:29.6 4/7/2014: Initialising Bass Audio Library
13:29:29.7 4/7/2014: Creating Surfaces Misc and Dialogs
13:29:30.0 4/7/2014: Creating Surfaces Volume
13:29:30.0 4/7/2014: Creating Surfaces Arrows
13:29:30.0 4/7/2014: Creating Surfaces GameEXlogo Text
13:29:30.0 4/7/2014: Creating Surfaces Toolbar
13:29:30.1 4/7/2014: Creating Surfaces Toolbar Controls
13:29:30.1 4/7/2014: Creating Surfaces Backgrounds
13:29:30.1 4/7/2014: Creating Surfaces GameEx Logo
13:29:30.1 4/7/2014: Creating Surface Unselected
13:29:30.2 4/7/2014: Creating Surfaces Snaps
13:29:30.2 4/7/2014: Creating Surfaces Menu and List Bars
13:29:30.3 4/7/2014: Creating Fonts
13:29:30.3 4/7/2014: Creating Game Font
13:29:30.7 4/7/2014: Creating Game Font Faded
13:29:31.1 4/7/2014: Creating Title Font
13:29:31.2 4/7/2014: Restoring Title Font From Cache
13:29:31.4 4/7/2014: Creating Font Black
13:29:31.5 4/7/2014: Creating Font Black Small
13:29:31.6 4/7/2014: Fonts Created Succesfully
13:29:32.2 4/7/2014: 4MB Video Memory Used
13:29:33.1 4/7/2014: Attempting to load game list
13:29:33.2 4/7/2014: MAME CMD options: -nowindow -joy -skip_gameinfo
13:29:33.5 4/7/2014: Cannot Load Play List. Check Path and filename
13:29:33.5 4/7/2014: Sound Disabled
13:29:33.5 4/7/2014: Initialising DirectInput for Gamepad support
13:29:33.6 4/7/2014: Unable to create a joystick device
13:29:33.6 4/7/2014: Loading Start Page
13:29:33.6 4/7/2014: Initializing MCE Remote
13:29:33.6 4/7/2014: Initialization OK! Starting GameEx!
13:29:33.6 4/7/2014: Testing Main Loop Once: Processing Frame
13:29:34.3 4/7/2014: Testing Main Loop Once: Main Loop ran successfully
13:29:36.3 4/7/2014: Validating: Emulator_2: Snap Path: C:\Emulators\Stella\assets\Atari 2600\Snaps
13:29:36.3 4/7/2014: Validating: Emulator_2: Control Panel Path: C:\Emulators\Stella\assets\Atari 2600\Controls
13:29:36.3 4/7/2014: Validating: Emulator_2: Database: [Console] Atari 2600
13:29:36.4 4/7/2014: Validating: Emulator_2: Title Snap Path: C:\Emulators\Stella\assets\Atari 2600\Titles
13:29:36.4 4/7/2014: Validating: Emulator_2: Box Art Path: C:\Emulators\Stella\assets\Atari 2600\Boxes
13:29:36.4 4/7/2014: Validating: Emulator_2: Cart Art Path: C:\Emulators\Stella\assets\Atari 2600\Cartridges
13:29:36.4 4/7/2014: Validating: Emulator_2: Manual Path: C:\Emulators\Stella\assets\Atari 2600\Manuals
13:29:36.4 4/7/2014: Validating: Emulator_3: Snap Path: C:\Emulators\MESS\assets\Atari 5200\Snaps
13:29:36.4 4/7/2014: Warning: Emulator_3: Snap Path Does not exist
13:29:36.4 4/7/2014: Validating: Emulator_3: Control Panel Path: C:\Emulators\MESS\assets\Atari 5200\Controls
13:29:36.4 4/7/2014: Warning: Emulator_3: Control Panel Path Does not exist
13:29:36.4 4/7/2014: Validating: Emulator_3: Database: [Console] Atari 5200
13:29:36.4 4/7/2014: Validating: Emulator_3: Title Snap Path: C:\Emulators\kat5200\assets\Atari 5200\Titles
13:29:36.4 4/7/2014: Validating: Emulator_3: Box Art Path: C:\Emulators\kat5200\assets\Atari 5200\Boxes
13:29:36.4 4/7/2014: Validating: Emulator_3: Cart Art Path: C:\Emulators\kat5200\assets\Atari 5200\Cartridges
13:29:36.4 4/7/2014: Validating: Emulator_3: Manual Path: C:\Emulators\kat5200\assets\Atari 5200\Manuals
13:29:36.4 4/7/2014: Validating: Emulator_4: Snap Path: C:\Emulators\MESS\assets\Atari 7800\Snaps
13:29:36.5 4/7/2014: Validating: Emulator_4: Control Panel Path: C:\Emulators\MESS\assets\Atari 7800\Controls
13:29:36.5 4/7/2014: Validating: Emulator_4: Database: [Console] Atari 7800
13:29:36.5 4/7/2014: Validating: Emulator_4: Title Snap Path: C:\Emulators\MESS\assets\Atari 7800\Titles
13:29:36.5 4/7/2014: Validating: Emulator_4: Box Art Path: C:\Emulators\MESS\assets\Atari 7800\Boxes
13:29:36.5 4/7/2014: Validating: Emulator_4: Cart Art Path: C:\Emulators\MESS\assets\Atari 7800\Cartridges
13:29:36.5 4/7/2014: Validating: Emulator_4: Manual Path: C:\Emulators\MESS\assets\Atari 7800\Manuals
13:29:36.5 4/7/2014: Validating: Emulator_5: Snap Path: C:\Emulators\MESS\assets\Coleco Vision\Snaps
13:29:36.5 4/7/2014: Validating: Emulator_5: Control Panel Path: C:\Emulators\MESS\assets\Coleco Vision\Controls
13:29:36.5 4/7/2014: Validating: Emulator_5: Database: [Console] Coleco Vision
13:29:36.5 4/7/2014: Validating: Emulator_5: Title Snap Path: C:\Emulators\MESS\assets\Coleco Vision\Titles
13:29:36.5 4/7/2014: Validating: Emulator_5: Box Art Path: C:\Emulators\MESS\assets\Coleco Vision\Boxes
13:29:36.5 4/7/2014: Validating: Emulator_5: Cart Art Path: C:\Emulators\MESS\assets\Coleco Vision\Cartridges
13:29:36.5 4/7/2014: Validating: Emulator_5: Manual Path: C:\Emulators\MESS\assets\Coleco Vision\Manuals
13:29:36.5 4/7/2014: Validating: Emulator_6: Snap Path: C:\Emulators\MESS\assets\Intellivision\Snaps
13:29:36.6 4/7/2014: Validating: Emulator_6: Control Panel Path: C:\Emulators\MESS\assets\Coleco Vision\Controls
13:29:36.6 4/7/2014: Validating: Emulator_6: Database: [Console] Mattel Intellivision
13:29:36.6 4/7/2014: Validating: Emulator_6: Title Snap Path: C:\Emulators\MESS\assets\Intellivision\Titles
13:29:36.6 4/7/2014: Validating: Emulator_6: Box Art Path: C:\Emulators\MESS\assets\Intellivision\Boxes
13:29:36.6 4/7/2014: Validating: Emulator_6: Cart Art Path: C:\Emulators\MESS\assets\Intellivision\Cartridges
13:29:36.6 4/7/2014: Validating: Emulator_6: Manual Path: C:\Emulators\MESS\assets\Intellivision\Manuals
13:29:36.6 4/7/2014: Validating: Emulator_7: Snap Path: C:\Emulators\MESS\assets\Odyssey 2\Snaps
13:29:36.6 4/7/2014: Warning: Emulator_7: Snap Path Does not exist
13:29:36.6 4/7/2014: Validating: Emulator_7: Control Panel Path: C:\Emulators\MESS\assets\Coleco Vision\Controls
13:29:36.6 4/7/2014: Validating: Emulator_7: Database: [Console] Magnavox Odyssey 2
13:29:36.6 4/7/2014: Validating: Emulator_7: Title Snap Path: C:\Emulators\MESS\assets\Odyssey 2\Titles
13:29:36.6 4/7/2014: Warning: Emulator_7: Title Snap Path Does not exist
13:29:36.6 4/7/2014: Validating: Emulator_7: Box Art Path: C:\Emulators\MESS\assets\Odyssey 2\Boxes
13:29:36.6 4/7/2014: Warning: Emulator_7: Box Art Path Does not exist
13:29:36.6 4/7/2014: Validating: Emulator_7: Cart Art Path: C:\Emulators\MESS\assets\Odyssey 2\Cartridges
13:29:36.7 4/7/2014: Warning: Emulator_7: Cart Art Path Does not exist
13:29:36.7 4/7/2014: Validating: Emulator_7: Manual Path: C:\Emulators\MESS\assets\Odyssey 2\Manuals
13:29:36.7 4/7/2014: Warning: Emulator_7: Manual Path Does not exist
13:29:36.7 4/7/2014: Validating: Emulator_8: Snap Path: C:\Emulators\MESS\assets\Fairchild Channel F\Snaps
13:29:36.7 4/7/2014: Validating: Emulator_8: Control Panel Path: C:\Emulators\MESS\assets\Fairchild Channel F\Controls
13:29:36.7 4/7/2014: Validating: Emulator_8: Database: [Console] Fairchild Channel F
13:29:36.7 4/7/2014: Validating: Emulator_8: Title Snap Path: C:\Emulators\MESS\assets\Fairchild Channel F\Titles
13:29:36.7 4/7/2014: Validating: Emulator_8: Box Art Path: C:\Emulators\MESS\assets\Fairchild Channel F\Boxes
13:29:36.7 4/7/2014: Validating: Emulator_8: Cart Art Path: C:\Emulators\MESS\assets\Fairchild Channel F\Cartridges
13:29:36.7 4/7/2014: Validating: Emulator_8: Manual Path: C:\Emulators\MESS\assets\Fairchild Channel F\Manuals
13:29:36.7 4/7/2014: Validating: Emulator_9: Snap Path: C:\Emulators\MESS\assets\Super Cassette Vision\Snaps
13:29:36.7 4/7/2014: Warning: Emulator_9: Snap Path Does not exist
13:29:36.7 4/7/2014: Validating: Emulator_9: Control Panel Path: C:\Emulators\MESS\assets\Super Cassette Vision\Controls
13:29:36.7 4/7/2014: Warning: Emulator_9: Control Panel Path Does not exist
13:29:36.7 4/7/2014: Validating: Emulator_9: Database: [Console] Epoch Super Cassette Vision
13:29:36.8 4/7/2014: Validating: Emulator_9: Title Snap Path: C:\Emulators\MESS\assets\Super Cassette Vision\Snaps
13:29:36.8 4/7/2014: Warning: Emulator_9: Title Snap Path Does not exist
13:29:36.8 4/7/2014: Validating: Emulator_9: Box Art Path: C:\Emulators\MESS\assets\Super Cassette Vision\Snaps
13:29:36.8 4/7/2014: Warning: Emulator_9: Box Art Path Does not exist
13:29:36.8 4/7/2014: Validating: Emulator_9: Cart Art Path: C:\Emulators\MESS\assets\Super Cassette Vision\Snaps
13:29:36.8 4/7/2014: Warning: Emulator_9: Cart Art Path Does not exist
13:29:36.8 4/7/2014: Validating: Emulator_9: Manual Path: C:\Emulators\MESS\assets\Super Cassette Vision\Snaps
13:29:36.8 4/7/2014: Warning: Emulator_9: Manual Path Does not exist
13:29:36.8 4/7/2014: Validating: Emulator_10: Snap Path: C:\Emulators\bee\assets\SG-1000\Snaps
13:29:36.8 4/7/2014: Warning: Emulator_10: Snap Path Does not exist
13:29:36.8 4/7/2014: Validating: Emulator_10: Control Panel Path: C:\Emulators\bee\assets\Controls
13:29:36.8 4/7/2014: Warning: Emulator_10: Control Panel Path Does not exist
13:29:36.8 4/7/2014: Validating: Emulator_10: Database: [Console] Sega SG-1000
13:29:36.8 4/7/2014: Validating: Emulator_10: Title Snap Path: C:\Emulators\bee\assets\SG-1000\Titles
13:29:36.8 4/7/2014: Warning: Emulator_10: Title Snap Path Does not exist
13:29:36.9 4/7/2014: Validating: Emulator_10: Box Art Path: C:\Emulators\bee\assets\SG-1000\Boxes
13:29:36.9 4/7/2014: Warning: Emulator_10: Box Art Path Does not exist
13:29:36.9 4/7/2014: Validating: Emulator_10: Cart Art Path: C:\Emulators\bee\assets\SG-1000\Cartridges
13:29:36.9 4/7/2014: Warning: Emulator_10: Cart Art Path Does not exist
13:29:36.9 4/7/2014: Validating: Emulator_10: Manual Path: C:\Emulators\bee\assets\SG-1000\Manuals
13:29:36.9 4/7/2014: Warning: Emulator_10: Manual Path Does not exist
13:29:36.9 4/7/2014: Validating: Emulator_11: Snap Path: C:\Emulators\MESS\assets\Sega Master System\Snaps
13:29:36.9 4/7/2014: Validating: Emulator_11: Control Panel Path: C:\Emulators\MESS\assets\Sega Master System\Controls
13:29:36.9 4/7/2014: Validating: Emulator_11: Database: [Console] Sega Master System
13:29:36.9 4/7/2014: Validating: Emulator_11: Title Snap Path: C:\Emulators\MESS\assets\Sega Master System\Titles
13:29:36.9 4/7/2014: Validating: Emulator_11: Box Art Path: C:\Emulators\MESS\assets\Sega Master System\Boxes
13:29:36.9 4/7/2014: Validating: Emulator_11: Cart Art Path: C:\Emulators\MESS\assets\Sega Master System\Cartridges
13:29:36.9 4/7/2014: Validating: Emulator_11: Manual Path: C:\Emulators\MESS\assets\Sega Master System\Manuals
13:29:36.9 4/7/2014: Validating: Emulator_12: Snap Path: C:\Emulators\MESS\assets\Sega Genesis\Snaps
13:29:37.0 4/7/2014: Validating: Emulator_12: Control Panel Path: C:\Emulators\MESS\assets\Sega Genesis\Controls
13:29:37.0 4/7/2014: Validating: Emulator_12: Database: [Console] Sega Genesis
13:29:37.0 4/7/2014: Validating: Emulator_12: Title Snap Path: C:\Emulators\MESS\assets\Sega Genesis\Titles
13:29:37.0 4/7/2014: Validating: Emulator_12: Box Art Path: C:\Emulators\MESS\assets\Sega Genesis\Boxes
13:29:37.0 4/7/2014: Validating: Emulator_12: Cart Art Path: C:\Emulators\MESS\assets\Sega Genesis\Cartridges
13:29:37.0 4/7/2014: Validating: Emulator_12: Manual Path: C:\Emulators\MESS\assets\Sega Genesis\Manuals
13:29:37.0 4/7/2014: Validating: Emulator_13: Snap Path: C:\Emulators\Fusion\assets\Sega CD\Snaps
13:29:37.0 4/7/2014: Validating: Emulator_13: Control Panel Path: C:\Emulators\Fusion\assets\Sega CD\Controls
13:29:37.0 4/7/2014: Validating: Emulator_13: Database: [Console] Sega CD
13:29:37.0 4/7/2014: Validating: Emulator_13: Title Snap Path: C:\Emulators\Fusion\assets\Sega CD\Titles
13:29:37.0 4/7/2014: Validating: Emulator_13: Box Art Path: C:\Emulators\Fusion\assets\Sega CD\Boxes
13:29:37.0 4/7/2014: Validating: Emulator_13: Cart Art Path: C:\Emulators\Fusion\assets\Sega CD\Cartridges
13:29:37.0 4/7/2014: Validating: Emulator_13: Manual Path: C:\Emulators\Fusion\assets\Sega CD\Manuals
13:29:37.0 4/7/2014: Validating: Emulator_14: Snap Path: C:\Emulators\FCEUX\assets\Nintendo NES\Snaps
13:29:37.0 4/7/2014: Validating: Emulator_14: Control Panel Path: C:\Emulators\FCEUX\assets\Nintendo NES\Controls
13:29:37.1 4/7/2014: Validating: Emulator_14: Database: [Console] Nintendo NES
13:29:37.1 4/7/2014: Validating: Emulator_14: Title Snap Path: C:\Emulators\FCEUX\assets\Nintendo NES\Titles
13:29:37.1 4/7/2014: Validating: Emulator_14: Box Art Path: C:\Emulators\FCEUX\assets\Nintendo NES\Boxes
13:29:37.1 4/7/2014: Validating: Emulator_14: Cart Art Path: C:\Emulators\FCEUX\assets\Nintendo NES\Cartridges
13:29:37.1 4/7/2014: Validating: Emulator_14: Manual Path: C:\Emulators\FCEUX\assets\Nintendo NES\Manuals
13:29:37.1 4/7/2014: Validating: Emulator_15: Snap Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Snaps
13:29:37.1 4/7/2014: Validating: Emulator_15: Control Panel Path: C:\Emulators\FCEUX\assets\Nintendo NES\Controls
13:29:37.1 4/7/2014: Validating: Emulator_15: Database: [Console] Nintendo Famicom Disk System
13:29:37.1 4/7/2014: Validating: Emulator_15: Title Snap Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Titles
13:29:37.1 4/7/2014: Validating: Emulator_15: Box Art Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Boxes
13:29:37.1 4/7/2014: Validating: Emulator_15: Cart Art Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Cartridges
13:29:37.1 4/7/2014: Validating: Emulator_15: Manual Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Manuals
13:29:37.1 4/7/2014: Validating: Emulator_16: Snap Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Snaps
13:29:37.1 4/7/2014: Validating: Emulator_16: Control Panel Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Controls
13:29:37.2 4/7/2014: Validating: Emulator_16: Database: [Console] Nintendo SNES
13:29:37.2 4/7/2014: Validating: Emulator_16: Title Snap Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Titles
13:29:37.2 4/7/2014: Validating: Emulator_16: Box Art Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Boxes
13:29:37.2 4/7/2014: Validating: Emulator_16: Cart Art Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Cartridges
13:29:37.2 4/7/2014: Validating: Emulator_16: Manual Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Manuals
13:29:37.2 4/7/2014: Validating: Emulator_17: Snap Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Snaps
13:29:37.2 4/7/2014: Validating: Emulator_17: Control Panel Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Controls
13:29:37.2 4/7/2014: Validating: Emulator_17: Database: [Console] NEC TurboGrafx-16
13:29:37.2 4/7/2014: Validating: Emulator_17: Title Snap Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Titles
13:29:37.2 4/7/2014: Validating: Emulator_17: Box Art Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Boxes
13:29:37.2 4/7/2014: Validating: Emulator_17: Cart Art Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Cartridges
13:29:37.2 4/7/2014: Validating: Emulator_17: Manual Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Manuals
13:29:37.2 4/7/2014: Validating: Emulator_18: Snap Path: C:\Emulators\Mednafen\assets\NEC TurboGrafx CD\Snaps
13:29:37.2 4/7/2014: Validating: Emulator_18: Control Panel Path: C:\Emulators\Mednafen\assets\NEC TurboGrafx CD\Controls
13:29:37.3 4/7/2014: Validating: Emulator_18: Database: [Console] NEC TurboGrafx CD
13:29:37.3 4/7/2014: Validating: Emulator_18: Title Snap Path: C:\Emulators\Mednafen\assets\NEC TurboGrafx CD\Titles
13:29:37.3 4/7/2014: Validating: Emulator_18: Box Art Path: C:\Emulators\Mednafen\assets\NEC TurboGrafx CD\Boxes
13:29:37.3 4/7/2014: Validating: Emulator_18: Cart Art Path: C:\Emulators\Mednafen\assets\NEC TurboGrafx CD\Cartridges
13:29:37.3 4/7/2014: Validating: Emulator_18: Manual Path: C:\Emulators\Mednafen\assets\NEC TurboGrafx CD\Manuals
13:29:37.3 4/7/2014: Validating: Emulator_19: Snap Path: C:\Emulators\MESS\assets\Atari Lynx\Snaps
13:29:37.3 4/7/2014: Validating: Emulator_19: Control Panel Path: C:\Emulators\MESS\assets\Atari Lynx\Controls
13:29:37.3 4/7/2014: Validating: Emulator_19: Database: [Handheld] Atari Lynx
13:29:37.3 4/7/2014: Validating: Emulator_19: Title Snap Path: C:\Emulators\MESS\assets\Atari Lynx\Titles
13:29:37.3 4/7/2014: Validating: Emulator_19: Box Art Path: C:\Emulators\MESS\assets\Atari Lynx\Boxes
13:29:37.3 4/7/2014: Validating: Emulator_19: Cart Art Path: C:\Emulators\MESS\assets\Atari Lynx\Cartridges
13:29:37.3 4/7/2014: Validating: Emulator_19: Manual Path: C:\Emulators\MESS\assets\Atari Lynx\Manuals
13:29:37.3 4/7/2014: Validating: Emulator_20: Snap Path: C:\Emulators\MESS\assets\SNK Neo Geo Pocket Color\Snaps
13:29:37.3 4/7/2014: Validating: Emulator_20: Control Panel Path: C:\Emulators\MESS\assets\SNK Neo Geo Pocket Color\Controls
13:29:37.3 4/7/2014: Validating: Emulator_20: Database: [Handheld] SNK Neo Geo Pocket Color
13:29:37.4 4/7/2014: Validating: Emulator_20: Title Snap Path: C:\Emulators\MESS\assets\SNK Neo Geo Pocket Color\Titles
13:29:37.4 4/7/2014: Validating: Emulator_20: Box Art Path: C:\Emulators\MESS\assets\SNK Neo Geo Pocket Color\Boxes
13:29:37.4 4/7/2014: Validating: Emulator_20: Cart Art Path: C:\Emulators\MESS\assets\SNK Neo Geo Pocket Color\Cartridges
13:29:37.4 4/7/2014: Validating: Emulator_20: Manual Path: C:\Emulators\MESS\assets\SNK Neo Geo Pocket Color\Manuals
13:29:37.4 4/7/2014: Validating: Emulator_21: Snap Path: C:\Emulators\BlueMSX\Assets\Microsoft MSX\Snaps
13:29:37.4 4/7/2014: Validating: Emulator_21: Control Panel Path: C:\Emulators\BlueMSX\Assets\Microsoft MSX\Controls
13:29:37.4 4/7/2014: Validating: Emulator_21: Database: [PC] Microsoft MSX
13:29:37.4 4/7/2014: Validating: Emulator_21: Title Snap Path: C:\Emulators\BlueMSX\Assets\Microsoft MSX\Titles
13:29:37.4 4/7/2014: Validating: Emulator_21: Box Art Path: C:\Emulators\BlueMSX\Assets\Microsoft MSX\Boxes
13:29:37.4 4/7/2014: Validating: Emulator_21: Cart Art Path: C:\Emulators\BlueMSX\Assets\Microsoft MSX\Cartridges
13:29:37.4 4/7/2014: Validating: Emulator_21: Manual Path: C:\Emulators\BlueMSX\Assets\Microsoft MSX\Manuals
13:29:37.4 4/7/2014: Validating: Emulator_22: Snap Path: C:\Emulators\MESS\assets\GCE Vectrex\Snaps
13:29:37.4 4/7/2014: Validating: Emulator_22: Control Panel Path: C:\Emulators\MESS\assets\GCE Vectrex\Controls
13:29:37.4 4/7/2014: Validating: Emulator_22: Database: [Console] GCE Vectrex
13:29:37.5 4/7/2014: Validating: Emulator_22: Title Snap Path: C:\Emulators\MESS\assets\GCE Vectrex\Titles
13:29:37.5 4/7/2014: Validating: Emulator_22: Box Art Path: C:\Emulators\MESS\assets\GCE Vectrex\Boxes
13:29:37.5 4/7/2014: Validating: Emulator_22: Cart Art Path: C:\Emulators\MESS\assets\GCE Vectrex\Cartridges
13:29:37.5 4/7/2014: Validating: Emulator_22: Manual Path: C:\Emulators\MESS\assets\GCE Vectrex\Manuals
13:29:37.5 4/7/2014: Validating: Emulator_23: Snap Path: C:\Emulators\MESS\assets\Super Vision\Snaps
13:29:37.5 4/7/2014: Warning: Emulator_23: Snap Path Does not exist
13:29:37.5 4/7/2014: Validating: Emulator_23: Control Panel Path: C:\Emulators\MESS\assets\Super Vision\Controls
13:29:37.5 4/7/2014: Warning: Emulator_23: Control Panel Path Does not exist
13:29:37.5 4/7/2014: Validating: Emulator_23: Database: [Handheld] Watara Supervision
13:29:37.5 4/7/2014: Validating: Emulator_23: Title Snap Path: C:\Emulators\MESS\assets\Super Vision\Snaps
13:29:37.5 4/7/2014: Warning: Emulator_23: Title Snap Path Does not exist
13:29:37.5 4/7/2014: Validating: Emulator_23: Box Art Path: C:\Emulators\MESS\assets\Super Vision\Snaps
13:29:37.5 4/7/2014: Warning: Emulator_23: Box Art Path Does not exist
13:29:37.5 4/7/2014: Validating: Emulator_23: Cart Art Path: C:\Emulators\MESS\assets\Super Vision\Snaps
13:29:37.5 4/7/2014: Warning: Emulator_23: Cart Art Path Does not exist
13:29:37.6 4/7/2014: Validating: Emulator_23: Manual Path: C:\Emulators\MESS\assets\Super Vision\Snaps
13:29:37.6 4/7/2014: Warning: Emulator_23: Manual Path Does not exist
13:29:37.6 4/7/2014: Validating: Emulator_31: Snap Path: C:\Emulators\FCEUX\assets\Nintendo NES\Snaps
13:29:37.6 4/7/2014: Validating: Emulator_31: Control Panel Path: C:\Emulators\FCEUX\assets\Nintendo NES\Controls
13:29:37.6 4/7/2014: Validating: Emulator_31: Database: [Console] Nintendo NES
13:29:37.6 4/7/2014: Validating: Emulator_31: Title Snap Path: C:\Emulators\FCEUX\assets\Nintendo NES\Titles
13:29:37.6 4/7/2014: Validating: Emulator_31: Box Art Path: C:\Emulators\FCEUX\assets\Nintendo NES\Boxes
13:29:37.6 4/7/2014: Validating: Emulator_31: Cart Art Path: C:\Emulators\FCEUX\assets\Nintendo NES\Cartridges
13:29:37.6 4/7/2014: Validating: Emulator_31: Manual Path: C:\Emulators\FCEUX\assets\Nintendo NES\Manuals
13:29:37.6 4/7/2014: Validating: Emulator_32: Snap Path: C:\Emulators\MESS\assets\Atari 7800\Snaps
13:29:37.6 4/7/2014: Validating: Emulator_32: Control Panel Path: C:\Emulators\MESS\assets\Atari 7800\Controls
13:29:37.6 4/7/2014: Validating: Emulator_32: Database: [Console] Atari 7800
13:29:37.6 4/7/2014: Validating: Emulator_32: Title Snap Path: C:\Emulators\MESS\assets\Atari 7800\Titles
13:29:37.6 4/7/2014: Validating: Emulator_32: Box Art Path: C:\Emulators\MESS\assets\Atari 7800\Boxes
13:29:37.6 4/7/2014: Validating: Emulator_32: Cart Art Path: C:\Emulators\MESS\assets\Atari 7800\Cartridges
13:29:37.7 4/7/2014: Validating: Emulator_32: Manual Path: C:\Emulators\MESS\assets\Atari 7800\Manuals
13:29:37.7 4/7/2014: Validating: Emulator_33: Snap Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Snaps
13:29:37.7 4/7/2014: Validating: Emulator_33: Control Panel Path: C:\Emulators\FCEUX\assets\Nintendo NES\Controls
13:29:37.7 4/7/2014: Validating: Emulator_33: Database: [Console] Nintendo Famicom Disk System
13:29:37.7 4/7/2014: Validating: Emulator_33: Title Snap Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Titles
13:29:37.7 4/7/2014: Validating: Emulator_33: Box Art Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Boxes
13:29:37.7 4/7/2014: Validating: Emulator_33: Cart Art Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Cartridges
13:29:37.7 4/7/2014: Validating: Emulator_33: Manual Path: C:\Emulators\FCEUX\assets\Nintendo FDS\Manuals
13:29:37.7 4/7/2014: Validating: Emulator_34: Snap Path: C:\Emulators\MESS\assets\Coleco Vision\Snaps
13:29:37.7 4/7/2014: Validating: Emulator_34: Control Panel Path: C:\Emulators\MESS\assets\Coleco Vision\Controls
13:29:37.7 4/7/2014: Validating: Emulator_34: Database: [Console] Coleco Vision
13:29:37.7 4/7/2014: Validating: Emulator_34: Title Snap Path: C:\Emulators\MESS\assets\Coleco Vision\Titles
13:29:37.7 4/7/2014: Validating: Emulator_34: Box Art Path: C:\Emulators\MESS\assets\Coleco Vision\Boxes
13:29:37.7 4/7/2014: Validating: Emulator_34: Cart Art Path: C:\Emulators\MESS\assets\Coleco Vision\Cartridges
13:29:37.8 4/7/2014: Validating: Emulator_34: Manual Path: C:\Emulators\MESS\assets\Coleco Vision\Manuals
13:29:37.8 4/7/2014: Validating: Emulator_35: Snap Path: C:\Emulators\MESS\assets\Intellivision\Snaps
13:29:37.8 4/7/2014: Validating: Emulator_35: Control Panel Path: C:\Emulators\MESS\assets\Coleco Vision\Controls
13:29:37.8 4/7/2014: Validating: Emulator_35: Database: [Console] Mattel Intellivision
13:29:37.8 4/7/2014: Validating: Emulator_35: Title Snap Path: C:\Emulators\MESS\assets\Intellivision\Titles
13:29:37.8 4/7/2014: Validating: Emulator_35: Box Art Path: C:\Emulators\MESS\assets\Intellivision\Boxes
13:29:37.8 4/7/2014: Validating: Emulator_35: Cart Art Path: C:\Emulators\MESS\assets\Intellivision\Cartridges
13:29:37.8 4/7/2014: Validating: Emulator_35: Manual Path: C:\Emulators\MESS\assets\Intellivision\Manuals
13:29:37.8 4/7/2014: Validating: Emulator_36: Snap Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Snaps
13:29:37.8 4/7/2014: Validating: Emulator_36: Control Panel Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Controls
13:29:37.8 4/7/2014: Validating: Emulator_36: Database: [Console] Nintendo SNES
13:29:37.9 4/7/2014: Validating: Emulator_36: Title Snap Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Titles
13:29:37.9 4/7/2014: Validating: Emulator_36: Box Art Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Boxes
13:29:37.9 4/7/2014: Validating: Emulator_36: Cart Art Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Cartridges
13:29:37.9 4/7/2014: Validating: Emulator_36: Manual Path: C:\Emulators\ZSNES\assets\Nintendo SNES\Manuals
13:29:37.9 4/7/2014: Validating: Emulator_37: Snap Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Snaps
13:29:37.9 4/7/2014: Validating: Emulator_37: Control Panel Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Controls
13:29:37.9 4/7/2014: Validating: Emulator_37: Database: [Console] NEC TurboGrafx-16
13:29:37.9 4/7/2014: Validating: Emulator_37: Title Snap Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Titles
13:29:37.9 4/7/2014: Validating: Emulator_37: Box Art Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Boxes
13:29:37.9 4/7/2014: Validating: Emulator_37: Cart Art Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Cartridges
13:29:37.9 4/7/2014: Validating: Emulator_37: Manual Path: C:\Emulators\MESS\assets\NEC TurboGrafx-16\Manuals
13:29:37.9 4/7/2014: Validating: Emulator_38: Snap Path: C:\Emulators\MESS\assets\Sega Master System\Snaps
13:29:37.9 4/7/2014: Validating: Emulator_38: Control Panel Path: C:\Emulators\MESS\assets\Sega Master System\Controls
13:29:37.9 4/7/2014: Validating: Emulator_38: Database: [Console] Sega Master System
13:29:38.0 4/7/2014: Validating: Emulator_38: Title Snap Path: C:\Emulators\MESS\assets\Sega Master System\Titles
13:29:38.0 4/7/2014: Validating: Emulator_38: Box Art Path: C:\Emulators\MESS\assets\Sega Master System\Boxes
13:29:38.0 4/7/2014: Validating: Emulator_38: Cart Art Path: C:\Emulators\MESS\assets\Sega Master System\Cartridges
13:29:38.0 4/7/2014: Validating: Emulator_38: Manual Path: C:\Emulators\MESS\assets\Sega Master System\Manuals
13:29:38.0 4/7/2014: Validating: Emulator_39: Snap Path: C:\Emulators\MESS\assets\Sega Genesis\Snaps
13:29:38.0 4/7/2014: Validating: Emulator_39: Control Panel Path: C:\Emulators\MESS\assets\Sega Genesis\Controls
13:29:38.0 4/7/2014: Validating: Emulator_39: Database: [Console] Sega Genesis
13:29:38.0 4/7/2014: Validating: Emulator_39: Title Snap Path: C:\Emulators\MESS\assets\Sega Genesis\Titles
13:29:38.0 4/7/2014: Validating: Emulator_39: Box Art Path: C:\Emulators\MESS\assets\Sega Genesis\Boxes
13:29:38.0 4/7/2014: Validating: Emulator_39: Cart Art Path: C:\Emulators\MESS\assets\Sega Genesis\Cartridges
13:29:38.0 4/7/2014: Validating: Emulator_39: Manual Path: C:\Emulators\MESS\assets\Sega Genesis\Manuals
13:29:38.1 4/7/2014: Restoring Emulator from Cache: 2
13:29:38.3 4/7/2014: Restoring Emulator Database From Cache: 2
13:29:38.5 4/7/2014: Restoring Emulator from Cache: 3
13:29:38.5 4/7/2014: Restoring Emulator Database From Cache: 3
13:29:38.6 4/7/2014: Restoring Emulator from Cache: 4
13:29:38.6 4/7/2014: Restoring Emulator Database From Cache: 4
13:29:38.7 4/7/2014: Restoring Emulator from Cache: 5
13:29:38.7 4/7/2014: Restoring Emulator Database From Cache: 5
13:29:38.8 4/7/2014: Restoring Emulator from Cache: 6
13:29:38.9 4/7/2014: Restoring Emulator Database From Cache: 6
13:29:38.9 4/7/2014: Restoring Emulator from Cache: 7
13:29:39.0 4/7/2014: Restoring Emulator Database From Cache: 7
13:29:39.1 4/7/2014: Restoring Emulator from Cache: 8
13:29:39.1 4/7/2014: Restoring Emulator Database From Cache: 8
13:29:39.2 4/7/2014: Restoring Emulator from Cache: 9
13:29:39.2 4/7/2014: Restoring Emulator Database From Cache: 9
13:29:39.3 4/7/2014: Restoring Emulator from Cache: 10
13:29:39.3 4/7/2014: Restoring Emulator Database From Cache: 10
13:29:39.4 4/7/2014: Restoring Emulator from Cache: 11
13:29:39.4 4/7/2014: Restoring Emulator Database From Cache: 11
13:29:39.5 4/7/2014: Restoring Emulator from Cache: 12
13:29:39.5 4/7/2014: Restoring Emulator Database From Cache: 12
13:29:39.7 4/7/2014: Restoring Emulator from Cache: 13
13:29:39.7 4/7/2014: Restoring Emulator Database From Cache: 13
13:29:39.7 4/7/2014: Restoring Emulator from Cache: 14
13:29:39.8 4/7/2014: Restoring Emulator Database From Cache: 14
13:29:39.9 4/7/2014: Restoring Emulator from Cache: 15
13:29:40.0 4/7/2014: Restoring Emulator Database From Cache: 15
13:29:40.1 4/7/2014: Restoring Emulator from Cache: 16
13:29:40.2 4/7/2014: Restoring Emulator Database From Cache: 16
13:29:40.2 4/7/2014: Restoring Emulator from Cache: 17
13:29:40.3 4/7/2014: Restoring Emulator Database From Cache: 17
13:29:40.4 4/7/2014: Restoring Emulator from Cache: 18
13:29:40.4 4/7/2014: No Database Data: 18
13:29:40.5 4/7/2014: Restoring Emulator from Cache: 19
13:29:40.6 4/7/2014: Restoring Emulator Database From Cache: 19
13:29:40.6 4/7/2014: Restoring Emulator from Cache: 20
13:29:40.7 4/7/2014: Restoring Emulator Database From Cache: 20
13:29:40.8 4/7/2014: Restoring Emulator from Cache: 21
13:29:40.8 4/7/2014: Restoring Emulator Database From Cache: 21
13:29:40.9 4/7/2014: Restoring Emulator from Cache: 22
13:29:40.9 4/7/2014: Restoring Emulator Database From Cache: 22
13:29:41.0 4/7/2014: Restoring Emulator from Cache: 23
13:29:41.1 4/7/2014: Restoring Emulator Database From Cache: 23
13:29:41.1 4/7/2014: Restoring Emulator Database From Cache: 31
13:29:41.2 4/7/2014: Restoring Emulator Database From Cache: 32
13:29:41.3 4/7/2014: Restoring Emulator Database From Cache: 33
13:29:41.4 4/7/2014: Restoring Emulator Database From Cache: 34
13:29:41.5 4/7/2014: Restoring Emulator Database From Cache: 35
13:29:41.6 4/7/2014: Restoring Emulator Database From Cache: 36
13:29:41.7 4/7/2014: Restoring Emulator Database From Cache: 37
13:29:41.8 4/7/2014: Restoring Emulator Database From Cache: 38
13:29:41.9 4/7/2014: Restoring Emulator Database From Cache: 39
13:30:04.5 4/7/2014: Creating instance of global keyboard hook
13:30:04.6 4/7/2014: Running: cmd.exe /c C: fceux.exe "C:\Emulators\FCEUX\NES Roms\Balloon Fight (U) [!].nes"
13:30:04.8 4/7/2014: Shutting down display
13:30:13.1 4/7/2014: Writing Stats
13:30:13.2 4/7/2014: Plugin: Game Exit
13:30:13.2 4/7/2014: Plugin: Process Commands
13:30:13.2 4/7/2014: Refreshing Keyboard
13:30:13.4 4/7/2014: Initialising Audio
13:30:13.4 4/7/2014: Relaunching HideOS
13:30:13.8 4/7/2014: Restoring Window
13:30:13.8 4/7/2014: Reinitializing Graphics System
13:30:16.3 4/7/2014: Returning to GameEx
13:30:33.6 4/7/2014: Running: cmd.exe /c C: Mess64.exe a7800 -cart "C:\Emulators\MESS\roms\a7800\Fight Night (1988) (Atari)" -joy -now
13:30:33.7 4/7/2014: Shutting down display
13:30:35.9 4/7/2014: Writing Stats
13:30:36.0 4/7/2014: Plugin: Game Exit
13:30:36.0 4/7/2014: Plugin: Process Commands
13:30:36.0 4/7/2014: Refreshing Keyboard
13:30:36.1 4/7/2014: Initialising Audio
13:30:36.2 4/7/2014: Relaunching HideOS
13:30:36.5 4/7/2014: Restoring Window
13:30:36.5 4/7/2014: Reinitializing Graphics System
13:30:38.6 4/7/2014: Returning to GameEx
13:30:42.4 4/7/2014: Exiting GameEx!
13:30:42.4 4/7/2014: Disposing all videos
13:30:42.4 4/7/2014: Deleting temporary Karaoke videos
13:30:42.4 4/7/2014: Disposing Image List
13:30:42.4 4/7/2014: Disposing Fonts
13:30:42.4 4/7/2014: Disposing Surfaces
13:30:42.5 4/7/2014: Saving Settings
13:30:42.5 4/7/2014: Shutting down Bass
13:30:42.5 4/7/2014: Closing HideOS.exe
13:30:42.8 4/7/2014: Disposing Plugins
13:30:42.8 4/7/2014: Closing database connection
13:30:42.8 4/7/2014: Checking for applications to Launch On Exit
13:30:42.9 4/7/2014: Media Center was not open when starting GameEx, so not launching
13:30:42.9 4/7/2014: Bye
Okay okay, never mind. It's not working, but...
Balloon Fight works because it's at the top of my list since I've tested it so much. When I run the top instance the game loads, but when I run the main-group instance, I still get the error message. Here's a rough text illustration:
Balloon Fight <-- Works
Action 52
Archon
Balloon Fight <-- Doesn't Work
Clu Clu Land
