I just recently downloaded the Ambient Occlusion theme and I haven't messed around with themes much but I really like how this one looks. Anyways, I moved Custom Menu.ini file into my GameEx CONFIG folder and emulators are showing that I don't have set up and some aren't showing. I know I have to set them up in the Custom Menu.ini but I am clueless lol would any of you be willing to set my menu back up for me? Ive attached my inis let me know if anything else is needed.
CustomMenu.ini
GameEx.ini
Did you not use the custom menu app to set up your menus?! :o It would be impossible for anyone else to edit your menus as we all have different setups. Check out the Custom Menu Guide. It's very easy to do! ;) Did you copy it over from another install or something? I'm afraid custom menus won't work like that unless you copy your other setup (all emu's, app's etc) EXACTLY.
Yeah I copied over the custom menu file from the themes folder.Like i said I haven't really messed with themes much. But since I bought GameEx its been another story lol. I appreciate you pointing me in the right direction :) it seems easy enough now
