Hi All,
At one time, I had GameEX setup to use my mouse/trackball, and NOT be controlled by using my joysticks (I have a full cabinet, but I have a track ball on also, and that is what I prefer to move around in GameEX)
Can anyone tell me the setting to make GameEX use the mouse in this front end, and not be controlled by joysticks?
Kudos to the developer, outside of this setting I have never had a real issues with this front-end.
  Linker said:
Hi All,
Hi, there are two settings that disable the mouse, one is 'Arcade Mode' on and the other is much more obvious which is just enable/disable mouse.
If your are running at a resolution below 640 x 480 arcade mode is automatically turned on and the mouse will be disabled.
