Is the mame game resolution controlled by the theme or by the desktop? I use the arcade 640x480 theme. Are my mame games using that resolution or are they using my desktop resolution? Any way to change resolutions on the fly?
MAME itself determines the resolution it will run at. By default it trys to detect the most suitable resolution based on the game. You can make it use a fixed resolution, and also just make it use the desktop resolution. I won't explain how you do all this now, kinda busy on something. However the only version I know that allows you to switch resolutions on the fly is AdvanceMAME.
