Nightlife Posted February 3, 2014 Share Posted February 3, 2014 This is an interesting one... any help would be very appreciated! The Model 2 emulator has an ability to run scripts. Someone has written an excellent script to enable lightguns to function better with this emulator. Here is the discussion with the scripts:http://forum.arcadecontrols.com/index.php/topic,104484.msg1287623.html#msg1287623The way it works is that if the scripts are in the emulator's folders, when you pick a game with the Model 2 emulator, the script automatically calls an exe which runs, and then closes when complete. It's perfect... unless used with GameEx. So basically, the game doesn't load because it gets hung up on the exe called in the script.Any ideas how I can make this function? Thanks! Link to comment Share on other sites More sharing options...
nullPointer Posted February 3, 2014 Share Posted February 3, 2014 How does it get hung up. Does it just return to GameEx or something? What happens if you launch it from Run Last Game (runitgame.bat)? Link to comment Share on other sites More sharing options...
Nightlife Posted February 3, 2014 Author Share Posted February 3, 2014 Returns to GameEx. If then I quit GameEx I can see that a cmd.exe is open. Once I close that, the game starts up.Where is runitgame.bat? How do I run that? Link to comment Share on other sites More sharing options...
nullPointer Posted February 3, 2014 Share Posted February 3, 2014 After having attempted to run the Model 2 emulator from GameEx go to:All Programs > GameEx > Utilities > Run Last GameThis is basically a generated batch file that runs the exact same commands that GameEx uses to run the emulator. It's a good way to determine whether there's a problem happening with GameEx, or whether there's a problem with the command being used to run it (or possibly even the emulator itself). Link to comment Share on other sites More sharing options...
Tempest Posted February 3, 2014 Share Posted February 3, 2014 Did you get the latest version of the script? The author claims that he needed to modify it to close the cmd window. Once that part works, you will need to use an advanced config to watch for additional processes.Edit: I wonder if his Process,Close,cmd.exe is closing Runitgame.bat, and not his own cmd.exe? I would think that he could get the pid of the cmd.exe that he spawns, and then make sure to close that cmd.exe, and not runitgame.bat. 2 Link to comment Share on other sites More sharing options...
Nightlife Posted February 3, 2014 Author Share Posted February 3, 2014 Here's the latest:- Using the newest version of the script- Run Last Game causes the same thing to happen (the cmd appears and doesn't go away)- Also I forgot to mention this doesn't work when using the "use model 2" feature in GameEx, or when setting it up as its own emulatorI'm assuming I should use an advanced config... any ideas on where I should start?Thanks so much for the help... Link to comment Share on other sites More sharing options...
nullPointer Posted February 3, 2014 Share Posted February 3, 2014 The Run Last Game information is good to know since it basically takes GameEx out of the equation for the time being. What I mean is that we need to get this all running from the command line before it can be incorporated back into GameEx.So I would start with your runitgame.bat script, and tweak it to the point where everything can be started from that batch file. Once that's working OK you can translate those commands back into GameEx, and hopefully have good results.Tempest's comments also lead me to wonder whether the external script itself may be causing problems for you. 1 Link to comment Share on other sites More sharing options...
DazzleHP Posted February 3, 2014 Share Posted February 3, 2014 The fact that there might be two cmd windows open at the same time might be causing problems. Even if you explicitly tell GameEx to wait for it (cmd.exe) - how does it know which (command window) is which? I'm of course just re-wording Tempest's enlightening post above. It makes a lot of sense though. Link to comment Share on other sites More sharing options...
Nightlife Posted February 3, 2014 Author Share Posted February 3, 2014 I'm a scripting newbie... I wouldn't even know where to start on tweaking the .bat files. Link to comment Share on other sites More sharing options...
Adultery Posted February 3, 2014 Share Posted February 3, 2014 We were all n00bz at one point my friend. It's your desire to make it work that will teach you the path. Link to comment Share on other sites More sharing options...
Tempest Posted February 4, 2014 Share Posted February 4, 2014 Try this exe instead of Ramjet's and let me know what happens.Test.zip 1 Link to comment Share on other sites More sharing options...
Nightlife Posted February 4, 2014 Author Share Posted February 4, 2014 Try this exe instead of Ramjet's and let me know what happens.So if I'm reading you accurately, I should rename the Test.exe to RamjetM2Borderless.exe and put that in the folder?If I do that, The cmd prompt comes up and sits there. If I close the cmd window, the game then starts. Link to comment Share on other sites More sharing options...
Tempest Posted February 4, 2014 Share Posted February 4, 2014 Yes, that is what I meant.Instead of running the script from within Model2, try using the launch before in your emulator config. Again, let me know what happens.I do not have Model2 installed, so we will just have to keep it up with trial and error. 1 Link to comment Share on other sites More sharing options...
Nightlife Posted February 4, 2014 Author Share Posted February 4, 2014 No sweat, I appreciate the help. So just to be 100% clear, are you saying set test.exe to launch before, and take RamjetM2Borderless.exe out of the equation completely? Link to comment Share on other sites More sharing options...
Nightlife Posted February 4, 2014 Author Share Posted February 4, 2014 If I do what I described above (did I get the steps right?) what happens is I select the game in GameEx, it kicks me to the Windows UI, but the RamjetM2Borderless icon is in the task bar. Nothing else happens. If I close the item in the task bar, the cmd comes up and nothing happens. If I then close that, the game starts. Link to comment Share on other sites More sharing options...
Tempest Posted February 4, 2014 Share Posted February 4, 2014 Can you post the text that is in the cmd window?To do that, right-click on the cmd window and select 'Mark'. Highlight the text and then press 'Enter'. The text will be sent to the clipboard. Paste it into your reply. Link to comment Share on other sites More sharing options...
Nightlife Posted February 5, 2014 Author Share Posted February 5, 2014 Can you post the text that is in the cmd window?To do that, right-click on the cmd window and select 'Mark'. Highlight the text and then press 'Enter'. The text will be sent to the clipboard. Paste it into your reply.The command window is blank..... nothing to paste... Link to comment Share on other sites More sharing options...
Tempest Posted February 5, 2014 Share Posted February 5, 2014 Try this script within Model2 and let me know what happens. (Crossing my fingers)RamjetM2Borderless.zip 4 Link to comment Share on other sites More sharing options...
Nightlife Posted February 5, 2014 Author Share Posted February 5, 2014 IT WORKS!!!!!!!!!FYI, when I have it set to launch before, I get an error that reads, "Unable to identify correct cmd.exe window." But if it's simply hangin' out in the folder, it works like a charm!!! So now it works great when using the "Use Model 2" feature as well.THANK YOU SO MUCH!!!!!!!!! 1 Link to comment Share on other sites More sharing options...
Adultery Posted February 5, 2014 Share Posted February 5, 2014 Nice work as usual, Matt! :-) 1 Link to comment Share on other sites More sharing options...
nullPointer Posted February 5, 2014 Share Posted February 5, 2014 Great job Tempest! It's moments like these that make me so proud to be a part of this community. 1 Link to comment Share on other sites More sharing options...
stigzler Posted February 5, 2014 Share Posted February 5, 2014 good work tmpst, amd great share, night 1 Link to comment Share on other sites More sharing options...
Tempest Posted February 5, 2014 Share Posted February 5, 2014 Awesome that it worked for you!I wasn't sure if I was going to be able to get there without having Model2 installed. Link to comment Share on other sites More sharing options...
Nightlife Posted February 5, 2014 Author Share Posted February 5, 2014 This is so great. It's literally the difference between playable and unplayable, if you have light guns. Again, thank you!!!! Link to comment Share on other sites More sharing options...
stigzler Posted February 5, 2014 Share Posted February 5, 2014 Have both model 2 and lightguns - not set up yet - what lightgun games it play?Desperate to get Lost World setup - is that model 2 or 3? Link to comment Share on other sites More sharing options...
