Hello guys!
I'm having trouble with the future pinball pinballX, sometimes it loads the table but does not place the credit, I need to load some of the attempts to get credit, is to solve it? ... Have to change something in the parameters pinballX?
Retro, not sure I fully understand....but are you saying when the table loads up AND you insert a credit, the credit does not register in FP?
If that is the case can you try two things and see if you get further....1) If you are using a 2 screen setup, move your mouse to the screen with the table and click once to make the screen active, then insert a credit. 2) Press the start button (1) first before inserting a credit.
Z
Z
I am using two screens yes, however I'm using on a pinball machine that I built, and there will not have to give this mouse click, the frontend pinballX already had to load without giving this click, is there anything I can do to solve that?
Look here and download this guide for jukebox. It contains instructions on how to compile and run a mouse click program http://www.gameex.info/forums/topic/14162-guide-for-installing-dwjukebox-for-pinballx-in-your-pincab/
This is a strange problem you are having as I have XP and don't have this problem. But you can create a autohotkey mouse click program that runs when a table is loaded to make sure it stays focused in the current window. It's a good precaution to have.
